429|2
510
【匠芯创D133CBS】--4.PWM驱动蜂鸣器 [复制链接]
      本篇讲述PWM驱动板载蜂鸣器使用不同占空比鸣叫。
一.硬件原理
      开发板蜂鸣器原理如下,这里使用到PWM1配置引脚,需4KHz PWM驱动。
图1:蜂鸣器原理
二.代码准备
1.命令scons --menuconfig配置使能PWM驱动选项,否则出现编译不过问题
2.PWM初始化。这里配置为脉冲周期4KHz,x需将宏定义参数设定为250000,在驱动函数里会用到。
#define LED_PIN             "PD.0"
#define KEY_PIN             "PD.15"
#define BUZZER_PIN          "PE.11"
#define BUZZER_PWM_CH       1
#define BUZZER_FREQ_PARAM   250000
void app_data_init(void)
    memset(&msg_control_t,0,sizeof(msg_control));
void app_key_init(void)
    // 1.get pin number
    static u32 pin = 0;
    pin = rt_pin_get(KEY_PIN);
    printf("Key pin%d\n",pin);
    // 2.set pin mode to Input-PullUp
    rt_pin_mode(pin, PIN_MODE_INPUT_PULLUP);
    // 3.attach irq handler
    rt_pin_attach_irq(pin, PIN_IRQ_MODE_RISING,key_irq_handler, &pin);//PIN_IRQ_MODE_RISING_FALLING
    // 4.enable pin irq
    rt_pin_irq_enable(pin, PIN_IRQ_ENABLE);
    rt_kprintf("%s\r\n",__func__);
void app_led_init(void)
    // 1.get pin number
    static u32 pin = 0;
    pin = rt_pin_get(LED_PIN);
    printf("Led pin%d\n",pin);
    // 2.set pin mode to Output
    rt_pin_mode(pin, PIN_MODE_OUTPUT);
void app_pwm_init(void)
    struct aic_pwm_action action0 = {
        /*       CBD,          CBU,          CAD, */
        PWM_ACT_NONE, PWM_ACT_NONE, PWM_ACT_NONE,
        /*      CAU,           PRD,         ZRO  */
        PWM_ACT_LOW,  PWM_ACT_NONE, PWM_ACT_HIGH};
    struct aic_pwm_action action1 = {
        PWM_ACT_NONE, PWM_ACT_LOW, PWM_ACT_NONE,
        /*      CAU,           PRD,         ZRO  */
        PWM_ACT_NONE, PWM_ACT_NONE,  PWM_ACT_HIGH};
    hal_pwm_init();
    hal_pwm_ch_init(BUZZER_PWM_CH, PWM_MODE_UP_COUNT, 0, &action0, &action1);
    hal_pwm_enable(BUZZER_PWM_CH);
    //Freq:4KHz
    // hal_pwm_set(BUZZER_PWM_CH, 0, BUZZER_FREQ_PARAM,PWM_SET_CMPA_CMPB);
void app_peripheral_init(void)
    app_data_init();
    app_key_init();
    app_led_init();
    app_pwm_init();
3.创建消息队列与任务,在按键中断回调里发送消息队列(如前一篇所述),每次控制蜂鸣器的PWM增加10%占空比。在接收消息队列任务里实现蜂鸣器PWM不同占空比控制驱动
typedef struct
    uint16_t    msg_len;
    uint8_t     led_value;
    uint8_t     buzzer_pwm_percent;
}msg_control;
static void key_irq_handler(void *args)
    unsigned int ret;
    u32 pin = *((u32 *)(args));
    printf("Key INT\r\n");
    msg_control_t.msg_len=sizeof(msg_control_t);
    msg_control_t.led_value=!msg_control_t.led_value;
    msg_control_t.buzzer_pwm_percent+=10;
    if(msg_control_t.buzzer_pwm_percent>100)
        msg_control_t.buzzer_pwm_percent=0;
    app_msg_send(&msg_control_t,sizeof(msg_control_t));
void app_thread_entry(void *parameter)
    int pin;
    msg_control msg_control_p;
    while(1)
        if(rt_mq_recv(&user_mq, &msg_control_p, sizeof(msg_control_p), RT_WAITING_FOREVER)==RT_EOK)
            rt_kprintf("Receive msg quene\r\n");
            rt_kprintf("msg_len:%d,led_value:%d,buzzer_pwm_percent:%d%%\r\n",\
                    msg_control_p.msg_len,msg_control_p.led_value,msg_control_p.buzzer_pwm_percent);
            rt_pin_write(pin, msg_control_p.led_value);
            hal_pwm_set(BUZZER_PWM_CH, msg_control_p.buzzer_pwm_percent*BUZZER_FREQ_PARAM/100, BUZZER_FREQ_PARAM,PWM_SET_CMPA_CMPB);
三.测验
      编译烧录,可以观察听到蜂鸣器不同鸣叫,在占空比0%和100%时,蜂鸣器是不鸣叫的,视频如下。串口日志如下
图2:蜂鸣器控制串口日志
      至此,实现驱动蜂鸣器功能。
Buzzer
 开发板蜂鸣器是有源的还是无源的  ?   详情 回复 发表于 2024-8-17 19:28
保持热爱
6483
 开发板蜂鸣器是有源的还是无源的  ?
无源  详情 回复 发表于 2024-8-17 19:46
在爱好的道路上不断前进,在生活的迷雾中播撒光引
510
秦天qintian0303 发表于 2024-8-17 19:28  开发板蜂鸣器是有源的还是无源的  ?
无源
保持热爱
