【Follow me第二季第2期】进阶任务+扩展任务二 之 将SHT40数据通过MQTT传输到HA平台
任务总览
- 获取SHT40的温湿度数据
- 搭建HomeAssistant平台
- 将设备接入到HomeAssistant平台
1.获取SHT40的温湿度数据
先使用官方例程测试一下SHT40传感器
- #include <Wire.h>
- #include "Adafruit_SHT4x.h"
- #define SDA_PIN 27
- #define SCL_PIN 26
- Adafruit_SHT4x sht4 = Adafruit_SHT4x();
- void setup() {
- Serial.begin(115200);
- while (!Serial)
- delay(10);
- TwoWire i2cWire = TwoWire(SCL_PIN, SDA_PIN);
- Serial.println("Adafruit SHT4x test");
- if (! sht4.begin(&i2cWire)) {
- Serial.println("Couldn't find SHT4x");
- while (1) delay(1);
- Serial.println("Found SHT4x sensor");
- Serial.print("Serial number 0x");
- Serial.println(sht4.readSerial(), HEX);
- sht4.setPrecision(SHT4X_HIGH_PRECISION);
- switch (sht4.getPrecision()) {
- case SHT4X_HIGH_PRECISION:
- Serial.println("High precision");
- break;
- case SHT4X_MED_PRECISION:
- Serial.println("Med precision");
- break;
- case SHT4X_LOW_PRECISION:
- Serial.println("Low precision");
- break;
- sht4.setHeater(SHT4X_NO_HEATER);
- switch (sht4.getHeater()) {
- case SHT4X_NO_HEATER:
- Serial.println("No heater");
- break;
- case SHT4X_HIGH_HEATER_1S:
- Serial.println("High heat for 1 second");
- break;
- case SHT4X_HIGH_HEATER_100MS:
- Serial.println("High heat for 0.1 second");
- break;
- case SHT4X_MED_HEATER_1S:
- Serial.println("Medium heat for 1 second");
- break;
- case SHT4X_MED_HEATER_100MS:
- Serial.println("Medium heat for 0.1 second");
- break;
- case SHT4X_LOW_HEATER_1S:
- Serial.println("Low heat for 1 second");
- break;
- case SHT4X_LOW_HEATER_100MS:
- Serial.println("Low heat for 0.1 second");
- break;
- void loop() {
- sensors_event_t humidity, temp;
- uint32_t timestamp = millis();
- sht4.getEvent(&humidity, &temp);
- timestamp = millis() - timestamp;
- Serial.print("Temperature: "); Serial.print(temp.temperature); Serial.println(" degrees C");
- Serial.print("Humidity: "); Serial.print(humidity.relative_humidity); Serial.println("% rH");
- Serial.print("Read duration (ms): ");
- Serial.println(timestamp);
- delay(1000);
串口打印出来的数据:
- Adafruit SHT4x test
- Found SHT4x sensor
- Serial number 0x10C60BD0
- High precision
- No heater
- Temperature: 30.67 degrees C
- Humidity: 70.80% rH
- Read duration (ms): 11
2. 搭建HomeAssistant平台
1. SD卡格式化
推荐使用SDFormatter(内存卡修复工具),经常在Linux和Windwos下使用的SD卡通常会有着不同的分区,在不能操作系统下识别出来的可能都不太一样,因此为了保险起见可以先格式化一下,若没有问题的可以跳过这一步
2. SD卡烧写镜像工具
推荐使用balenaEtcher,这是一个开源的、跨平台的工具,用于将操作系统镜像文件(如 ISO 和 IMG 文件)烧录到 SD 卡和 USB 驱动器中,支持的格式非常的多
选择镜像文件。我是用的是树莓派4,因此选择的是haos_rpi4-64-6.4.img.xz,大家根据自己的设备在附件中选择对应的型号即可。
选择SD卡、U盘等设备
Flash!等待烧写完成
3. 上电!配置树莓派
插入烧写好的镜像SD卡到树莓派
接网线到路由器
将电脑通过WiFi或者网线接入到上面树莓派接入的路由器
接HDMI到显示屏等能够显示的设备(有条件的最后接上,没有问题也不是很大)
上电!
若插上HDMI,稍稍稍微的登上那么一段时间,等待系统启动完成就可以看到这个界面了,若没有显示屏,不要捉急,在网站上输入 等待网页显示。若成功启动了,恭喜你完成了第一步!!!
能成功进入网站上,会显示这个界面准备,我一开始信了这个鬼(这最多可能需要20分钟),结果等了一个多小时都没有进去……
第二天起来看到已经到了Home Assistant 的欢迎界面,按照步骤一步步下去就可以了
点击FINISH之后,恭喜你现在已经启动并运行了 Home Assistant!!!
HA配置
SSH安装
设置
加载项
加载项商店
搜索ssh
安装后
成功安装的界面:
Samba 安装
设置
加载项
加载项商店
搜索Samba
安装
配置:用户名和密码
使用:
Win+R
输出\ip,例如 ,这个ip就是上面ssh中查到的ip地址
就可以跟使用文件夹一样,对树莓派里面的文件进行操作了
安装MQTT
设置
加载项
加载项商店
搜索MQTT
设置-》设备于服务-》打开MQTT-》配置,就可以了以下界面,进行配置ip,用户名、密码等信息,记住这些信息哟
添加设备,使用的软件是MQTTx,发送下面数据,湿度同理
"name": "SHT40 Humidity",
"state_topic": "homeassistant/sensor/sht40_humidity/state",
"unit_of_measurement": "%rH",
"device_class": "temperature",
"json_attributes_topic": "homeassistant/sensor/sht40_humidity/attributes",
"unique_id": "sht40_humidity",
"device": {
"identifiers": ["sht40"],
"name": "SHT40 Sensor",
"model": "SHT40",
"manufacturer": "SHT"
就可以看到添加的设备了
代码和效果展示
鎾斁鍣ㄥ姞杞藉け璐�: 鏈娴嬪埌Flash Player锛岃鍒� 瀹夎
HomeAssistant
