3220|0
79
LINUX的makefile问题!!!! [复制链接]
CC = ckcore-elf-gcc
AS = ckcore-elf-as
LD = ckcore-elf-ld
CFLAGS  = -mbig-endian  -c -O2 -g
ASFLAGS = -mbig-endian
OBJECT = tinyloader.o tiny_spi.o tiny_main.o vectors.o \
                  main.o pll_config.o tinyloader2.o  \
                  compress.o unzip_main.o 6102.o
TEMP_FILE1 := main.TM1
TEMP_FILE2 := main.TM2
all :flash ready
flash : bootloader.elf
        ckcore-elf-objcopy bootloader.elf bootloader.bin -O binary -S -g -R .note -R .comment \
                --change-section-lma .loadertext=0x60000000 \                --change-section-lma .loadertext2=0x60000800 \
                --change-section-lma .text=0x60010000
        xxd -c4 -p bootloader.bin > TEMP_FILE1
        sed -e '2c300155AA' TEMP_FILE1 > TEMP_FILE2
        xxd -r -c4 -p TEMP_FILE2 > bootloader.bin
        rm -f TEMP_FILE1
        rm -f TEMP_FILE2
ready : main.elf
        ckcore-elf-objcopy main.elf 6102.bin -O binary -S -g -R .loadertext -R .loaderbss
        gzip -n9 6102.bin
        bin2h 6102.bin.gz 6102.c
bootloader.elf :  $(OBJECT)
        $(LD)  -T link.ld -EB $(OBJECT) -o $@
bootloader.txt : bootloader.elf
        ckcore-elf-objdump -D $^ > $@
%.o : %.c
        $(CC) $(CFLAGS) $^ -o $@
%.o : %.S
clean:
        rm -f *.o *.srec *.hex bootloader.elf *.gz
红色的部分不是很清楚 请讲解下 !!顺便能总体讲解下 更好!!!!!
此帖出自Linux开发论坛
快来报名!
