36|0
Agilent 安捷伦U2001H二手探头 [复制链接]
U2001H USB power sensor measures average power over the frequency range 10 MHz to 6 GHz and power range -50 dBm to +30 dBm.
Highlights
Frequency range of 10 MHz to 6 GHz
Wide dynamic range (-50 dBm to +30 dBm)
Internal zeroing while connected to the DUT
High measurement speed of up to 250 readings/second
Support internal / external trigger measurements, internal triggering, and trace display
Display power measurements on a PC without the need of power meter
Compatible with other Keysight instruments
A BenchVue software license (BV0007B) is now included with your instrument. BenchVue makes it simple to connect, control instruments, and automate test sequences
