3537|3
63
setsockopt 函数如何使用? [复制链接]
我的发送程序
#include "vxWorks.h"
#include "fioLib.h"
#include "stdio.h"
#include "unistd.h"
#include "string.h"
#include "usrLib.h"
#include "errnoLib.h"
#include "hostLib.h"
#include "sockLib.h"
#include "socket.h"
#include "inetLib.h"
#include "in.h"
#define SOCKET_ERROR -1
#if 1
int testsend(void)
    int   eno,fd;
    struct sockaddr_in sa;
    char  buf[]  =  "Hello,  World!";
    int   sock_reuse  = 1;
    int   loopback    = 1;
    int   ttl         = 50;
    int quitting      = -1;
    sa.sin_family      = AF_INET;
    sa.sin_port        = htons(5100);
    sa.sin_addr.s_addr = inet_addr("224.1.2.1");
    fd = socket(AF_INET, SOCK_DGRAM, 0);
    if (fd == -1)
        printf("Couldn't create a UDP socket\n");
        return -1;
    if(setsockopt(fd,  SOL_SOCKET,  SO_REUSEADDR,  (char  *)&sock_reuse,  sizeof(sock_reuse))  <  0)
         printf("socket  options  set  error:reuse\n");
         close(fd);
         return -1;
    if((eno = setsockopt(fd,IPPROTO_IP,  IP_MULTICAST_TTL,  (char  *)&ttl,  sizeof(int)))<0)
         printf("socket  options  set  error:TTL eno:%d\n",eno);
         close(fd);
         return -1;
    if(setsockopt(fd,IPPROTO_IP,  IP_MULTICAST_LOOP,  (char  *)&loopback,  sizeof(int))<0)
         printf("socket  options  set  error:loopback\n");
         close(fd);
         return -1;
    while(!quitting)
         if(sendto(fd,buf,sizeof(buf),0,(struct  sockaddr  *)&sa,sizeof(sa))== SOCKET_ERROR)
             printf("Send error!\n");
             close(fd);
             return -1;
         }else
             printf("Send OK\n!");
         taskDelay(1);
    close(fd);
#endif
运行的时候setsockopt 函数返回错误,就不能发送
数据类型  详情 回复 发表于 2007-5-8 15:03
75
我的接收程序
#if 0
#include "fioLib.h"
#include "stdio.h"
#include "unistd.h"
#include "string.h"
#include "usrLib.h"
#include "socket.h"
#include "in.h"
#endif
#include "sys/types.h"
#include "ioLib.h"
#include "fioLib.h"
#include "stdio.h"
#include "unistd.h"
#include "string.h"
#include "usrLib.h"
#include "socket.h"
#include "in.h"
int testrecv(void)
    int    len,fd,sock_reuse  =  1;
     int quitting = 0;
    struct ip_mreq  multicast;
    char   buf[1024];
    if (fd == -1)
        return -1;
#if 0
multicast.imr_multiaddr.s_addr  =  inet_addr(RECV_IP_ADDR);
    multicast.imr_interface.s_addr  =  htonl(INADDR_ANY); multicast.imr_interface.s_addr  =  htonl("192.168.0.31");
#endif
#if 1
multicast.imr_multiaddr.s_addr  =  inet_addr("224.1.2.1");
#endif
#if 0
    sa.sin_port = htons(RECV_PORT);
#endif
    sa.sin_addr.s_addr = htonl(INADDR_ANY);
         close(fd);
         return -1;
    if (bind(fd, (struct sockaddr *) &sa, (int) sizeof(sa)) == -1)
         printf("Couldn't bind a UDP socket to port %d\n", 6666);
         close(fd);
         return -1;
    if(setsockopt(fd,IPPROTO_IP,IP_ADD_MEMBERSHIP,(char  *)&multicast,sizeof(multicast))  <  0  )
         printf("socket  options  set  error:multicast\n");
         close(fd);
         return -1;
    while(!quitting)
        memset(buf,0,sizeof(buf));
        if(recvfrom(fd,buf,sizeof(buf),0, (struct  sockaddr *)&sa, &len) ==  SOCKET_ERROR)
             printf("Recv error!\n");
             close(fd);
             return -1;
        else
             printf("Recv data:%s",buf);
    close(fd);
接收执行的时候setsockopt还是返回错误,导致接收不成功,想问问是什么原因导致的?
网卡工作是正常的,我可以ping通
数据类型
会议时间:3月18日(周二)09:30签到
参会奖励:电动螺丝刀套装、户外登山包、京东卡
