905|2
92
全能小网关|CH32V208--第五篇:ETH与BLE的联动 [复制链接]
一:说明
        (1)本次实验是在BLE_UART例程中,添加TCP客户端和SLEEP功能下进行的;
        (2)ETH和BLE共存的情况下,将系统核心时钟设置为120MHz:
                 既:uint32_t SystemCoreClock=SYSCLK_FREQ_120MHz_HSE;
二:设置SLEEP功能
       2.1,sleep功能进入逻辑
                当蓝牙接收到“AT+SLEEP=1\r\n”时,进入低功耗模式;
       2.2,sleep功能使能和低功耗模式下GPIO的状态设置函数
 * @fn      sleep_modem_gpio_state_func
 * @brief   sleep休眠模式时,GPIO的状态
 * @return   none
void sleep_modem_gpio_state_func(void)
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); //enable clock
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); //enable clock
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE); //enable clock
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE); //enable clock
    GPIO_InitTypeDef GPIO_InitStructure = {0};            //gpio init struct
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;           //gpio pin
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;         //gpio mode
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;     //gpio speed
    GPIO_Init(GPIOA, &GPIO_InitStructure);                //gpio init
    GPIO_Init(GPIOB, &GPIO_InitStructure);                //gpio init
    GPIO_Init(GPIOC, &GPIO_InitStructure);                //gpio init
    GPIO_Init(GPIOD, &GPIO_InitStructure);                //gpio init
 * @fn      sleep_mode_enable
 * @brief   使能sleep休眠模式
 * @return  none
void sleep_mode_enable(void)
    if(((RCC->CFGR0 & RCC_SWS)==0x04)||((RCC->CFGR0 & RCC_PLLSRC) == RCC_PLLSRC))
           RCC_HSICmd(DISABLE);
    __WFI();
三:添加TCP客户端功能
        3.1,添加wchnet库文件
                3.1.1,工程中添加操作,如下图所示:
备注:步骤4为添加后的结果
                3.1.2,“包含”添加操作,如下图所示:
                3.1.3,“库”添加操作,如下图所示:
                3.1.4,“库路径”添加操作,如下图所示:
                3.1.5,TCP部分代码记录,如下所示:
 * @fn      WCHNET_CreateTcpSocket
 * @brief   Create TCP Socket
 * @return  none
static u8 socket_test;
 * @return  none
void WCHNET_CreateTcpSocket(void)
    u8 i;
    SOCK_INF TmpSocketInf;
    memset((void *) &TmpSocketInf, 0, sizeof(SOCK_INF));
    memcpy((void *) TmpSocketInf.IPAddr, DESIP, 4);
    TmpSocketInf.DesPort = desport;
    TmpSocketInf.SourPort = srcport++;
    TmpSocketInf.ProtoType = PROTO_TYPE_TCP;
    TmpSocketInf.RecvBufLen = RECE_BUF_LEN;
    i = WCHNET_SocketCreat(&SocketId, &TmpSocketInf);
    printf("WCHNET_SocketCreat %d\r\n", SocketId);
    mStopIfError(i);
    i = WCHNET_SocketConnect(SocketId);                        //make a TCP connection
    mStopIfError(i);
 * @fn      WCH_TCP_CLIENT_SEND
 * @brief   TCP客户端发送数据
 * @param   void
 * @return  none
uint8_t wch_tcp_client_send_func(uint8_t *buf, uint32_t *len)
    return WCHNET_SocketSend(socket_test, buf, len);
 * @fn      on_bleuartServiceEvt
 * @brief   ble uart service callback handler
 * @return  NULL
extern void wch_tcp_client_send_func(uint8_t *buf, uint32_t *len);
void on_bleuartServiceEvt(uint16_t connection_handle, ble_uart_evt_t *p_evt)
    switch(p_evt->type)
        case BLE_UART_EVT_TX_NOTI_DISABLED:
            PRINT("%02x:bleuart_EVT_TX_NOTI_DISABLED\r\n", connection_handle);
            break;
        case BLE_UART_EVT_TX_NOTI_ENABLED:
            PRINT("%02x:bleuart_EVT_TX_NOTI_ENABLED\r\n", connection_handle);
            break;
        case BLE_UART_EVT_BLE_DATA_RECIEVED://BLE数据接收事件
            PRINT("BLE RX DATA len:%d\r\n", p_evt->data.length);
            PRINT("BLE RX DATA :%s\r\n", p_evt->data.p_data);
            //此处,将数据发送到TCP服务器端
            if(wch_tcp_client_send_func((uint8_t *)p_evt->data.p_data,(uint32_t*)&p_evt->data.length) == p_evt->data.length)
                printf("data sent successfully!\r\n");
            break;
        default:
            break;
四:实验现象
        4.1,数据传输
                4.1.1,TCP服务器端记录,如下:
                4.1.2,设备运行日志记录,如下:
/* 上电初始化 */
CH32V20x_BLE_LIB_V1.40
SystemClk:120000000
net version:19
WCHNET_LibInit Success
WCHNET_SocketCreat 0
PHY Link Success
/* BLE连接成功 */
Initialized..
AdvertisConn 1 - Int 18
Connected..
Update 1 - Int 6
Update 1 - Int 18
Update 1 - Int 10
/* TCP第一次连接超时 */
TCP Timeout
/* TCP第二次连接超时 */
TCP Timeout
/* TCP连接成功 */
PHY Link Success
TCP Connect Success
socket id: 0
/* 数据转发 */
BLE RX DATA len:19
BLE RX DATA :welcome to eeworld!
BLE RX DATA len:19
BLE RX DATA len:19
BLE RX DATA len:19
BLE RX DATA len:19
BLE RX DATA len:19
        4.2,功耗记录
此帖出自无线连接论坛
蓝牙转wlan,确实是比较牛的功能了。   详情 回复 发表于 2024-7-21 09:07
7091
蓝牙转wlan,确实是比较牛的功能了。
此帖出自无线连接论坛
因为工作需要用到这个转换,也算是提前熟悉这部分功能了。  详情 回复 发表于 2024-7-21 11:51
92
lugl4313820 发表于 2024-7-21 09:07 蓝牙转wlan,确实是比较牛的功能了。
此帖出自无线连接论坛
