#AI挑战营第二站#RV1106的rknn模型转换、仿真推理
1.环境搭建不再赘述,参考https://bbs.eeworld.com.cn/thread-1280038-1-1.html
2.模型转换
rknn = RKNN(verbose=True)
#Pre-process config
print('--> Config model')
rknn.config(mean_values=[[28]], std_values=[[28]],target_platform='rv1106')
print('done')
# Load model
print('--> Loading model')
ret = rknn.load_onnx(model='mnist.onnx')
if ret != 0:
print('Load model failed!')
exit(ret)
print('done')
# Build model
print('--> Building model')
ret = rknn.build(do_quantization=True, dataset='./data.txt',rknn_batch_size=1)
if ret != 0:
print('Build model failed!')
exit(ret)
print('done')
# Export rknn model
print('--> Export rknn model')
ret = rknn.export_rknn('mnist.rknn')
if ret != 0:
print('Export rknn model failed!')
exit(ret)
print('done')
# Release
rknn.release()
3.紧接着进行模型仿真推理
# Set inputs
img = cv2.imread('8.png')
img = cv2.resize(img, (28, 28))
#cv2.imwrite('2r.jpg', img)
img = cv2.cvtColor(img, cv2.COLOR_BGR2GRAY)
img = np.expand_dims(img, 0)
img = np.expand_dims(img, 3)
# Init runtime environment
print('--> Init runtime environment')
ret = rknn.init_runtime()
if ret != 0:
print('Init runtime environment failed!')
exit(ret)
print('done')
# Inference
print('--> Running model')
outputs = rknn.inference(inputs=[img])
#Post Process
print('--> PostProcess')
with open('./synset.txt', 'r') as f:
labels = [l.rstrip() for l in f]
scores = softmax(outputs[0])
# print the top-5 inferences class
scores = np.squeeze(scores)
a = np.argsort(scores)[::-1]
print('-----TOP 5-----')
for i in a[0:5]:
print('[%d] score=%.2f class="%s"' % (i, scores[i], labels[i]))
print('done')
# Release
rknn.release()
注意:如需仿真推理,第二步2.模型转换中先不释放rknn实体
# Release
rknn.release()
4.模型转换log
I rknn-toolkit2 version: 2.0.0b0+9bab5682
--> Config model
done
--> Loading model
I It is recommended onnx opset 19, but your onnx model opset is 10!
I Model converted from pytorch, 'opset_version' should be set 19 in torch.onnx.export for successful convert!
I Loading : 100%|██████████████████████████████████████████████████| 9/9 [00:00<00:00, 16897.38it/s]
done
--> Building model
D base_optimize ...
D base_optimize done.
D fold_constant ...
D fold_constant done.
D correct_ops ...
D correct_ops done.
D fuse_ops ...
D fuse_ops results:
D replace_reshape_gemm_by_conv: remove node = ['/Reshape', '/fc1/Gemm'], add node = ['/fc1/Gemm_2conv', '/fc1/Gemm_2conv_reshape']
D swap_reshape_relu: remove node = ['/fc1/Gemm_2conv_reshape', '/Relu_2'], add node = ['/Relu_2', '/fc1/Gemm_2conv_reshape']
D convert_gemm_by_conv: remove node = ['/fc2/Gemm'], add node = ['/fc2/Gemm_2conv_reshape1', '/fc2/Gemm_2conv', '/fc2/Gemm_2conv_reshape2']
D fuse_two_reshape: remove node = ['/fc1/Gemm_2conv_reshape']
D remove_invalid_reshape: remove node = ['/fc2/Gemm_2conv_reshape1']
D fold_constant ...
D fuse_ops done.
D sparse_weight ...
D sparse_weight done.
I GraphPreparing : 100%|██████████████████████████████████████████| 10/10 [00:00<00:00, 4456.81it/s]
I Quantizating : 100%|████████████████████████████████████████████| 10/10 [00:00<00:00, 1337.34it/s]
D quant_optimizer ...
D quant_optimizer results:
D adjust_relu: ['/Relu_2', '/Relu_1', '/Relu']
D quant_optimizer done.
W build: The default input dtype of 'input' is changed from 'float32' to 'int8' in rknn model for performance!
Please take care of this change when deploy rknn model with Runtime API!
W build: The default output dtype of 'output' is changed from 'float32' to 'int8' in rknn model for performance!
I rknn building ...
I RKNN: [18:11:22.305] compress = 0, conv_eltwise_activation_fuse = 1, global_fuse = 1, multi-core-model-mode = 7, output_optimize = 1, layout_match = 1, enable_argb_group = 0
I RKNN: librknnc version: 2.0.0b0 (35a6907d79@2024-03-24T02:34:11)
D RKNN: [18:11:22.308] RKNN is invoked
D RKNN: [18:11:22.318] >>>>>> start: rknn::RKNNExtractCustomOpAttrs
D RKNN: [18:11:22.318] <<<<<<<< end: rknn::RKNNExtractCustomOpAttrs
D RKNN: [18:11:22.318] >>>>>> start: rknn::RKNNSetOpTargetPass
D RKNN: [18:11:22.318] <<<<<<<< end: rknn::RKNNSetOpTargetPass
D RKNN: [18:11:22.318] >>>>>> start: rknn::RKNNBindNorm
D RKNN: [18:11:22.318] <<<<<<<< end: rknn::RKNNBindNorm
D RKNN: [18:11:22.318] >>>>>> start: rknn::RKNNAddFirstConv
D RKNN: [18:11:22.318] <<<<<<<< end: rknn::RKNNAddFirstConv
D RKNN: [18:11:22.318] >>>>>> start: rknn::RKNNEliminateQATDataConvert
D RKNN: [18:11:22.318] <<<<<<<< end: rknn::RKNNEliminateQATDataConvert
D RKNN: [18:11:22.318] >>>>>> start: rknn::RKNNTileGroupConv
D RKNN: [18:11:22.318] <<<<<<<< end: rknn::RKNNTileGroupConv
D RKNN: [18:11:22.318] >>>>>> start: rknn::RKNNTileFcBatchFuse
D RKNN: [18:11:22.318] <<<<<<<< end: rknn::RKNNTileFcBatchFuse
D RKNN: [18:11:22.318] >>>>>> start: rknn::RKNNAddConvBias
D RKNN: [18:11:22.318] <<<<<<<< end: rknn::RKNNAddConvBias
D RKNN: [18:11:22.318] >>>>>> start: rknn::RKNNTileChannel
D RKNN: [18:11:22.318] <<<<<<<< end: rknn::RKNNTileChannel
D RKNN: [18:11:22.318] >>>>>> start: rknn::RKNNPerChannelPrep
D RKNN: [18:11:22.318] <<<<<<<< end: rknn::RKNNPerChannelPrep
D RKNN: [18:11:22.318] >>>>>> start: rknn::RKNNBnQuant
D RKNN: [18:11:22.318] <<<<<<<< end: rknn::RKNNBnQuant
D RKNN: [18:11:22.318] >>>>>> start: rknn::RKNNFuseOptimizerPass
D RKNN: [18:11:22.319] <<<<<<<< end: rknn::RKNNFuseOptimizerPass
D RKNN: [18:11:22.319] >>>>>> start: rknn::RKNNTurnAutoPad
D RKNN: [18:11:22.319] <<<<<<<< end: rknn::RKNNTurnAutoPad
D RKNN: [18:11:22.319] >>>>>> start: rknn::RKNNInitRNNConst
D RKNN: [18:11:22.319] <<<<<<<< end: rknn::RKNNInitRNNConst
D RKNN: [18:11:22.319] >>>>>> start: rknn::RKNNInitCastConst
D RKNN: [18:11:22.319] <<<<<<<< end: rknn::RKNNInitCastConst
D RKNN: [18:11:22.319] >>>>>> start: rknn::RKNNMultiSurfacePass
D RKNN: [18:11:22.319] <<<<<<<< end: rknn::RKNNMultiSurfacePass
D RKNN: [18:11:22.319] >>>>>> start: rknn::RKNNReplaceConstantTensorPass
D RKNN: [18:11:22.319] <<<<<<<< end: rknn::RKNNReplaceConstantTensorPass
D RKNN: [18:11:22.319] >>>>>> start: rknn::RKNNSubgraphManager
D RKNN: [18:11:22.319] <<<<<<<< end: rknn::RKNNSubgraphManager
D RKNN: [18:11:22.319] >>>>>> start: OpEmit
D RKNN: [18:11:22.319] <<<<<<<< end: OpEmit
D RKNN: [18:11:22.319] >>>>>> start: rknn::RKNNLayoutMatchPass
I RKNN: [18:11:22.319] AppointLayout: t->setNativeLayout(64), tname:[/Relu_output_0]
I RKNN: [18:11:22.319] AppointLayout: t->setNativeLayout(64), tname:[/pool/MaxPool_output_0]
I RKNN: [18:11:22.319] AppointLayout: t->setNativeLayout(64), tname:[/Relu_1_output_0]
I RKNN: [18:11:22.319] AppointLayout: t->setNativeLayout(64), tname:[/pool_1/MaxPool_output_0]
I RKNN: [18:11:22.319] AppointLayout: t->setNativeLayout(64), tname:[/fc1/Gemm_output_0_new]
I RKNN: [18:11:22.319] AppointLayout: t->setNativeLayout(64), tname:[output_conv]
I RKNN: [18:11:22.319] AppointLayout: t->setNativeLayout(0), tname:[output]
D RKNN: [18:11:22.319] <<<<<<<< end: rknn::RKNNLayoutMatchPass
D RKNN: [18:11:22.319] >>>>>> start: rknn::RKNNAddSecondaryNode
D RKNN: [18:11:22.319] <<<<<<<< end: rknn::RKNNAddSecondaryNode
D RKNN: [18:11:22.319] finish initComputeZoneMap
D RKNN: [18:11:22.320] <<<<<<<< end: OpEmit
D RKNN: [18:11:22.320] >>>>>> start: rknn::RKNNSubGraphMemoryPlanPass
D RKNN: [18:11:22.320] <<<<<<<< end: rknn::RKNNSubGraphMemoryPlanPass
D RKNN: [18:11:22.320] >>>>>> start: rknn::RKNNProfileAnalysisPass
D RKNN: [18:11:22.320] node: Reshape:/fc2/Gemm_2conv_reshape2, Target: NPU
D RKNN: [18:11:22.320] <<<<<<<< end: rknn::RKNNProfileAnalysisPass
D RKNN: [18:11:22.320] >>>>>> start: rknn::RKNNOperatorIdGenPass
D RKNN: [18:11:22.320] <<<<<<<< end: rknn::RKNNOperatorIdGenPass
D RKNN: [18:11:22.320] >>>>>> start: rknn::RKNNWeightTransposePass
W RKNN: [18:11:22.331] Warning: Tensor /fc2/Gemm_2conv_reshape2_shape need paramter qtype, type is set to float16 by default!
D RKNN: [18:11:22.331] <<<<<<<< end: rknn::RKNNWeightTransposePass
D RKNN: [18:11:22.331] >>>>>> start: rknn::RKNNCPUWeightTransposePass
D RKNN: [18:11:22.331] <<<<<<<< end: rknn::RKNNCPUWeightTransposePass
D RKNN: [18:11:22.331] >>>>>> start: rknn::RKNNModelBuildPass
D RKNN: [18:11:22.336] <<<<<<<< end: rknn::RKNNModelBuildPass
D RKNN: [18:11:22.336] >>>>>> start: rknn::RKNNModelRegCmdbuildPass
D RKNN: [18:11:22.336] ------------------------------------------------------------------------------------------------------------------------------------------------------------------------
D RKNN: [18:11:22.336] Network Layer Information Table
D RKNN: [18:11:22.336] ID OpType DataType Target InputShape OutputShape Cycles(DDR/NPU/Total) RW(KB) FullName
D RKNN: [18:11:22.336] 0 InputOperator INT8 CPU \ (1,1,28,28) 0/0/0 0 InputOperator:input
D RKNN: [18:11:22.336] 1 ConvRelu INT8 NPU (1,1,28,28),(32,1,3,3),(32) (1,32,28,28) 4429/7056/7056 2 Conv:/conv1/Conv
D RKNN: [18:11:22.336] 2 MaxPool INT8 NPU (1,32,28,28) (1,32,14,14) 5092/0/5092 24 MaxPool:/pool/MaxPool
D RKNN: [18:11:22.336] 3 ConvRelu INT8 NPU (1,32,14,14),(64,32,3,3),(64) (1,64,14,14) 6131/7488/7488 24 Conv:/conv2/Conv
D RKNN: [18:11:22.336] 4 MaxPool INT8 NPU (1,64,14,14) (1,64,7,7) 2546/0/2546 12 MaxPool:/pool_1/MaxPool
D RKNN: [18:11:22.336] 5 ConvRelu INT8 NPU (1,64,7,7),(128,64,7,7),(128) (1,128,1,1) 65865/12544/65865 396 Conv:/fc1/Gemm_2conv
D RKNN: [18:11:22.336] 6 Conv INT8 NPU (1,128,1,1),(10,128,1,1),(10) (1,10,1,1) 252/64/252 1 Conv:/fc2/Gemm_2conv
D RKNN: [18:11:22.336] 7 Reshape INT8 NPU (1,10,1,1),(2) (1,10) 7/0/7 0 Reshape:/fc2/Gemm_2conv_reshape2
D RKNN: [18:11:22.336] 8 OutputOperator INT8 CPU (1,10) \ 0/0/0 0 OutputOperator:output
D RKNN: [18:11:22.337] <<<<<<<< end: rknn::RKNNModelRegCmdbuildPass
D RKNN: [18:11:22.337] >>>>>> start: rknn::RKNNFlatcModelBuildPass
D RKNN: [18:11:22.337] Export Mini RKNN model to /tmp/tmphfyahgcw/check.rknn
D RKNN: [18:11:22.337] >>>>>> end: rknn::RKNNFlatcModelBuildPass
D RKNN: [18:11:22.337] >>>>>> start: rknn::RKNNMemStatisticsPass
D RKNN: [18:11:22.337] ---------------------------------------------------------------------------------------------------------------------------------
D RKNN: [18:11:22.337] Feature Tensor Information Table
D RKNN: [18:11:22.337] -----------------------------------------------------------------------------------------------+---------------------------------
D RKNN: [18:11:22.337] ID User Tensor DataType DataFormat OrigShape NativeShape | [Start End) Size
D RKNN: [18:11:22.337] 1 ConvRelu input INT8 NC1HWC2 (1,1,28,28) (1,1,28,28,1) | 0x00069000 0x00069380 0x00000380
D RKNN: [18:11:22.337] 2 MaxPool /Relu_output_0 INT8 NC1HWC2 (1,32,28,28) (1,2,28,28,16) | 0x00069380 0x0006f580 0x00006200
D RKNN: [18:11:22.337] 3 ConvRelu /pool/MaxPool_output_0 INT8 NC1HWC2 (1,32,14,14) (1,2,14,14,16) | 0x0006f580 0x00070e00 0x00001880
D RKNN: [18:11:22.337] 4 MaxPool /Relu_1_output_0 INT8 NC1HWC2 (1,64,14,14) (1,4,14,14,16) | 0x00069000 0x0006c100 0x00003100
D RKNN: [18:11:22.337] 5 ConvRelu /pool_1/MaxPool_output_0 INT8 NC1HWC2 (1,64,7,7) (1,4,7,7,16) | 0x0006c100 0x0006ce00 0x00000d00
D RKNN: [18:11:22.337] 6 Conv /fc1/Gemm_output_0_new INT8 NC1HWC2 (1,128,1,1) (1,8,1,1,16) | 0x00069000 0x00069080 0x00000080
D RKNN: [18:11:22.337] 7 Reshape output_conv INT8 NC1HWC2 (1,10,1,1) (1,1,1,1,16) | 0x00069080 0x00069090 0x00000010
D RKNN: [18:11:22.337] 8 OutputOperator output INT8 UNDEFINED (1,10) (1,10) | 0x00069040 0x00069080 0x00000040
D RKNN: [18:11:22.337] Const Tensor Information Table
D RKNN: [18:11:22.337] -------------------------------------------------------------------+---------------------------------
D RKNN: [18:11:22.337] ID User Tensor DataType OrigShape | [Start End) Size
D RKNN: [18:11:22.337] 1 ConvRelu conv1.weight INT8 (32,1,3,3) | 0x00000000 0x00000480 0x00000480
D RKNN: [18:11:22.337] 1 ConvRelu conv1.bias INT32 (32) | 0x00000480 0x00000580 0x00000100
D RKNN: [18:11:22.337] 3 ConvRelu conv2.weight INT8 (64,32,3,3) | 0x00000580 0x00004d80 0x00004800
D RKNN: [18:11:22.337] 3 ConvRelu conv2.bias INT32 (64) | 0x00004d80 0x00004f80 0x00000200
D RKNN: [18:11:22.337] 5 ConvRelu fc1.weight INT8 (128,64,7,7) | 0x00004f80 0x00066f80 0x00062000
D RKNN: [18:11:22.337] 5 ConvRelu fc1.bias INT32 (128) | 0x00066f80 0x00067380 0x00000400
D RKNN: [18:11:22.337] 6 Conv fc2.weight INT8 (10,128,1,1) | 0x00067380 0x00067880 0x00000500
D RKNN: [18:11:22.337] 6 Conv fc2.bias INT32 (10) | 0x00067880 0x00067900 0x00000080
D RKNN: [18:11:22.337] 7 Reshape /fc2/Gemm_2conv_reshape2_shape INT64 (2) | 0x00067900*0x00067940 0x00000040
D RKNN: [18:11:22.337] Total Internal Memory Size: 31.5KB
D RKNN: [18:11:22.337] Total Weight Memory Size: 414.312KB
D RKNN: [18:11:22.337] <<<<<<<< end: rknn::RKNNMemStatisticsPass
I rknn buiding done.
done
done
5.仿真推理log
I Target is None, use simulator!
done
--> Running model
W inference: The 'data_format' is not set, and its default value is 'nhwc'!
I GraphPreparing : 100%|██████████████████████████████████████████| 12/12 [00:00<00:00, 4513.64it/s]
I SessionPreparing : 100%|████████████████████████████████████████| 12/12 [00:00<00:00, 1368.27it/s]
--> PostProcess
-----TOP 5-----
[8] score=1.00 class="8 8"
[3] score=0.00 class="3 3"
[9] score=0.00 class="9 9"
[2] score=0.00 class="2 2"
[6] score=0.00 class="6 6"
done
6.模型转换工程目录下文件
7.data.txt内容
./2.png
8.synset.txt内容
0 0
1 1
2 2
3 3
4 4
5 5
6 6
7 7
8 8
9 9
9.仿真推理所用图片:
10.附github工程链接
