3446|3
54
CE6.0烧写求助 [复制链接]
我现在烧写ce6.0的nk.bin 下面是返回的串口信息。但是在最下面一行出现了错误,请大家帮助分析一下
Selection: D
Mark the bootimage area in Flash as RESERVED.
LAN91C111 EbootDeviceAddress B9C00300
pKITLArgs->MAC: 3412:7856:2391
LAN91Cxxx: Chip Id 9 Revision 1
INFO: SMSC LAN91C111 Ethernet controller initialized.
INFO: MAC address: 12-34-56-78-91-23
System ready!
Preparing for download...
FlashWrite: blockSize = 0x20000
FlashWrite: start writing at block 5
FlashWrite: numBlocksProgram: 1
FlashWrite: Image written
INFO: Using device name: 'ZYLONITE37155'
+EbootSendBootmeAndWaitForTftp
Sent BOOTME to 255.255.255.255
Packet has the following data:
  boot.bin[NULL]octet[NULL]
TFTP packet could have 1 name/value pairs
Locked Down Link 1
Src IP 192.168.3.140 Port 03D4   Dest IP 192.168.3.126 Port 12EE
Default TFTP block size set to: 512 bytes
There were no options detected in the TFTP
EthDown::TFTPD_OPEN::boot.bin
-EbootSendBootmeAndWaitForTftp
BL_IMAGE_TYPE_BIN
****** OEMVerifyMemory checking memory range [ 0x80702000 ==> 0x818707C3 ]...
BOOT FLASH 0x0 -> 0x7D80000
BOOT SDRAM 0x80000000 -> 0x83FFFFFF
****** RAM address ******
........................................................................................................................................................rom_offset=0x0.
..ImageStart = 0x0, ImageLength = 0x0, LaunchAddr = 0x0
Completed file(s):
[0]: Address=0x80702000  Length=0x116E7C4  Name="" Target=RAM
+OEMLaunch: Start 0x0, Length 0x0, LaunchAddr 0x0, RomHdr 0x0
Got EDBG_CMD_JUMPIMG
Got EDBG_CMD_CONFIG, flags:0x00000000
WriteImageToPartition: Start 0x80702000, Length 0x116E7C4
IsValidMBR: MBR sector = 0x180 (valid MBR)
OpenPartition: Partition Exists=0x1 for part 0x21.
Fatal Error: Partition size is smaller than Image size, formatting the whole flash:
To Format: The LowLevelFormat may take up to 5 minutes. Please wait patiently
Enter LowLevelFormat [0x6, 0x3eb].
Erasing flash block(s) [0x6, 0x3eb] (please wait): Done.
WriteMBR: MBR block = 0x6.
Done.
To Create: Creating new partition for PART_BINFS
OpenPartition: Partition Exists=0x0 for part 0x21.
CreatePartition: Enter CreatePartition for 0x21.
LastLogSector: Last log sector is: 0xf97f.
CreatePartition: Start = 0x1, Num = 0x22dd.
Log2Phys: Logical 0x1 -> Physical 0x181
OpenPartition: Partition Exists=0x0 for part 0x4.
CreatePartition: Enter CreatePartition for 0x4.
FindFreeSector: FreeSector is: 0x22de after processing part 0x21.
CreatePartition: Num sectors set to 0xd600 to allow for compaction blocks.
CreatePartition: Start = 0x2300, Num = 0xd600.
BP_SetDataPointer at 0x701000
To Write data: g_burnStart:0x80702000, g_burnSize:0x116E7C4
WriteData: Start = 0x701000, Length = 0x116e7c4.
WriteData: trying to write past end of partition.
Error: failed to BP_SetDataPointer()
SpinForever...
对,是不是什么空间分配不够?  详情 回复 发表于 2009-2-24 15:51
78
没用过CE6.0,路过
看信息,LZ可能要在下载前重新格式化flash,因为分区的大小不对!
这句话是关键:Partition size is smaller than Image size
57
这个板子是第一次使用,所以还没有经过格式化
62
对,是不是什么空间分配不够?
