【Follow me第二季第4期】在Arduino下使用SD卡录制声音
自定任务:Arduino Nano RP2040 Connect板载的PDM麦克风实现录音功能
看到板载有麦克风为什么不试一下录制声音呢,因此想通过板载的PDM麦克风实现声音拾取,并将收集到的数据以WAV格式形式存储在SD卡中。SD卡通过SPI接口实现与主控板通讯,SPI引脚直接使用了默认引脚。
我使用的SD卡外置模块为5V供电,需要将主控板的VBUS焊盘连接上来进行供电,否则3V3无法启动。
流程顺序大体如下:
目前程序还是有点问题不知道是出在哪里,录音的长度和设定长度一致,但是播放录制的程序明显速度变快了,哪位大佬有空帮我看看问题出在哪里了,程序如下:
#include <PDM.h>
#include "wave.h"
#include <SPI.h>
#include "SdFat.h"
const int chipSelect = 10;
// default number of output channels
static const char channels = 1;
// default PCM output frequency
static const int frequency = 20000;
// Buffer to read samples into, each sample is 16-bits
short sampleBuffer[128];
const int record_time = 30; // second
const char filename[] = "/record.wav";
const int waveDataSize = record_time * 40000;
char partWavData[1024];
// Number of audio samples read
volatile int samplesRead;
FsFile file; // 录音文件
SdFs sd;
void setup() {
Serial.begin(9600);
delay(2000);
if(!sd.begin(SdSpiConfig(chipSelect, DEDICATED_SPI, SD_SCK_MHZ(16))))//初始化SD
Serial.println(F("sd init error"));
return;
sd.remove(filename);
file = sd.open(filename, O_WRITE|O_CREAT);
if(!file)
Serial.println("crate file error");
return;
// Configure the data receive callback
auto header = CreateWaveHeader(1, 20000, 16);
header.riffSize = waveDataSize + 44 - 8;
header.dataSize = waveDataSize;
file.write(&header,44);
PDM.onReceive(onPDMdata);
// Optionally set the gain
// Defaults to 20 on the BLE Sense and 24 on the Portenta Vision Shield
PDM.setGain(10);
// Initialize PDM with:
// - one channel (mono mode)
// - a 16 kHz sample rate for the Arduino Nano 33 BLE Sense
// - a 32 kHz or 64 kHz sample rate for the Arduino Portenta Vision Shield
if (!PDM.begin(channels, frequency)) {
Serial.println("Failed to start PDM!");
while (1);
else{
Serial.println("start");
int count = waveDataSize/128;
void loop() {
// Wait for samples to be read
if(count==0){
samplesRead=0;
file.close();
Serial.println("finish");
if (samplesRead) {
file.write((const byte*)sampleBuffer, 128);
count--;
// Clear the read count
samplesRead = 0;
// if (samplesRead) {
// Serial.println(samplesRead);
// samplesRead=0;
* Callback function to process the data from the PDM microphone.
* NOTE: This callback is executed as part of an ISR.
* Therefore using `Serial` to print messages inside this function isn't supported.
void onPDMdata() {
// Query the number of available bytes
int bytesAvailable = PDM.available();
// Read into the sample buffer
PDM.read(sampleBuffer, bytesAvailable);//每次64样本
// 16-bit, 2 bytes per sample
samplesRead = bytesAvailable / 2;
对应的WAVE文件内容
#include "wave.h"
WAV_HEADER CreateWaveHeader(int numChannels, //声道数
unsigned int sampleRate, //采样率
unsigned short bitsPerSample) //采样位宽
WAV_HEADER header;
header.riffSize = 0;
header.numChannels = numChannels;
header.sampleRate = sampleRate;
header.bitsPerSample = bitsPerSample;
header.bytesPerSecond = sampleRate * numChannels * bitsPerSample /8 ;
header.blockAlign = numChannels * bitsPerSample/8;
header.dataSize = 0;
return header;
效果图如下,动态效果见视频:
59820604
