4332|12
86
电子钟程序问题 [复制链接]
#include
#define uchar unsigned char
#define ON 0
#define OFF 1
sbit buzz=P2^1;
sbit key_1=P1^0;
sbit key_2=P1^1;
sbit key_3=P1^2;
sbit key_4=P1^3;
uchar display_code[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90},
      display_sel[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f},
          display_bit[8];
char time_hour,time_min,time_sec,time_count;
char alarm_hour,alarm_min,alarm_sec;
uchar mode=1;
uchar station;
uchar disp_flash,disp_bit;
unsigned int time_flash;
bit int_time_on,alarm_time_on;
void delay2ms()
// 延时子程序
        unsigned char i,ms=2;
        while(ms--)
                for(i = 0; i < 120; i++);
   初始化
void initial()
        EA=1;
        ET0=1;
        ET1=1;
        TMOD=0X11;
        TH0=0X3C;        //50ms
        TL0=0XB0;
        TH1=0Xfc;        //1ms
        TL1=0X18;
        TR0=1;
        TR1=1;
        buzz=OFF;
        键盘扫描模块
void key_block()
        if(!key_1)        //模式切换
                delay2ms();
                if(!key_1)
                        mode++;
                        if(mode==3) mode=1;
                        while(!key_1);
        if(!key_2)        //调整时间位切换
                delay2ms();
                if(!key_2)
                        station++;
                        if(station!=0)
                         TR0=0;
                        if(station==4)
                                station=0;
                                TR0=1;
                         while(!key_2);
        if(!key_3)        //加功能识别
                delay2ms();
                if(!key_3)
                        if(mode==1)
                                switch(station)
                                        case 1:time_sec++;
                                                   if(time_sec==60) time_sec=0;
                                                   break;
                                        case 2:time_min++;
                                                   if(time_min==60) time_min=0;
                                                   break;
                                        case 3:time_hour++;
                                                   if(time_hour==24) time_hour=0;
                                                   break;
                                        default:break;
                         else if(mode==2)
                                 switch(station)
                                        case 1:alarm_sec++;
                                                   if(alarm_sec==60) alarm_sec=0;
                                                   break;
                                        case 2:alarm_min++;
                                                   if(alarm_min==60) alarm_min=0;
                                                   break;
                                        case 3:alarm_hour++;
                                                   if(alarm_hour==24) alarm_hour=0;
                                                   break;
                                        default:break;
                          while(!key_3);
        if(!key_4)        //减功能识别
                delay2ms();
                if(!key_4)
                        if(mode==1)
                                switch(station)
                                        case 1:time_sec--;
                                                   if(time_sec<0) time_sec=59;
                                                   break;
                                        case 2:time_min--;
                                                   if(time_min<0) time_min=59;
                                                   break;
                                        case 3:time_hour--;
                                                   if(time_hour<0) time_hour=23;
                                                   break;
                                        default:break;
                         else if(mode==2)
                                 switch(station)
                                        case 1:alarm_sec--;
                                                   if(alarm_sec<0) alarm_sec=59;
                                                   break;
                                        case 2:alarm_min--;
                                                   if(alarm_min<0) alarm_min=59;
                                                   break;
                                        case 3:alarm_hour--;
                                                   if(alarm_hour<0) alarm_hour=23;
                                                   break;
                                        default:break;
                          while(!key_4);
        显示部分
void display(uchar hour,uchar min,uchar sec)
        display_bit[7]=display_code[sec%10];
        display_bit[6]=display_code[sec/10];
        display_bit[5]=0xbf;
        display_bit[4]=display_code[min%10];
        display_bit[3]=display_code[min/10];
        display_bit[2]=0xbf;
    display_bit[1]=display_code[hour%10];
        display_bit[0]=display_code[hour/10];
void time_disp() interrupt 3 using 1        //1ms
        TH1=0Xfc;        //1ms
        TL1=0X18;
        time_flash++;
                if(time_flash==500)
                time_flash=0;
                disp_flash++;
                if(disp_flash==2)
                disp_flash=0;
                disp_bit++;
                if(disp_bit==8) disp_bit=0;
                P3=0xff;
                P0=display_bit[disp_bit];
                if(station)
                        if(!disp_flash)
                                P3=display_sel[disp_bit];
                   else P3=0xff;
                else P3=display_sel[disp_bit];
定时模块
void time0() interrupt 1 using 0
    TH0=0X3C;        //50ms
        TL0=0XB0;
        time_count++;
        if(time_count==20)
                time_count=0;
                time_sec++;
                if(time_sec==60)
                        time_sec=0;
                        time_min++;
                        if(time_min==60)
                                time_min=0;
                                time_hour++;
整点报时和闹钟模块
void time_report()
        if((time_hour-time_sec)>0)        //闹钟鸣叫的次数与小时相等
                int_time_on=1;
        else int_time_on=0;
        if((alarm_hour==time_hour)&&(alarm_min==time_min)&&(alarm_sec==time_sec))        //
当设置的闹钟时间与当前时间相等时,启动闹钟,鸣叫1min
                alarm_time_on=0;
    if(time_min-alarm_min==1)
                alarm_time_on=0;
        if(int_time_on||alarm_time_on)
                if(!disp_flash)
                        buzz=ON;
                else
                        buzz=OFF;
void main()
   initial();
   while(1)
                key_block();
                switch(mode)
                        case 1:display(time_hour,time_min,time_sec);
                                        break;
                        case 2:display(alarm_hour,alarm_min,alarm_sec);
                                        break;
                        default:break;
                 time_report();
//为什么整点报时与闹钟模块达不到我想要的效果,想了一个晚上还是想不通.....是初始设置有问题么?
不错,最近在搞这个东西来玩,学习了  详情 回复 发表于 2009-4-19 09:15
66
整点报时和闹钟模块
void time_report()
int_time_on=1;
else int_time_on=0;
alarm_time_on=0;
alarm_time_on=1;
if(!disp_flash)
buzz=ON;
else
buzz=OFF;
alarm_time_on=0;改为alarm_time_on=1;
把总是描述详细一点,别动不动贴一大堆代码上来,谁那么有空帮你看。
57
凡是看到一大堆代码,又没有说明的,一般我都路过.
78
对,贴代码要加说明,要不恶心坏了
75
路过中,不仅把一大段代码贴出来,还仅仅说了一句“//为什么整点报时与闹钟模块达不到我想要的效果,想了一个晚上还是想不通.....是初始设置有问题么?”都不知道要说什么
贴了一大堆代码.......
进入整点报时模块的条件是否符合?是否进入了该模块?该模块执行的行为和你设想的不同?
//自己调试一下吧。定位错误。
67
谢谢大家给的意见,我是新手,不足的地方我会改进的
引用 3 楼 ceFighter 的回复:
同感.楼主可以大致说一下自己的实现思路,这样大家才好给你建议.
82
这代码一般新手还很难 写啊,赞楼主下
引用 7 楼 xiaoQ1987 的回复:
85
谢谢大家了,问题我已经解决了,由于是通宵写的,有些细节没仔细考虑清楚,所以大家不要像我这样,通宵熬夜使人思维下降啊,深有感悟........
63
路过路过路过路过路过路过
82
不错,最近在搞这个东西来玩,学习了
