2645|5
64
【100分】WQ28008D19,屏见过的速进。马上给分。 [复制链接]
WQ28008D19屏
两个事情
1.求一个屏手册 50分
2.确认下WQ28008D19的屏驱动IC型号。50分
速度给
自己搞定了 void LCD_Ini(void) {     Write_Cmd(0x0600,0x0001);        Delay(110);     Write_Cmd(0x0600,0x0000);     Delay(110);     Write_Cmd(0x0001,0x0100);         Write_Cmd(0x0002,0x0100);         Write_Cmd(0x0003,0x1030);         Write_Cmd(0x0006,0x0000);         Write_Cmd(0x0008,0x0202);         Write_Cmd(0x0009,0x0001);         Write_Cmd(0x000B,0x0010);         Write_Cmd(0x000C,0x0000);         Write_Cmd(0x000F,0x0000);         Write_Cmd(0x0010,0x0010);         Write_Cmd(0x0011,0x0101);           Write_Cmd(0x0012,0x0307);         Write_Cmd(0x0400,0x3100);         Write_Cmd(0x0300,0x0706);         Write_Cmd(0x0301,0x0103);         Write_Cmd(0x0302,0x0001);         Write_Cmd(0x0303,0x0300);         Write_Cmd(0x0304,0x0000);         Write_Cmd(0x0305,0x0002);         Write_Cmd(0x0306,0x0010);                 Write_Cmd(0x0307,0x0706);         Write_Cmd(0x0308,0x0103);         Write_Cmd(0x0309,0x0001);         Write_Cmd(0x030A,0x0300);         Write_Cmd(0x030B,0x0000);         Write_Cmd(0x030C,0x0002);         Write_Cmd(0x030D,0x0010);                 Write_Cmd(0x0210,0x0000);         Write_Cmd(0x0211,0x00EF);         Write_Cmd(0x0212,0x0000);         Write_Cmd(0x0213,0x018F); // --------------power ctrl-----------------         Write_Cmd(0x0007,0x0001);         Write_Cmd(0x0110,0x0001);         Write_Cmd(0x0112,0x0060);         Write_Cmd(0x0100,0x17B0);         Delay(100);         Write_Cmd(0x0101,0x0006);         Delay(100);         Write_Cmd(0x0102,0x0118);           Write_Cmd(0x0103,0x3600);           Write_Cmd(0x0282,0x0000);            Delay(100);         Write_Cmd(0x0281,0x0006);           Write_Cmd(0x0110,0x0001);         Delay(10);         Write_Cmd(0x0102,0x0138);           Delay(100);         Write_Cmd(0x0007,0x0021);         Delay(100);         Write_Cmd(0x0100,0x17B0);         Write_Cmd(0x0101,0x0007);         Write_Cmd(0x0007,0x0061);         Delay(300);         Write_Cmd(0x0007,0x0173);         Delay(100); //-------------power ctrl end--------------- } 复制代码 R61509a reasan  详情 回复 发表于 2009-11-5 12:25
帮你顶了,我没有屏手册
主控应该是:RK2705
引用 1 楼 lgy198612 的回复:
帮你顶了,我没有屏手册
主控应该是:RK2705
不是。。。是R61509.....哎。刚找到了。。。
不过如果有AN的话最好了
62
AN网上应该有的吧?
65
没有
自己搞定了
  1. void LCD_Ini(void)
  2. {
  3.     Write_Cmd(0x0600,0x0001);
  4.     Delay(110);
  5.     Write_Cmd(0x0600,0x0000);
  6.     Delay(110);
  7.     Write_Cmd(0x0001,0x0100);
  8.         Write_Cmd(0x0002,0x0100);
  9.         Write_Cmd(0x0003,0x1030);
  10.         Write_Cmd(0x0006,0x0000);
  11.         Write_Cmd(0x0008,0x0202);
  12.         Write_Cmd(0x0009,0x0001);
  13.         Write_Cmd(0x000B,0x0010);
  14.         Write_Cmd(0x000C,0x0000);
  15.         Write_Cmd(0x000F,0x0000);
  16.         Write_Cmd(0x0010,0x0010);
  17.         Write_Cmd(0x0011,0x0101);
  18.         Write_Cmd(0x0012,0x0307);
  19.         Write_Cmd(0x0400,0x3100);
  20.         Write_Cmd(0x0300,0x0706);
  21.         Write_Cmd(0x0301,0x0103);
  22.         Write_Cmd(0x0302,0x0001);
  23.         Write_Cmd(0x0303,0x0300);
  24.         Write_Cmd(0x0304,0x0000);
  25.         Write_Cmd(0x0305,0x0002);
  26.         Write_Cmd(0x0306,0x0010);
  27.
  28.         Write_Cmd(0x0307,0x0706);
  29.         Write_Cmd(0x0308,0x0103);
  30.         Write_Cmd(0x0309,0x0001);
  31.         Write_Cmd(0x030A,0x0300);
  32.         Write_Cmd(0x030B,0x0000);
  33.         Write_Cmd(0x030C,0x0002);
  34.         Write_Cmd(0x030D,0x0010);
  35.
  36.         Write_Cmd(0x0210,0x0000);
  37.         Write_Cmd(0x0211,0x00EF);
  38.         Write_Cmd(0x0212,0x0000);
  39.         Write_Cmd(0x0213,0x018F);
  40. // --------------power ctrl-----------------
  41.         Write_Cmd(0x0007,0x0001);
  42.         Write_Cmd(0x0110,0x0001);
  43.         Write_Cmd(0x0112,0x0060);
  44.         Write_Cmd(0x0100,0x17B0);
  45.         Delay(100);
  46.         Write_Cmd(0x0101,0x0006);
  47.         Delay(100);
  48.         Write_Cmd(0x0102,0x0118);
  49.         Write_Cmd(0x0103,0x3600);
  50.         Write_Cmd(0x0282,0x0000);
  51.         Delay(100);
  52.         Write_Cmd(0x0281,0x0006);
  53.         Write_Cmd(0x0110,0x0001);
  54.         Delay(10);
  55.         Write_Cmd(0x0102,0x0138);
  56.         Delay(100);
  57.         Write_Cmd(0x0007,0x0021);
  58.         Delay(100);
  59.         Write_Cmd(0x0100,0x17B0);
  60.         Write_Cmd(0x0101,0x0007);
  61.         Write_Cmd(0x0007,0x0061);
  62.         Delay(300);
  63.         Write_Cmd(0x0007,0x0173);
  64.         Delay(100);
  65. //-------------power ctrl end---------------
  66. }
复制代码
R61509a reasan
