421|8
441
【FRDM-MCXN947】TFT-LCD显示屏测试 [复制链接]
使用FLEXIO接口测试TFT-LCD显示屏,驱动芯片使用SSD1963。
一、硬件接口部分
1.1、使用板子上的LCD接口
1.2、SSD1963接口框图
1.3、SSD1963数据格式
SSD1963与显示屏之间数据接口的连接定义
1.4、显示屏接口
我的显示屏是18位总线,在配置SSD1963时,选择18位数据。
二、引脚配置
2.1、配置显示屏接口
2.2、配置外设
三、程序部分
3.1、mculcd.c
#include "main.h"
 * Prototypes
void BOARD_InitSmartDMA(void);
static void DEMO_InitFlexioMcuLcd(void);
static void DEMO_InitPanel(void);
static void DEMO_StartPanel(void);
static status_t DEMO_LcdWriteCommand(void *dbiXferHandle, uint32_t command);
static status_t DEMO_LcdWriteData(void *dbiXferHandle, void *data, uint32_t len_byte);
static status_t DEMO_LcdWriteMemory(void *dbiXferHandle, uint32_t command, const void *data, uint32_t len_byte);
 * Variables
/* The functions used to drive the panel. */
static dbi_xfer_ops_t s_flexioDbiOps = {
    .writeCommand          = DEMO_LcdWriteCommand,
    .writeData             = DEMO_LcdWriteData,
    .writeMemory           = DEMO_LcdWriteMemory,
    .readMemory            = NULL, /* Don't need read in this project. */
    .setMemoryDoneCallback = NULL, /* This used for upper layer to register callback.
                                      If the writeMemory is a non-blocking(or async)
                                      function, when write finished, the registered
                                      callback function will be called.
                                      In this project, to be simple, DEMO_LcdWriteMemory
                                      blocks to wait the write done, it is not async
                                      implementation, so don't need to set callback.
static ssd1963_handle_t lcdHandle;
static flexio_mculcd_smartdma_handle_t s_flexioLcdHandle;
static demo_pixel_t s_lcdBuffer[DEMO_BUFFER_HEIGHT][DEMO_BUFFER_WIDTH];
static volatile bool s_transferDone = false;
void FLEXIO_TransferCallback(FLEXIO_MCULCD_Type *,flexio_mculcd_smartdma_handle_t *,status_t ,void *)
    s_transferDone = true;
void BOARD_SetResetPin(bool set)
    GPIO_PinWrite(DEMO_SSD1963_RST_GPIO, DEMO_SSD1963_RST_PIN, (uint8_t)set);
    RESET_ClearPeripheralReset(kMUX_RST_SHIFT_RSTn);
    INPUTMUX_Init(INPUTMUX0);
    INPUTMUX_AttachSignal(INPUTMUX0, 0, kINPUTMUX_FlexioToSmartDma);
    /* Turnoff clock to inputmux to save power. Clock is only needed to make changes */
    INPUTMUX_Deinit(INPUTMUX0);
    SMARTDMA_InitWithoutFirmware();
    NVIC_EnableIRQ(SMARTDMA_IRQn);
    NVIC_SetPriority(SMARTDMA_IRQn, 3);
    /* dbiXferHandle is actually s_flexioLcdHandle, set by SSD1963_Init 4th parameter. */
    flexio_mculcd_smartdma_handle_t *flexioLcdHandle = (flexio_mculcd_smartdma_handle_t *)dbiXferHandle;
    /* Here use blocking way to send command, because command is short. */
    FLEXIO_MCULCD_Type *flexioLCD = flexioLcdHandle->base; /* flexioLcdDev */
    FLEXIO_MCULCD_StartTransfer(flexioLCD);
    FLEXIO_MCULCD_WriteCommandBlocking(flexioLCD, command);
    FLEXIO_MCULCD_StopTransfer(flexioLCD);
    return kStatus_Success;
     * Here use blocking way to write data, this function is generally
     * used to send command parameter, the data length is short.
    FLEXIO_MCULCD_WriteDataArrayBlocking(flexioLCD, data, len_byte);
    status_t status;
    flexio_mculcd_transfer_t xfer = {
        .command             = command,
        .mode                = kFLEXIO_MCULCD_WriteArray,
        .dataAddrOrSameValue = (uint32_t)data,
        .dataSize            = len_byte,
    status         = FLEXIO_MCULCD_TransferSMARTDMA(flexioLCD, flexioLcdHandle, &xfer);
    if (kStatus_Success != status)
        PRINTF("Write Memory Failed\r\n");
        while (1)
    else
        /* Wait for transfer done. */
        while (!s_transferDone)
    return status;
    status_t status;
    flexio_mculcd_config_t flexioMcuLcdConfig;
    flexio_mculcd_smartdma_config_t flexioEzhConfig = {
        .inputPixelFormat = kFLEXIO_MCULCD_RGB565,
        .outputPixelFormat = kFLEXIO_MCULCD_RGB565,
    /* Initialize the flexio MCU LCD. */
     * flexioMcuLcdConfig.enable = true;
     * flexioMcuLcdConfig.enableInDoze = false;
     * flexioMcuLcdConfig.enableInDebug = true;
     * flexioMcuLcdConfig.enableFastAccess = true;
     * flexioMcuLcdConfig.baudRate_Bps = 96000000U;
//    FLEXIO_MCULCD_GetDefaultConfig(&flexioMcuLcdConfig);
//    flexioMcuLcdConfig.baudRate_Bps = DEMO_FLEXIO_BAUDRATE_BPS;
//    status = FLEXIO_MCULCD_Init(&flexioLcdDev, &flexioMcuLcdConfig, DEMO_FLEXIO_CLOCK_FREQ);
//    if (kStatus_Success != status)
//        PRINTF("FlexIO MCULCD init failed\r\n");
//        while (1)
    /* Init SMARTDMA. */
 //   BOARD_InitSmartDMA();
//    /* Create FLEXIO_MCULCD SMARTDMA handle. */
//    status = FLEXIO_MCULCD_TransferCreateHandleSMARTDMA(&flexioLcdDev, &s_flexioLcdHandle, &flexioEzhConfig,
//                                                      DEMO_FLEXIO_TransferCallback, NULL);
//		status = FLEXIO_MCULCD_TransferCreateHandleSMARTDMA(&FLEXIO0_peripheralConfig, &ss_flexioLcdHandle, &FLEXIO0_smartdma_config,
//                                                      FLEXIO_TransferCallback, NULL);
//        PRINTF("FlexIO MCULCD handle creation failed\r\n");
//        while (1)
    status_t status;
    const ssd1963_config_t ssd1963Config = {
        .pclkFreq_Hz = DEMO_SSD1963_PCLK_FREQ,
#if SSD1963_DATA_WITDH == 16
        .pixelInterface = kSSD1963_PixelInterface16Bit565,
#else
        .pixelInterface = kSSD1963_PixelInterface8BitBGR888,
#endif
        .panelDataWidth = kSSD1963_PanelData18Bit,
        .polarityFlags  = DEMO_SSD1963_POLARITY_FLAG,
        .panelWidth     = DEMO_PANEL_WIDTH,
        .panelHeight    = DEMO_PANEL_HEIGHT,
        .hsw            = DEMO_SSD1963_HSW,
        .hfp            = DEMO_SSD1963_HFP,
        .hbp            = DEMO_SSD1963_HBP,
        .vsw            = DEMO_SSD1963_VSW,
        .vfp            = DEMO_SSD1963_VFP,
        .vbp            = DEMO_SSD1963_VBP
    /* Reset the SSD1963 LCD controller. */
    BOARD_SetResetPin(false);
    SDK_DelayAtLeastUs(1, SystemCoreClock); /* Delay 10ns. */
    BOARD_SetResetPin(true);
    SDK_DelayAtLeastUs(5000, SystemCoreClock); /* Delay 5ms. */
    status = SSD1963_Init(&lcdHandle, &ssd1963Config, &s_flexioDbiOps, &ss_flexioLcdHandle, DEMO_SSD1963_XTAL_FREQ);
        PRINTF("Panel initialization failed\r\n");
        while (1)
    SSD1963_StartDisplay(&lcdHandle);
    SSD1963_SetBackLight(&lcdHandle, 255);
 * Draw one window with pixel array, and delay some time after draw done.
void DEMO_DrawWindow(uint16_t startX,
                            uint16_t startY,
                            uint16_t endX,
                            uint16_t endY,
                            const uint8_t *data,
                            uint32_t dataLen,
                            uint32_t delayMsAfterDraw)
    SSD1963_SelectArea(&lcdHandle, startX, startY, endX, endY);
    SSD1963_WriteMemory(&lcdHandle, data, dataLen);
    if (delayMsAfterDraw > 0)
        SDK_DelayAtLeastUs(delayMsAfterDraw * 1000, SystemCoreClock);
 * Draw multiple windows with specified color, can delay some time each window draw finished.
 * In this example, the whole screen is devided in to 4 windows, this function fills the
 * windows one by one.
void DEMO_DrawMultiWindows(demo_pixel_t color, uint32_t intervalMs)
    /* Fill buffer with pixel. */
    for (uint32_t y = 0; y < DEMO_BUFFER_HEIGHT; y++)
        for (uint32_t x = 0; x < DEMO_BUFFER_WIDTH; x++)
            s_lcdBuffer[y][x] = color;
    /* Region 0. */
    DEMO_DrawWindow(0, 0, DEMO_BUFFER_WIDTH - 1, DEMO_BUFFER_HEIGHT - 1, (const uint8_t *)s_lcdBuffer,
                    sizeof(s_lcdBuffer), intervalMs);
    /* Region 1. */
    DEMO_DrawWindow(DEMO_BUFFER_WIDTH, 0, 2 * DEMO_BUFFER_WIDTH - 1, DEMO_BUFFER_HEIGHT - 1,
                    (const uint8_t *)s_lcdBuffer, sizeof(s_lcdBuffer), intervalMs);
    /* Region 2. */
    DEMO_DrawWindow(0, DEMO_BUFFER_HEIGHT, DEMO_BUFFER_WIDTH - 1, 2 * DEMO_BUFFER_HEIGHT - 1,
    /* Region 3. */
    DEMO_DrawWindow(DEMO_BUFFER_WIDTH, DEMO_BUFFER_HEIGHT, 2 * DEMO_BUFFER_WIDTH - 1, 2 * DEMO_BUFFER_HEIGHT - 1,
void init_mculcd(void)
	BOARD_InitBootPeripherals();
	DEMO_InitPanel();
	DEMO_DrawMultiWindows(DEMO_COLOR_BLACK, 0);
	DEMO_StartPanel();
3.2、mculcd.h
#ifndef __MCULCD_H
#define __MCULCD_H
#define DEMO_PANEL_WIDTH  640U
#define DEMO_PANEL_HEIGHT 480U
/* Macros for the LCD controller. */
#define DEMO_SSD1963_XTAL_FREQ     10000000U
#define DEMO_SSD1963_PCLK_FREQ     25000000U
#define DEMO_SSD1963_HSW           1U
#define DEMO_SSD1963_HFP           116U
#define DEMO_SSD1963_HBP           44U
#define DEMO_SSD1963_VSW           1U
#define DEMO_SSD1963_VFP           10U
#define DEMO_SSD1963_VBP           34U
#define DEMO_SSD1963_POLARITY_FLAG 0U
#define DEMO_SSD1963_RST_GPIO      GPIO4
#define DEMO_SSD1963_RST_PIN       7
#define DEMO_SSD1963_CS_GPIO       GPIO0
#define DEMO_SSD1963_CS_PIN        12
#define DEMO_SSD1963_RS_GPIO       GPIO0
#define DEMO_SSD1963_RS_PIN        7
#define DEMO_FLEXIO              FLEXIO0
#define DEMO_FLEXIO_CLOCK_FREQ   CLOCK_GetFlexioClkFreq()
#define DEMO_FLEXIO_BAUDRATE_BPS 160000000U /* 16-bit data bus, baud rate on each pin is 1MHz. */
/* Macros for FlexIO shifter, timer, and pins. */
#define DEMO_FLEXIO_WR_PIN           1
#define DEMO_FLEXIO_RD_PIN           0
#define DEMO_FLEXIO_DATA_PIN_START   16
#define DEMO_FLEXIO_TX_START_SHIFTER 0
#define DEMO_FLEXIO_RX_START_SHIFTER 0
#define DEMO_FLEXIO_TX_END_SHIFTER   7
#define DEMO_FLEXIO_RX_END_SHIFTER   7
#define DEMO_FLEXIO_TIMER            0
/* Macros for DMA */
#define DEMO_EDMA                  DMA0
#define DEMO_FLEXIO_TX_DMA_CHANNEL 0
#define DEMO_FLEXIO_TX_DMA_REQUEST kDma0RequestMuxFlexIO0ShiftRegister0Request
/* Buffer of the LCD send data. */
#define DEMO_BUFFER_WIDTH  (DEMO_PANEL_WIDTH / 2U)
#define DEMO_BUFFER_HEIGHT (DEMO_PANEL_HEIGHT / 2U)
/* Color for RGB565 */
typedef uint16_t demo_pixel_t;
#define DEMO_COLOR_RED   0xF800U
#define DEMO_COLOR_GREEN 0x07E0U
#define DEMO_COLOR_BLUE  0x001FU
#define DEMO_COLOR_WHITE 0xFFFFU
#define DEMO_COLOR_BLACK 0x0000U
void init_mculcd(void);
                            uint16_t startY,
                            uint16_t endX,
                            uint16_t endY,
                            uint32_t dataLen,
                            uint32_t delayMsAfterDraw);
void DEMO_DrawMultiWindows(demo_pixel_t color, uint32_t intervalMs);
#endif
3.3、main.c
#include "main.h"
int main(void)
	uint8_t i;
	uint8_t colorIdx                = 0;
	const demo_pixel_t colorTable[] = {
			DEMO_COLOR_RED,
			DEMO_COLOR_GREEN,
			DEMO_COLOR_BLUE,
			DEMO_COLOR_WHITE,
  CLOCK_EnableClock(kCLOCK_Gpio0);
	BOARD_InitDEBUG_UARTPins();
	BOARD_PowerMode_OD();
	BOARD_InitBootPins();
	BOARD_InitBootClocks();
	BOARD_InitDebugConsole();
	SysTick_Init();
	init_led();
	init_key();
	init_mculcd();
	while (1)
		DEMO_DrawMultiWindows(colorTable[colorIdx], 500);
		colorIdx++;
		if (colorIdx >= ARRAY_SIZE(colorTable))
				colorIdx = 0U;
		led_red_tog();
3.4、 源代码
n947_prj_20241222_2.rar (5.77 MB, 下载次数: 0)
四、运行结果
下载程序到开发板,显示屏显示如下
lvgl
此帖出自NXP MCU论坛
你这是做了转接板吗,看着好像直接连上去的   详情 回复 发表于 2024-12-27 11:03
点赞 关注(1)
2943
感觉楼主的速度有点慢,是不是楼主程序有延时。
此帖出自NXP MCU论坛
小窗口循环显示有延时  详情 回复 发表于 2024-12-23 10:06
441
bigbat 发表于 2024-12-23 09:40 感觉楼主的速度有点慢,是不是楼主程序有延时。
小窗口循环显示有延时
此帖出自NXP MCU论坛
7274
刷新颜色看起来还行,没有撕裂和卡顿。
此帖出自NXP MCU论坛
6585
这个要是有那个官方的模块效果会不会更好,省的配置了
此帖出自NXP MCU论坛
嗯,想通过MCLCD接口的配置的学习来了解这个接口方面的应用。  详情 回复 发表于 2024-12-27 10:53
在爱好的道路上不断前进,在生活的迷雾中播撒光引
441
秦天qintian0303 发表于 2024-12-25 22:53 这个要是有那个官方的模块效果会不会更好,省的配置了
此帖出自NXP MCU论坛
必须向你学习,就得这样才能印象深刻    详情 回复 发表于 2024-12-27 11:02
6585
TL-LED 发表于 2024-12-27 10:53 嗯,想通过MCLCD接口的配置的学习来了解这个接口方面的应用。
必须向你学习,就得这样才能印象深刻
此帖出自NXP MCU论坛
6585
此帖出自NXP MCU论坛
做的转接板,驱动一个老旧屏幕  详情 回复 发表于 2024-12-27 11:18
441
秦天qintian0303 发表于 2024-12-27 11:03 你这是做了转接板吗,看着好像直接连上去的
做的转接板,驱动一个老旧屏幕
此帖出自NXP MCU论坛
