1188|3
136
【FireBeetle 2 ESP32 C6开发板】-3- C6获取小米温湿度计2数据 [复制链接]
小米温湿度计2 是从设备,同时也是BLE SERVER,部署了多个sevice,其中serviceUUID("ebe0ccb0-7a0a-4b0c-8a1a-6ff2997da3a6")里面的charUUID("ebe0ccc1-7a0a-4b0c-8a1a-6ff2997da3a6")就是温湿度数据。
esp32c6是主设备,同时也是BLE CLIENT,通过BLE的协议来访问Server上的Characteristic,从而获取到温湿度数据。
C6启动后,会开始扫描周围的BLE设备,此时进行一个判断,设备名称是否为XiaomiDeviceName = "LYWSD03MMC"
   * Called for each advertising BLE server.
  void onResult(BLEAdvertisedDevice advertisedDevice) {
    Serial.println("*-------------------------------------------------------------------*");
    Serial.print("BLE Advertised Device found: ");
    Serial.println(advertisedDevice.toString().c_str());
    // We have found a device, let us now see if it contains the service we are looking for.
    Serial.println(advertisedDevice.getServiceUUID().toString().c_str());
    Serial.println(advertisedDevice.getName().c_str());
    if(0 == advertisedDevice.getName().compareTo(XiaomiDeviceName)){
      Serial.println("Great, Found " + advertisedDevice.getName());
      Serial.println("advertisedDevice.getServiceUUIDCount() = " + String(advertisedDevice.getServiceUUIDCount()));
      BLEDevice::getScan()->stop();
      myDevice = new BLEAdvertisedDevice(advertisedDevice);
      doConnect = true;
      doScan = true;
  } // onResult
找到小米设备后,进行连接:
bool connectToServer() {
    Serial.print("Forming a connection to ");
    Serial.println(myDevice->getAddress().toString().c_str());
    BLEClient*  pClient  = BLEDevice::createClient();
    Serial.println(" - Created client");
    pClient->setClientCallbacks(new MyClientCallback());
    // Connect to the remove BLE Server.
    pClient->connect(myDevice);  // if you pass BLEAdvertisedDevice instead of address, it will be recognized type of peer device address (public or private)
    Serial.println(" - Connected to server");
    pClient->setMTU(517); //set client to request maximum MTU from server (default is 23 otherwise)
    // Obtain a reference to the service we are after in the remote BLE server.
    BLERemoteService* pRemoteService = pClient->getService(serviceUUID);
    if (pRemoteService == nullptr) {
      Serial.print("Failed to find our service UUID: ");
      Serial.println(serviceUUID.toString().c_str());
      pClient->disconnect();
      return false;
    Serial.println(" - Found our service");
    // Obtain a reference to the characteristic in the service of the remote BLE server.
    pRemoteCharacteristic = pRemoteService->getCharacteristic(charUUID);
    if (pRemoteCharacteristic == nullptr) {
      Serial.print("Failed to find our characteristic UUID: ");
      Serial.println(charUUID.toString().c_str());
      return false;
    Serial.println(" - Found our characteristic");
    // Read the value of the characteristic.
    if(pRemoteCharacteristic->canRead()) {
      String value = pRemoteCharacteristic->readValue();
      Serial.print("The characteristic value was: ");
      Serial.println(value.c_str());
    if(pRemoteCharacteristic->canNotify())
      pRemoteCharacteristic->registerForNotify(notifyCallback);
    connected = true;
    return true;
从小米设备获取到数据,共有5个字节。
static void notifyCallback(
  BLERemoteCharacteristic* pBLERemoteCharacteristic,
  uint8_t* pData,
  size_t length,
  bool isNotify) {
    Serial.print("Notify callback for characteristic ");
    Serial.print(pBLERemoteCharacteristic->getUUID().toString().c_str());
    Serial.print(" of data length ");
    Serial.println(length);
    uint16_t TempVal = pData[1]*256 + pData[0];
    Serial.println("Temperature is: "+ String(TempVal/100) + "." + String(TempVal%100) + " degree");
    uint8_t HumidityVal = pData[2];
    Serial.println("Humidity is: " + String(pData[2]) + "% ");
    uint16_t BatteryVal = pData[4]*256 + pData[3];
    Serial.println("Battery Voltage is: "+ String(BatteryVal/100) + "." + String(BatteryVal%100) + " mV");
    Serial.println();
注意数据为小端模式存储。
5.2日更新:
上文中BLE SERVER notify上来的数据是没有问题的,温湿度值跟实际设备对比也是OK的,但是仔细观察设备启动,首次连接小米设备成功后,直接读取Characteristic的值,竟然是4??
这个肯定是读取的姿势不对,我接下来一番笨丁解牛。
小米温湿度数据格式为:F2 07 4A C3 0A。也就是5个十六进制数据。仔细看当前的直接读取Characteristic值代码:
readValue()方法返回的是String类型变量,更合适的应该是:
uint8_t* test = pRemoteCharacteristic->readRawData();
计算一下使用直接读取数据所对应的温湿度:
代码:
      uint8_t i;
      uint8_t  test_temp_val[5]={0};
      for(i = 0; i < 5; i++){
        if(test != nullptr){
          Serial.print("The characteristic value using readRawData was: ");
          Serial.println(*test);
          test_temp_val = *test;
        }else{
          Serial.println("pRemoteCharacteristic->readRawData() returns NULL PTR");
        test++;
    static uint16_t Test_TempVal = test_temp_val[1]*256 + test_temp_val[0];
    Serial.println("Test Temperature is: "+ String(Test_TempVal/100) + "." + String(Test_TempVal%100) + " degree");
    static uint8_t Test_HumidityVal = test_temp_val[2];
    Serial.println("Test Humidity is: " + String(test_temp_val[2]) + "% ");
    static uint16_t Test_BatteryVal = test_temp_val[4]*256 + test_temp_val[3];
    Serial.println("Test Battery Voltage is: "+ String(Test_BatteryVal/100) + "." + String(Test_BatteryVal%100) + " mV");
参考:
读取小米蓝牙温湿度计2数据 https://www.cnblogs.com/qsbye/p/15913753.html
此帖出自无线连接论坛
C6启动后,会开始扫描周围的BLE设备,此时进行一个判断,设备名称是否为XiaomiDeviceName = "LYWSD03MMC" 不会吧,直接可以读出小米的东西吗?   详情 回复 发表于 2024-5-1 22:49
756
感谢楼主分享的技术内容,有机会一定买块板子动手测试一下这些例子
此帖出自无线连接论坛
7096
不会吧,直接可以读出小米的东西吗?
此帖出自无线连接论坛
可以的大佬,是我太菜了。我尝试扫描周围设备,想直接根据SERVICE UUID来锁定小米温湿度度计2,但可能小米设备的广播报文里面并没有包含serviceUUID("ebe0ccb0-7a0a-4b0c-8a1a-6ff2997da3a6")。所以才直接根据设  详情 回复 发表于 2024-5-2 08:52
136
lugl4313820 发表于 2024-5-1 22:49 C6启动后,会开始扫描周围的BLE设备,此时进行一个判断,设备名称是否为XiaomiDeviceName = "LYWSD03MMC ...
可以的大佬,是我太菜了。我尝试扫描周围设备,想直接根据SERVICE UUID来锁定小米温湿度度计2,但可能小米设备的广播报文里面并没有包含serviceUUID("ebe0ccb0-7a0a-4b0c-8a1a-6ff2997da3a6")。所以才直接根据设备名称来锁定小米设备。
此帖出自无线连接论坛
