189|0
工业级无线通信5合1模块,NB-IOT,WIFI,LORA,Bluetooth,4G [复制链接]
Multi network connectivity:
Bluetooth LE 5.0
Wi Fi 802.11b/g/n (2.4GHz)
Semtech LoRa (WAN) 868MHz/915MHz
Cellular LTE CAT M1/NB1/NB2
Powerful Espressif ESP32 S3 MCU
MicroPython programmable with 27 IOs on module pads
SMT friendly semi hole pins at module edges
Compact for functionality: 40mm x 16mm x 2.7mm
