LT6711A HDMI to Type-c(DP/eDP) 国产原装 适用于移动系统、VR / AR、蜂窝手机等
描述
LT6711是一款经过深度优化的HDMI重新驱动器IC,可通过执行电缆或电路板走线损耗补偿来增强TMDS信号质量。LT6711可配置为在HDMI1.4b下工作,数据速率高达3.4Gb / s,HDMI2.0标准,最高6Gb / s数据速率,可实现4Kx2K 60Hz或1080P的最高分辨率,刷新率更高。
LT6711的输入接收器具有多级可编程线性均衡器,可通过符号间干扰(ISI)支持最大25dB的损耗补偿。输出发送器通过多级可编程输出摆幅和高达6dB的去加重来重新驱动接收信号。
还包括内置DDC拦截功能,与时钟通道上的精确频率检测协同工作,以自动设置重新驱动器参数。
LT6711内部集成了一个8位OCM和SPI闪存(堆叠芯片)来运行程序。LT6711还支持在线软件升级。
LT6711采用先进的CMOS工艺制造,采用小尺寸5mmx5mm BGA81(LT6711B)和7.5mmx7.5mm QFN64(LT6711A)封装。该封装符合RoHS标准,额定工作温度范围为-40°C至+ 85°C。
The Lontium LT6711 is HDMI2.0 to DP1.2 converter with internal Type-C Alternate Mode switch and PD controller.
For HDMI input, LT6711 features a HDMI2.0 receiver with 1 clock lane and 3 data lanes operating at maximum 6Gb/s per data lane and a maximum input bandwidth of 18Gb/s, allowing resolution up to 4Kx2K@60Hz for RGB format. The converter also integrates a DDC controller and supports both HDCP1.4 and HDCP2.2.
For DP1.2 output, it consists of 4 data lanes, supporting RBR (1.62Gbps), HBR (2.7Gbps) and HBR2 (5.4Gbps) link speeds. The build-in optional SSC function reduces EMI effect on EMI-concerned system application.
In order to be adaptable to the latest USB Type-C ecosystem, LT6711 integrates CC logic and PD management unit to relieve mobile system design complexity and BOM cost. The switch function is compliant with VESA DP Alternate Mode on USB Type-C Standard.
The LT6711 is fabricated in advanced CMOS process and implemented in a small outline 5mmx5mm BGA81 (LT6711B) and 7.5mmx7.5mm QFN64 (LT6711A) package. This package is RoHS compliant and specified to operate from -40°C to +85°C.
应用
移动系统,VR / AR
蜂窝手机,PAD /平板电脑
数码摄像机
数码相机
Mobile systems, VR/AR
Cellular handsets, PAD/Tablets
Digital video cameras
Digital still cameras
我公司可提供全套开发资料:规格书,电路图,DEMO,在线与原厂技术支持沟通推荐更适合客户的解决方案等等,能满足系统厂商不同的设计要求,欢迎广大客户来电咨询,可提供样品和含税13%!代理产品,每一片芯片都有原厂来货证明,杜绝一切假货后顾之忧,让您的用料更加放心可靠!
如需获取更多产品资料PDF,电路图或样品,技术疑问(原厂技术支持)欢迎随时与我们取得联系!!
