3032|5
91
WINCE4.2里面到底有没有CFileDialog类? [复制链接]
有的话,如何用?
此帖出自WindowsCE论坛
还是自己写个好了 wince自带的却是不敢恭维  详情 回复 发表于 2007-5-28 12:25
当然有.
CFileDialog *openPicDlg=new CFileDialog(true,NULL,NULL,OFN_HIDEREADONLY | OFN_OVERWRITEPROMPT,_T("Bmp Files(*.bmp)|*.bmp|All Files(*.*)|*.*|"),NULL);
        int nResponse = openPicDlg->DoModal();
        if (nResponse == IDOK)
                strImageFilePath=openPicDlg->GetPathName();
此帖出自WindowsCE论坛
85
当然有   可能功能少点
此帖出自WindowsCE论坛
wince的对话框类功能比较少,好像只能浏览MyDocument目录及其子目录。如果需要浏览其他目录,好像需要自己写一个。
此帖出自WindowsCE论坛
Construction Methods
Method Description
CFileDialog Constructs a CFileDialog object.
Operations Methods
Method Description
DoModal Displays the dialog box and allows the user to make a selection.
GetPathName Returns the full path of the selected file.
GetFileName Returns the file name of the selected file.
GetFileExt Returns the file extension of the selected file.
GetFileTitle Returns the title of the selected file.
Overridable Methods
Method Description
OnShareViolation Called when a share violation occurs.
OnFileNameOK Called to validate the file name entered in the dialog box.
OnLBSelChangedNotify Called when the list box selection changes.
此帖出自WindowsCE论坛
还是自己写个好了
wince自带的却是不敢恭维
此帖出自WindowsCE论坛
