1110|3
3249
out出不来 [复制链接]
我用modesim仿真
register.v:
module register8(ena,clk,data,rst,out);
input ena,clk,rst;
input [7:0] data;
output [7:0] out;
wire [7:0] data;
reg[7:0] out;
  always @(posedge clk)
        if (!rst)
          out = 0;
        else if (ena)
          out = data;
 //閾忕晫鍔у▽鈩冩箒閸愭獔lse妞ょ櫢绱濋弰鍓у姧婵″倹鐏塭na娑撹桨缍嗛悽闈涢挬閿涘苯宓嗘担鎸庢闁界喎褰夐崠鏍电礉data閸欐ê瀵查敍灞肩稻out娴犲秳绻氶幐浣风瑝閸?
endmodule
register1.v
// Copyright (C) 1991-2013 Altera Corporation
// Your use of Altera Corporation's design tools, logic functions
// and other software and tools, and its AMPP partner logic
// functions, and any output files from any of the foregoing
// (including device programming or simulation files), and any
// associated documentation or information are expressly subject
// to the terms and conditions of the Altera Program License
// Subscription Agreement, Altera MegaCore Function License
// Agreement, or other applicable license agreement, including,
// without limitation, that your use is for the sole purpose of
// programming logic devices manufactured by Altera and sold by
// Altera or its authorized distributors.  Please refer to the
// applicable agreement for further details.
// This file contains a Verilog test bench template that is freely editable to
// suit user's needs .Comments are provided in each section to help the user
// fill out necessary details.
// Generated on "06/08/2024 07:43:11"
// Verilog Test Bench template for design : register8
// Simulation tool : ModelSim (Verilog)
`timescale 1 ns/ 100 ps
module register8_vlg_tst();
// constants
// general purpose registers
// test vector input registers
reg clk;
reg [7:0] data;
reg ena;
reg rst;
// wires
wire [7:0]  out;
// assign statements (if any)
register8 i1 (
// port map - connection between master ports and signals/registers
	.clk(clk),
	.data(data),
	.ena(ena),
	.out(out),
	.rst(rst)
initial
begin
// code that executes only once
// insert code here --> begin
    clk=0;
		#5 clk=~clk;
// --> end
end
 initial
// optional sensitivity list
// @(event1 or event2 or .... eventn)
begin
// code executes for every event on sensitivity list
 #10 rst=0;
#10 rst=1;
#10 ena=1;
#10 data=16'h55;
 #10 data=16'haa;
 #10 data=16'h46;
  #10 $stop;
// --> end
end
endmodule
仿真效果图:
请问高手,哪里出错了?谢谢!
此帖出自FPGA/CPLD论坛
testbench中第54行前面加个always,你这时钟一直为1,结果肯定不对。   详情 回复 发表于 2024-6-8 10:21
个人签名为江山踏坏了乌骓马,为社稷拉断了宝雕弓。
4953
设置中断,二分查找吧
此帖出自FPGA/CPLD论坛
375
此帖出自FPGA/CPLD论坛
谢谢!  详情 回复 发表于 2024-6-9 07:44
3249
00750 发表于 2024-6-8 10:21 testbench中第54行前面加个always,你这时钟一直为1,结果肯定不对。
谢谢!
此帖出自FPGA/CPLD论坛
