457|3
365
一起读《动手学深度学习(PyTorch版)》- 多项式回归:欠拟合、过拟合 [复制链接]
邀请:@tagetage   @littleshrimp   @okhxyyo   @freebsder   参与回复
多项式回归
这样可以避免很大的 x^i 带来的特别大的指数值,变成 x^i / i !,也就是x的i次幂 / i的阶乘,如下图可以对比
import matplotlib.pyplot as plt
import math
num = 3
x = range(0, 1000)
y = []
y1 = []
for i in x:
    y.append(i**num)
    y1.append((i**num)/math.factorial(num))
plt.plot(x, y)
plt.plot(x, y1)
plt.show()
3阶多项式拟合
100个训练样本,100和验证样本
设定多项式的权重,3阶多项式,有4个权重值,经过400次训练
import torch
import torchvision
from torch.utils import data
from torchvision import transforms
from torch import nn
import numpy as np
import math
def get_dataloader_workers():
    return 6
def accurancy(y_hat, y):
    if len(y_hat.shape) > 1 and y_hat.shape[1] > 1:
        y_hat = y_hat.argmax(axis=1)
    # cmp is a dict which restore true or false
    cmp = y_hat.type(y.dtype) == y
    # calc the num of true
    return float(cmp.type(y.dtype).sum())
class Accumulator:
    def __init__(self, n) -> None:
        self.data = [0.0]*n
    def add(self, *args):
        # args is a tupe
        self.data = [a + float(b) for a, b in zip(self.data, args)]
    def reset(self):
        self.data = [0.0] * len(self.data)
    def __getitem__(self, idx):
        return self.data[idx]
def evaluate_accurancy(net, data_iter):
    if isinstance(net, torch.nn.Module):
        net.eval()
    metric = Accumulator(2)
    with torch.no_grad():
        for X, y in data_iter:
            metric.add(accurancy(net(X), y), y.numel())
    return metric[0] / metric[1]
def train_epoch_ch3(net, train_iter, loss, updater):
        print("is instance nn.Module")
        net.train()
    metric = Accumulator(3)
    for X, y in train_iter:
        y_hat = net(X)
        # print(y, y_hat)
        l = loss(y_hat, y)
        if isinstance(updater, torch.optim.Optimizer):
            updater.zero_grad()
            l.mean().backward()
            updater.step()
        else:
            l.sum().backward()
            updater(X.shape[0])
        metric.add(float(l.sum()), accurancy(y_hat, y), y.numel())
    #     print(metric[0] , metric[1], metric[2])
    # print("", metric[0] , metric[1], metric[2])
    # return metric[0] / metric[1], metric[1] / metric[2]
def set_axes(axes, xlable, ylable, xlim, ylim, xscale, yscale, legend):
    axes.set_xlabel(xlable)
    axes.set_ylabel(ylable)
    axes.set_xscale(xscale)
    axes.set_yscale(yscale)
    axes.set_xlim(xlim)
    axes.set_ylim(ylim)
    if legend:
        axes.legend(legend)
        axes.grid()
class Animator:
    def __init__(self, xlable=None, ylable=None, legend=None, xlim=None, ylim=None,
    xscale='linear', yscale='linear',fmts=('-','m--','g-.','r:'), nrows=1, ncols=1, figsize=(3.5, 2.5)):
        if legend is None:
            legend = []
        self.fig, self.axes = plt.subplots(nrows, ncols, figsize=figsize)
        if nrows * ncols == 1:
            self.axes = [self.axes, ]
        self.config_axes = lambda: set_axes(self.axes[0], xlable, ylable, xlim, ylim, xscale, yscale, legend)
        self.X, self.Y, self.fmts = None, None, fmts
    def add(self, x, y):
        if not hasattr(y, "__len__"):
            y=[y]
        n = len(y)
        if not hasattr(x, "__len__"):
            x = [x] * n
        if not self.X:
            self.X = [[] for _ in range(n)]
        if not self.Y:
            self.Y = [[] for _ in range(n)]
        for i, (a,b) in enumerate(zip(x, y)):
            if a is not None and b is not None:
                self.X[i].append(a)
                self.Y[i].append(b)
        self.axes[0].cla()
        for x, y, fmt in zip(self.X, self.Y, self.fmts):
            self.axes[0].plot(x, y, fmt)
        self.config_axes()
def load_array(data_arrays, batch_size, is_train=True):  #@save   dataset = data.TensorDataset(*data_arrays)
    return data.DataLoader(dataset, batch_size, shuffle=is_train, num_workers=get_dataloader_workers())
max_degree = 20  # 20 power
n_train, n_test = 100, 100
true_w = np.zeros(max_degree)
true_w[0:4] = np.array([5, 1.2, -3.4, 5.6])
features = np.random.normal(size=(n_train + n_test, 1))
np.random.shuffle(features)
poly_features = np.power(features, np.arange(max_degree).reshape(1, -1))
for i in range(max_degree):
    poly_features[:, i] /= math.gamma(i + 1)  # gamma(n)=(n-1)!
labels = np.dot(poly_features, true_w)
labels += np.random.normal(scale=0.1, size=labels.shape)
true_w, features, poly_features, labels = [torch.tensor(x, dtype=
    torch.float32) for x in [true_w, features, poly_features, labels]]
# print(features[:2], poly_features[:2, :], labels[:2])
def evaluate_loss(net, data_iter, loss):
        out = net(X)
        y = y.reshape(out.shape)
        l = loss(out, y)
        metric.add(l.sum(), l.numel())
def train(train_features, test_features, train_labels, test_labels,
          num_epochs=400):
    loss = nn.MSELoss(reduction='none')
    input_shape = train_features.shape[-1]
    net = nn.Sequential(nn.Linear(input_shape, 1, bias=False))
    batch_size = min(10, train_labels.shape[0])
    train_iter = load_array((train_features, train_labels.reshape(-1,1)),
                                batch_size)
    test_iter = load_array((test_features, test_labels.reshape(-1,1)),
                               batch_size, is_train=False)
    trainer = torch.optim.SGD(net.parameters(), lr=0.01)
    animator = Animator(xlable='epoch', ylable='loss', yscale='log',
                            xlim=[1, num_epochs], ylim=[1e-3, 1e2],
                            legend=['train', 'test'])
    for epoch in range(num_epochs):
        train_epoch_ch3(net, train_iter, loss, trainer)
        if epoch == 0 or (epoch + 1) % 20 == 0:
            animator.add(epoch + 1, (evaluate_loss(net, train_iter, loss),
                                     evaluate_loss(net, test_iter, loss)))
    print('weight:', net[0].weight.data.numpy())
train(poly_features[:n_train, :4], poly_features[n_train:, :4],
      labels[:n_train], labels[n_train:])
plt.show()
可以看到权重值也就是多项式系数和最初设定的系数基本相同,loss也逐渐变小
线性函数,欠拟合
原因:由四个系数构成的20阶多项式,当训练系数只有2个时,不太可能表达出4个的效果,再增加数量或者训练次数,都不能减少损失
train(poly_features[:n_train, :2], poly_features[n_train:, :2],
高阶多项式,过拟合
3阶以上的系数未指定,本身应该时0值,但因为添加了噪声,没有明显的规律,所以训练结果很好,但面对随机的噪声怎么可能预估的出来
train(poly_features[:n_train, :], poly_features[n_train:, :],
      labels[:n_train], labels[n_train:], num_epochs=1000)
随机噪声可能需要估计噪声分布,白噪声还是高斯噪声,可以先处理一下。虽然现在深度学习网络很强大,但是必要的前处理还是可以有的。   详情 回复 发表于 2024-10-29 15:25
77
谢谢楼主的分享,《动手学深度学习(PyTorch版)》,已下载第二版拜读了。
7671
这个是真实噪声,消除就意味失真  详情 回复 发表于 2024-10-29 21:28
默认摸鱼,再摸鱼。2022、9、28
365
freebsder 发表于 2024-10-29 15:25 随机噪声可能需要估计噪声分布,白噪声还是高斯噪声,可以先处理一下。虽然现在深度学习网络很强大,但是必 ...
这个是真实噪声,消除就意味失真
