3419|0
LT8668SX 国产原装 支持eDP、LVDS与MIPI输出 用于显示系统的pc和嵌入式应用显示 [复制链接]
描述
LT8668SX可配置为在HDMI2.1标准下工作最大 8Gb/s数据速率可支持最高分辨率(带DSC或8Kx4K30Hz)。
LT8668SX还可配置为在DP1.4下工作,其数据速率最高可达8.1Gb/s,以便在DSC或8Kx4K30Hz下实现最高分辨率 8Kx4K 60Hz。
对于LVDS输出,LT8668SX可以配置为单端口、双端口或四端口LVDS,其中一个高速时钟通道和3~5个高速数据通道可支持总带宽高达 24Gbps。
对于 MIPI输出,LT8668SX可以配置为具有高速数据通道的单端口、双端口或四端口 MIPI,高速数据通道在D-PHY下工作在最大2.5Gbs/通道,其总带宽可高达40Gbps,或者使用C-PHY支持5.7Gb/s/路径,其总带幅可高达68.4Gbps.
对于eDP输出,它由8条数据通道组成,支持RBR(1.62Gbps)、HBR(2.7Gbps)和HBR2(5.4Gbps)链路速度。内置可选的SSC功能减少了EMI相关系统应用的EMI影响。
对于eDPx输出,它由8个数据通道组成,每通道最高工作速度为3Gb/s,可支持4K@60HZ:
8668 SX内部集成了一个8位的OCM和SPI闪存(堆叠芯片)来运行程序。Tell 18171547226 ,LT8668SX还支持在线软件升级。
8668SX是制造在先进的CMOS工艺,并在12mmx12毫米BGA288封装实施。该封装符合RoHS标准,可在-40°C至+85°C范围内工作。
应用程序
●移动系统
蜂窝手机、PAD/平板电脑
DescriptionLT8668SX can be configured to work under HDMI2.1standard with maximum 8Gb/s data rate to allow for thehighest resolutions of 8Kx4K 60Hz with DSC or 8Kx4K30Hz.LT8668SX also can be configured to work under DP1.4with up to 8.1Gb/s data rate to allow for the highestresolutions of 8Kx4K 60Hz with DSC or 8Kx4K 30Hz.For LVDS output, LT8668SX can be configured assingle-port , dual-port or four-port LVDS with 1 highspeed clock lane, and 3~5 high-speed data lanes, whichcan support a total bandwidth up to 24Gbps.For MIPI output, LT8668SX can be configured assingle-port , dual-port or four-port MIPI with high-speeddata lanes operating at maximum 2.5Gb/s/lane withD-PHY, which can support a total bandwidth of up to40Gbps, Or support 5.7Gb/s/lane with C-PHY, whichcan support a total bandwidth of up to 68.4Gbps.For eDP output, it consists of 8 data lanes, supportingRBR (1.62Gbps), HBR (2.7Gbps) and HBR2 (5.4Gbps)link speeds. The build-in optional SSC function reducesEMI effect on EMI-concerned system application.For eDPx output, it consists of 8 data lanes, withoperating at maximum 3Gb/s per lane, which cansupport 4K@60Hz.LT8668SX internally integrates an 8-bit OCM and SPIflash memory (stacked die) to run program. Onlinesoftware upgrade is also supported for LT8668SX.LT8668SX is fabricated in advanced CMOS processand implemented in 12mmx12mm BGA288 package.This package is RoHS compliant and specified tooperate from -40°C to +85°C.
 Mobile system
 Cellular handsets, PAD/Tablets
 Display
 AR/VR
Lontium-LT8668EX.pdf (138.85 KB, 下载次数: 1)
