116|0
龙迅 LT8711UXC 国产原装 4通道C/DP转HDMI2.0转换方案 超高清8K@30Hz 用于加密狗 [复制链接]
2.一般说明
LT8711UXC是一款高性能的Type-C/DP1.4转换器用于将USBType-C源或DP1.4源连接到HDMI2.0汇流器。该LT8711UXC集成了一个符合DP1.4标准的接收器和一个符合HDMI2.0标准的发射器。此外,还包括CC控制器,用于CC通信,以实现DP ALT模式和功率传送功能。
DP接口包括4个主通道、辅助通道和HPD信号接收器支持每条通道的最大8.1Gbps数据速率中。DP接收机采用HDCP1.3/2.2/2.3内容保护方案,内置密钥,可安全传输数字音视频内容。
HDMI接口包括4个TMDS时钟/数据对、DDC和HPD信号。HDMI传输器能够支持高达6Gpbs的数据速率,足以处理高达UHD4k60Hz格式的视频分辨率。HDMI发射器集成了HDCP引擎,同时支持HDCP1.4/2.2/2.3。随着HDCP的列入,该LT8711UXC允许受保护的内容安全传输嵌入式密钥可提供最高级别的HDCP密钥安全
该设备能够自动操作,这由集成微处理器实现该微处理器使用嵌入式SPI闪存用于固件存储手系统控制也可通过使用专用配置12C从站接口
3.应用程序
对接站
加密狗
2. General DescriptionThe LT8711UXC is a high performance Type-C/DP1.4 toHDMI2.0 converter, designed to connect a USB Type-Csource or a DP1.4 source to an HDMI2.0 sink. TheLT8711UXC integrates a DP1.4 compliant receiver, andan HDMI2.0 compliant transmitter. Also, a CC controller isincluded for CC communication to implement DP Alt Modeand power delivery function.The DP interface comprises 4 main lanes, AUX channel,and HPD signal. The receiver supports maximum8.1Gbps data rate per lane. The DP receiver incorporatesHDCP 1.3/2.2/2.3 content protection scheme withembedded key for secure transmission of digitalaudio-video content.The HDMI interface includes 4 TMDS clock/data pairs,DDC, and HPD signal. The HDMI transmitter is capable ofsupporting up to 6Gpbs data rate, quite adequate forhandling video resolutions up to UHD 4k 60Hz formats.The HDMI transmitter incorporates HDCP engines whichsupport both HDCP1.4/2.2/2.3. With the inclusion ofHDCP, the LT8711UXC allows secure transmission ofprotected content. Embedded key is available thatprovides the highest level of HDCP key security.The device is capable of automatic operation which isenabled by an integrated microprocessor that uses anembedded SPI flash for firmware storage. System controlis also available through the use of a dedicatedconfiguration I2C slave interface.
3. Applications
Docking station
Dongle
