729|2
113
[原创] 【瑞萨RA8D1评测】第六篇:UART通讯控制LED亮灭 [复制链接]
先看效果:RA8D1发送“HELLO eeworld”,同时若接收到串口调试软件发送指令进行亮灭LED灯
因JLINK自带烧写和调试串口,刚好链接开发板的uart3,所以需要使能开发板的uart3就可以直接通过JLINK的USB直接与电脑进行通讯
系统框图如下:
使能串口uart3
核对串口使能引脚
配置时钟
串口处理函数
debug_uart3c
#include <debug_uart3.h>
void Debug_UART3_Init(void)
    fsp_err_t err = FSP_SUCCESS;
    err = R_SCI_B_UART_Open (&g_uart3_ctrl, &g_uart3_cfg);
    assert(FSP_SUCCESS == err);
uint8_t uart_send_complete_flag = 0;
void debug_uart3_callback (uart_callback_args_t * p_args)
    switch (p_args->event)
        case UART_EVENT_RX_CHAR:
            switch (p_args->data)
                    case '1':
                        R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_10_PIN_01, BSP_IO_LEVEL_LOW);;
                        break;
                    case '2':
                        R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_10_PIN_01, BSP_IO_LEVEL_HIGH);
                        break;
                    default:
                        break;
              break;
        case UART_EVENT_TX_COMPLETE:
            uart_send_complete_flag = 1;
            break;
        default:
            break;
串口头文件
debug_uart3.h
#ifndef _DEBUG_UART3_H
#define	_DEBUG_UART3_H
#include "hal_data.h"
#include "stdio.h"
void Debug_UART3_Init(void);
#endif
print函数构建
printf_redirect.c
#include "stdio.h"
#include <sys/stat.h>
#include <errno.h>
#undef errno
extern int errno;
int _write(int file, char *ptr, int len);
int _close(int file);
int _fstat(int file, struct stat *st);
int _isatty(int file);
int _read(int file, char *ptr, int len);
int _lseek(int file, int ptr, int dir);
#define DEBUG_SERIAL_TIMEOUT 2000/portTICK_PERIOD_MS
extern uint8_t uart_send_complete_flag;
    FSP_PARAMETER_NOT_USED(file);
    static bool uart_open = false;
    if (false == uart_open)
        err = R_SCI_B_UART_Open(&g_uart3_ctrl, &g_uart3_cfg);
    if (FSP_SUCCESS == err)
          err = R_SCI_B_UART_Write(&g_uart3_ctrl, (uint8_t *)ptr, (uint32_t)len);
    if (FSP_SUCCESS != err)
        len = -1;
    while(uart_send_complete_flag == 0)
        R_BSP_SoftwareDelay(10, BSP_DELAY_UNITS_MILLISECONDS);
    return len;
  return -1;
  st->st_mode = S_IFCHR;
  return 0;
  return 1;
    FSP_PARAMETER_NOT_USED(ptr);
    FSP_PARAMETER_NOT_USED(dir);
  return 0;
    FSP_PARAMETER_NOT_USED(len);
    return 0;
主程序hal_entry.c
 hal_entry.c
#include "debug_uart3.h"
fsp_err_t err;
void R_BSP_WarmStart(bsp_warm_start_event_t event);
//extern bsp_leds_t g_bsp_leds;
 * @brief   Blinky example application
 * Blinks all leds at a rate of 1 second using the software delay function provided by the BSP.
void hal_entry (void)
    Debug_UART3_Init();
    while (1)
        printf("HELL eeworld !\r\n");
        R_BSP_SoftwareDelay(1, BSP_DELAY_UNITS_SECONDS); //延时1秒
 * This function is called at various points during the startup process.  This implementation uses the event that is
 * called right before main() to set up the pins.
 * @param[in]  event    Where at in the start up process the code is currently at
void R_BSP_WarmStart (bsp_warm_start_event_t event)
    if (BSP_WARM_START_RESET == event)
#if BSP_FEATURE_FLASH_LP_VERSION != 0
        /* Enable reading from data flash. */
        R_FACI_LP->DFLCTL = 1U;
        /* Would normally have to wait tDSTOP(6us) for data flash recovery. Placing the enable here, before clock and
         * C runtime initialization, should negate the need for a delay since the initialization will typically take more than 6us. */
#endif
    if (BSP_WARM_START_POST_C == event)
        /* C runtime environment and system clocks are setup. */
        /* Configure pins. */
        R_IOPORT_Open(&IOPORT_CFG_CTRL, &IOPORT_CFG_NAME);
程序框架:
参考来源:https://m.eeworld.com.cn/bbs/forum.php?mod=viewthread&tid=1289361   详情 回复 发表于 2024-10-20 20:23
点赞(1) 关注
113
419
