1031|0
24
【FireBeetle 2 ESP32 C6】espnow 测试2 [复制链接]
将程序修改一下,按下按钮后发送信号,接收到信号时闪LED。
对于不同的板子,修改LED和SW对应引脚即可。
import network
import espnow
import time
from machine import Pin
import os
r = os.uname()
if 'ESP32C6' in r.machine:
    LED= Pin(15, Pin.OUT)
    SW = Pin(9, Pin.IN)
else:
    LED= Pin(12, Pin.OUT)
    SW = Pin(9, Pin.IN)
# WLAN接口必须处于活动状态才能 send()/recv()
sta = network.WLAN(network.STA_IF) # 或 network.AP_IF
sta.active(True)
sta.disconnect() # 对于 ESP8266
e = espnow.ESPNow()
e.active(True)
peer = b'\xbb\xbb\xbb\xbb\xbb\xbb' # 配对设备wifi接口的MAC地址
e.add_peer(peer) # 发送前必须 add_peer()
def isr_sw(t):
    e.send(peer, str(time.ticks_ms()))
def erecv():
    while True:
        host, msg = e.recv()
        if msg:
            LED(not LED())
            print(host, msg)
SW.irq(trigger=Pin.IRQ_FALLING, handler=isr_sw)
erecv()
