63|0
94
【Follow me第二季第3期】基础任务:quad-spi flash和octo-spi flash配置及读写速... [复制链接]
在e2 studio中把工程建立起来,选择好芯片型号。
逐步生成工程文件:
quad-spi flash配置
很方便的在e2 studio中配置好QSPI FLASH,CLK也配置好
octo-spi flash配置
配置完成后点击生成配置和驱动,ospi_performance_test的源码如下,分别提供OSPI flash的读写测试结果:
 * Function Name: ospi_performance_test
 * Description  : .
 * Arguments    : data_size
 *              : ospi_performance_write_result
 *              : ospi_performance_read_result
 * Return Value : .
void ospi_performance_test(uint32_t data_size,
                            uint32_t *ospi_performance_write_result,
                            uint32_t *ospi_performance_read_result)
    fsp_err_t err;
    uint32_t i =  1;
    if (R_CGC_Open (g_cgc.p_ctrl, g_cgc.p_cfg) != FSP_SUCCESS)
        __asm("bkpt");
    while (i)
        err = R_OSPI_Open(g_ospi.p_ctrl, g_ospi.p_cfg);
        if (FSP_SUCCESS != err)
            __asm("bkpt");
#if HIGH_SPEED_MODE
        configure_dopi_ospi();
        ospi_test_wait_until_wip();
#endif
        *ospi_performance_write_result = write_dopi_ospi(data_size);
        *ospi_performance_read_result = read_dopi_ospi(data_size);
        erase_dopi_ospi();
#if HIGH_SPEED_MODE
        configure_spi_ospi();
#endif
        err = R_OSPI_Close(g_ospi.p_ctrl);
            __asm("bkpt");
        i--;
QSPI flash的写测试实现如下:
* Function Name: qspi_write_test
 * Description  : .
 * Argument     : block_size
 * Return Value : .
static uint32_t qspi_write_test(uint32_t block_size)
    fsp_err_t fsp_err;
    uint32_t qspi_write_result = 0;
    timer_status_t status = {};
    fsp_err_t err = FSP_SUCCESS;
    spi_flash_protocol_t current_spi_mode;
    /* Convert from kB */
    block_size *= 1024;
    /* The comms mode is EXTENDED_SPI by default */
    current_spi_mode = SPI_FLASH_PROTOCOL_EXTENDED_SPI;
    /* initialise the QSPI, and change mode to that set in FSP */
    err = qpi_init();
    if (FSP_SUCCESS == err)
        /* The comms mode has changed. So if recovering, this new mode required */
        current_spi_mode = g_qspi_cfg.spi_protocol;
    uint32_t page_write_count = 0;
    uint8_t  * p_mem_addr;
    /* Cast to req type */
    p_mem_addr = (uint8_t *)QSPI_DEVICE_START_ADDRESS;
    while (((page_write_count * SECTOR_SIZE) < block_size)
        && ( FSP_SUCCESS == err ) )
        /* Erase Flash for one sector */
        err = R_QSPI_Erase(&g_qspi_ctrl, p_mem_addr, SECTOR_SIZE);
            sprintf(s_print_buffer, "R_QSPI_Erase Failed\r\n");
        else
            err = get_flash_status();
                sprintf(s_print_buffer, "Failed to get status for QSPI operation\r\n");
            /* Verify the erased block data */
            uint32_t count;
            for (count = 0; count < SECTOR_SIZE; count++ )
                if (DEFAULT_MEM_VAL != p_mem_addr[count])
                    /* Verification failed, perhaps the ERASE failed */
                    err = FSP_ERR_NOT_ERASED;
        p_mem_addr += SECTOR_SIZE;
        page_write_count++;
    /* Start the test timer */
    fsp_err = R_GPT_Start(g_memory_performance.p_ctrl);
    /* Handle error */
    if (FSP_SUCCESS != fsp_err)
        /* Fatal error */
        SYSTEM_ERROR
    while (((page_write_count * PAGE_WRITE_SIZE) < block_size)
        && (FSP_SUCCESS == err))
            /* Write data to QSPI Flash */
            /* Each block begins one character shifted along the source text. To avoid regular striping in memory */
            err = R_QSPI_Write(&g_qspi_ctrl, &(sp_source[page_write_count]), p_mem_addr, PAGE_WRITE_SIZE);
                sprintf(s_print_buffer, "R_QSPI_Write Failed\r\n");
            else
        p_mem_addr += PAGE_WRITE_SIZE;
        page_write_count++;
    /* close QSPI module */
    deinit_qspi(current_spi_mode);
    fsp_err = R_GPT_Stop(g_memory_performance.p_ctrl);
    /* Handle error */
        /* Fatal error */
        SYSTEM_ERROR
    fsp_err = R_GPT_StatusGet(g_memory_performance.p_ctrl, &status);
    /* Handle error */
        /* Fatal error */
        SYSTEM_ERROR
    fsp_err = R_GPT_Reset(g_memory_performance.p_ctrl);
    /* Handle error */
        /* Fatal error */
        SYSTEM_ERROR
    qspi_write_result = status.counter;
    return (qspi_write_result);
QSPI flash的读测试代码如下:
 * Function Name: qspi_read_test
 * Description  : .
 * Return Value : .
static uint32_t qspi_read_test(uint32_t block_size)
    fsp_err_t fsp_err;
    uint32_t qspi_read_result = 0;
    uint8_t  * p_dma_read_buffer;
    uint32_t   page_read_count;
    block_size *= 1024;
    p_dma_read_buffer = pvPortMalloc(block_size);
    if (NULL == p_dma_read_buffer)
        HeapStats_t pxHeapStats;
        vPortGetHeapStats(&pxHeapStats);
        sprintf(s_print_buffer, "\r\nQSPI malloc operation Failed - Max free mem: %dbytes\r\n",
                pxHeapStats.xSizeOfLargestFreeBlockInBytes);
    /* The comms mode of the FLASH device is EXTENDED_SPI by default */
    err = qpi_init();
    /* Handle error */
        /* Fatal error */
        SYSTEM_ERROR
    page_read_count = 0;
    /* cast to req type */
    while (((page_read_count * PAGE_WRITE_SIZE) < block_size)
        /* Verify the written data */
        if ((fsp_err_t) (memcmp (p_mem_addr, &(sp_source[page_read_count]), PAGE_WRITE_SIZE)) != FSP_SUCCESS)
            sprintf(s_print_buffer, "\r\nQSPI operation Failed -> Data read does not match with written data\r\n");
        page_read_count++;
    /* Handle error */
        /* Fatal error */
        SYSTEM_ERROR
    /* Handle error */
        /* Fatal error */
        SYSTEM_ERROR
    /* Handle error */
        /* Fatal error */
        SYSTEM_ERROR
    qspi_read_result = status.counter;
    vPortFree(p_dma_read_buffer);
    return (qspi_read_result);
测试效果如下
##完成!
