2733|0
mini2440 ov9650 wince6.0 应用程序 采集图像花屏!!~~~~求高手解答 [复制链接]
int rc = 0;
     HANDLE hCam = CreateFile (TEXT("CIS1:"), GENERIC_WRITE | GENERIC_READ,
         0, NULL, OPEN_EXISTING, 0, NULL); //打开设备句柄
    if (hCam == INVALID_HANDLE_VALUE)
  rc = GetLastError();
  printf ("can't open file rc = %d\r\n", rc);
  AfxMessageBox(_T("无法打开设备!请检查设备是否已被占用。"));
       WORD width=GetSystemMetrics(SM_CXSCREEN);
       WORD height=GetSystemMetrics(SM_CYSCREEN);//屏幕尺寸
       BYTE* DDBdata=new BYTE[width*height*2];//分配用于存数据的空间
    BOOL ret;
       PINGPONG_PR image; //定义结构体用于存RGB图像地址;
     ret = DeviceIoControl(hCam,IOCTL_CAM_GETINFO,NULL,NULL,(PBYTE)&image,NULL,NULL,NULL);  //启动预览功能
    if(!ret)
    AfxMessageBox(_T("启动预览失败!"));
       //SetKMode(TRUE);
     memcpy(DDBdata,(void *)image.rgb_address,width*height*2);
     //SetKMode(FALSE);
       CDC* pDC ;
       pDC= new CClientDC(this);//简单的为图画刷
    CBitmap bitmap1;
    //bitmap1.LoadOEMBitmap(IDB_DAN);
    bitmap1.CreateBitmap(240,320,1,16,DDBdata);
    CBrush brush1;
    brush1.CreatePatternBrush(&bitmap1);
       pDC->SelectObject(&brush1);
       pDC->Rectangle (0,0,240,320);
       delete []DDBdata;
关键是memcpy(DDBdata,(void *)image.rgb_address,width*height*2);不能顺利的取到数据!!!
SetKMode(TRUE); 这个在wince6.0中不能使用。
那应该怎样处理这个问题呢?
谢谢
qq:274571716
