487|4
请问这款规格书对应的编程器知道吗 [复制链接]
型号是L9924L,不知道哪款编程器可以调试,求告知
此帖出自汽车电子论坛
看看是什么内核呗,如果是ARM,是不是JLink就行   详情 回复 发表于 2024-9-12 16:10
感谢分享,很有用处。谢谢
此帖出自汽车电子论坛
3248
The L9924L is a controlled multifunctional alternator regulator intended to be used in cars, commercial and agricultural vehicles, with support for 12 V and 24 V systems. The control can be achieved through different communication protocols: LIN, RCV, PCM, C_term, BSS. It is a System-In-Package solution with smart power alternator regulator IC coupled with a 8-bit microcontroller (non-monolithic approach). It includes the control section, fault diagnostic circuit which drives a warning lamp, and the protection against short circuits. This device regulates in closed loop the output of an automotive generator by controlling the field winding current by means of a Pulse-Width Modulation (PWM) of an external high side or low side driver at fixed frequency.
个人弄不了这个,有编程器你也你编不了。
此帖出自汽车电子论坛
tagetage 发表于 2024-9-12 13:45 The L9924L is a controlled multifunctional alternator regulator intended to be used in cars, commerc ...
帮客户找的,只要提供编程器即可,有合适的编程器吗
此帖出自汽车电子论坛
7294
此帖出自汽车电子论坛
