539|3
7002
【STM32H7S78-DK】基于TouchGFX的可视测距仪 [复制链接]
【硬件】
1、STM32H7S78-DK
2、X-NUCLEO-53L4A3 TOF评估板
【软件环境】
1、STM32CubeMX6.12
2、X-CUBE-TOF
3、X-CUBE_TOUCHGFX
4、TouchGFX-Designer
5、MDK5.38
【实现步步骤】
1、使用TouchGFX-Designer生成基于STM32H7S78L-DK的TouchGFX工程,设计界面如下:
2、使用STM32CubeMX打开工程,配置X-CBUE-TOF如下:
3、生成MDK工程,由于TouchGFX已经打开了I2C1,并且53L4A3也是使用I2C1所以无需重新配置。
4、打开MDK工程,可以看到STM32CubeMX已经给生成了53L4A3的工程文件:
【用户代码实现】
1、我们添加app_tof.h/c,来实现对53L4A3的初始化以及读取任务。
app_tof.c内存如下:
  * [url=home.php?mod=space&uid=1307177]@File[/url]           : app_tof.c
  * [url=home.php?mod=space&uid=1315547]@author[/url]         : IMG SW Application Team
  * [url=home.php?mod=space&uid=159083]@brief[/url]          : This file provides code for the configuration
  *                  of the STMicroelectronics.X-CUBE-TOF1.3.4.2 instances.
  * [url=home.php?mod=space&uid=1020061]@attention[/url] *
  * Copyright (c) 2023 STMicroelectronics.
  * All rights reserved.
  * This software is licensed under terms that can be found in the LICENSE file
  * in the root directory of this software component.
  * If no LICENSE file comes with this software, it is provided AS-IS.
#ifdef __cplusplus
extern "C" {
#endif
/* Includes ------------------------------------------------------------------*/
#include "app_tof.h"
#include "main.h"
#include <stdio.h>
#include "cmsis_os2.h"
#include "53l4a3_ranging_sensor.h"
#define TIMING_BUDGET (100U) /* 10 ms < TimingBudget < 200 ms */
#define POLLING_PERIOD (250U) /* refresh rate for polling mode (ms, shall be consistent with TimingBudget value) */
/* Private variables ---------------------------------------------------------*/
static RANGING_SENSOR_Capabilities_t Cap;
static RANGING_SENSOR_ProfileConfig_t Profile;
static int32_t status = 0;
volatile uint8_t ToF_EventDetected = 0;
/* Private function prototypes -----------------------------------------------*/
static void MX_53L4A3_SimpleRanging_Init(void);
static void MX_53L4A3_SimpleRanging_Process(void);
static void print_result(RANGING_SENSOR_Result_t *Result);
static int32_t decimal_part(float_t x);
void MX_TOF_Init(void)
  /* USER CODE BEGIN SV */
  /* USER CODE END SV */
  /* USER CODE BEGIN TOF_Init_PreTreatment */
  /* USER CODE END TOF_Init_PreTreatment */
  /* Initialize the peripherals and the TOF components */
  MX_53L4A3_SimpleRanging_Init();
  /* USER CODE BEGIN TOF_Init_PostTreatment */
  /* USER CODE END TOF_Init_PostTreatment */
  /* reset XSHUT (XSDN) pin */
  HAL_GPIO_WritePin(VL53L4A3_XSHUT_C_PORT, VL53L4A3_XSHUT_C_PIN, GPIO_PIN_RESET);
  HAL_Delay(2);
  HAL_GPIO_WritePin(VL53L4A3_XSHUT_C_PORT, VL53L4A3_XSHUT_C_PIN, GPIO_PIN_SET);
  HAL_Delay(2);
  printf("53L4A3 Simple Ranging demo application\n");
  status = VL53L4A3_RANGING_SENSOR_Init(VL53L4A3_DEV_CENTER);
  if (status != BSP_ERROR_NONE)
    printf("VL53L4A3_RANGING_SENSOR_Init failed\n");
    while (1);
 * LM background task
void MX_TOF_Process(void)
  /* USER CODE BEGIN TOF_Process_PreTreatment */
  /* USER CODE END TOF_Process_PreTreatment */
  MX_53L4A3_SimpleRanging_Process();
  /* USER CODE BEGIN TOF_Process_PostTreatment */
  /* USER CODE END TOF_Process_PostTreatment */
  uint8_t i;
  uint32_t cal_distance_mm = 0; /* target distance used for offset calibration */
  uint32_t Id;
  RANGING_SENSOR_Result_t Result;
  VL53L4A3_RANGING_SENSOR_ReadID(VL53L4A3_DEV_CENTER, &Id);
  VL53L4A3_RANGING_SENSOR_GetCapabilities(VL53L4A3_DEV_CENTER, &Cap);
  Profile.RangingProfile = VL53L4ED_PROFILE_CONTINUOUS;
  Profile.TimingBudget = TIMING_BUDGET;
  Profile.Frequency = 0; /* Induces intermeasurement period, NOT USED for normal ranging */
  Profile.EnableAmbient = 1; /* Enable: 1, Disable: 0 */
  Profile.EnableSignal = 1; /* Enable: 1, Disable: 0 */
  /* set the profile if different from default one */
  VL53L4A3_RANGING_SENSOR_ConfigProfile(VL53L4A3_DEV_CENTER, &Profile);
  printf("--- BEGIN OFFSET CALIBRATION ---\n");
  /* make sure that a target is placed at cal_distance_mm (100 mm is the default value in this example)
   * the application will perform some measure in order to have a log of some pre-calibration values
  status = VL53L4A3_RANGING_SENSOR_Start(VL53L4A3_DEV_CENTER, RS_MODE_BLOCKING_CONTINUOUS);
	printf("--- Start testing ---\n");
  while (1)
    /* interrupt mode */
      status = VL53L4A3_RANGING_SENSOR_GetDistance(VL53L4A3_DEV_CENTER, &Result);
      if (status == BSP_ERROR_NONE)
        print_result(&Result);
		osDelay(100);
  uint8_t i;
  uint8_t j;
  for (i = 0; i < RANGING_SENSOR_MAX_NB_ZONES; i++)
    printf("\nTargets = %lu", (unsigned long)Result->ZoneResult[i].NumberOfTargets);
    for (j = 0; j < Result->ZoneResult[i].NumberOfTargets; j++)
      printf("\n |---> ");
      printf("Status = %ld, Distance = %5ld mm ",
             (long)Result->ZoneResult[i].Status[j],
             (long)Result->ZoneResult[i].Distance[j]);
      if (Profile.EnableAmbient)
        printf(", Ambient = %ld.%02ld kcps/spad",
               (long)Result->ZoneResult[i].Ambient[j],
               (long)decimal_part(Result->ZoneResult[i].Ambient[j]));
      if (Profile.EnableSignal)
        printf(", Signal = %ld.%02ld kcps/spad",
               (long)Result->ZoneResult[i].Signal[j],
               (long)decimal_part(Result->ZoneResult[i].Signal[j]));
  printf("\n");
  int32_t int_part = (int32_t) x;
  return (int32_t)((x - int_part) * 100);
#ifdef __cplusplus
#endif
同时添加app_tof.h声明两个函数,用个Inint与任务
#ifndef __APP_TOF_H
#define __APP_TOF_H
#ifdef __cplusplus
extern "C" {
#endif
/* Exported defines ----------------------------------------------------------*/
/* Exported functions --------------------------------------------------------*/
void MX_TOF_Init(void);
void MX_TOF_Process(void);
#ifdef __cplusplus
#endif
#endif /* __APP_TOF_H */
3、在freertos的任务中执行初始化,并运行检测任务。
void StartDefaultTask(void *argument)
  /* USER CODE BEGIN StartDefaultTask */
  /* Infinite loop */
	MX_TOF_Init();
	MX_TOF_Process();
  for(;;)
    osDelay(1);
  /* USER CODE END StartDefaultTask */
使用串口助手,可以看到可以打印出测距信息:
4、为了在tochGFX中显示,我们在app_tof.c中添加一个函数,用于与TouchGFX的数据交换。
int get_distance(long * value)
		*value = (long)Result.ZoneResult[0].Distance[0];
		return 0;
	return -1;
5、在ScreenView.hpp中添加handleTickEvent函数。
并在Screen1view.cpp中实现:
void Screen1View::handleTickEvent()
	static int tick;
	tick ++;
	long value;
	int ret;
	if( 0 == (tick%20))
		ret = get_distance(&value);
		if(0 == ret)
			Unicode::snprintf(textArea3Buffer,TEXTAREA3_SIZE,"%d",value);
			textArea3.invalidate();
烧录后,可以成功的实现测距:
  【总结】
使用TouchGFX+X-CBUE-Tof可以快速的实现一个可视化的测距工具。
此帖出自stm32/stm8论坛
53L8应该是多点的,那就可以跟热成像是的高边缘锐化了    详情 回复 发表于 2024-11-2 23:34
6509
你这不错,正好可以连个活动结合,不过53L4A3是几点检测?
此帖出自stm32/stm8论坛
不过53L4A3是几点检测?只有一个点,我原来以为有4*4,8*8的,后来查了一下,只有一个。  详情 回复 发表于 2024-11-2 23:22
在爱好的道路上不断前进,在生活的迷雾中播撒光引
7002
秦天qintian0303 发表于 2024-11-2 23:10 你这不错,正好可以连个活动结合,不过53L4A3是几点检测?
此帖出自stm32/stm8论坛
6509
lugl4313820 发表于 2024-11-2 23:22 不过53L4A3是几点检测?只有一个点,我原来以为有4*4,8*8的,后来查了一下,只有一个。
此帖出自stm32/stm8论坛
