1746|2
24
【FireBeetle 2 ESP32 C6】esp32系列芯片对比 [复制链接]
系列
ESP8266
ESP32
ESP32-S2
ESP32-S3
ESP32-C3
ESP32-C6
CPU
Xtensa® single-core 32-bit L106
Xtensa® dual-core 32-bit LX6
Xtensa® single-core 32-bit LX7
Xtensa® dual-core 32-bit LX7
32-bit RISC-V single-core processor
单/双核
时钟频率 (MHz)
160
240
240
240
160
160
封装 (mm)
QFN32 (5*5)
QFN48 (5*5)
QFN56 (7*7)
QFN56 (7*7)
QFN32 (5*5)
QFN40(5*5)
尺寸 (mm)
5*5
5*5
7*7
7*7
5*5
5*5
工作电压 (V)
2.5 ~ 3.6
2.3 ~ 3.6
3.0 ~ 3.6
3.0 ~ 3.6
3.0 ~ 3.6
3.0 ~ 3.6
工作温度 (℃)
-40 ℃ ~ 125 ℃
-40 ℃ ~ 125 ℃
-40 ℃ ~ 105 ℃
-40 ℃ ~ 105 ℃
-40 ℃ ~ 105 ℃
-40 ℃ ~ 105 ℃
市场状态
Mass Production
NRND
Mass Production
Mass Production
Mass Production
Mass Production
ECO
标准件
ECO V1
标准件
标准件
标准件
Wi-Fi
IEEE 802.11 b/g/n; 2.4 GHz; HT20; up to 75 Mbps
IEEE 802.11 b/g/n; 2.4 GHz; HT20/40; up to 150 Mbps
Wi-Fi 6
IEEE 802.11 ax; 2.4 GHz; HT20; up to 150 Mbps
Thread
N/A
N/A
N/A
N/A
N/A
Available
蓝牙
N/A
BR/EDR + Bluetooth LE v4.2
N/A
Bluetooth LE v5.0
Bluetooth LE v5.0
Bluetooth LE v5.3
SRAM (KB)
160
520
320
512
ROM (KB)
128
384
384
320
RTC SRAM (KB)
Flash (MB)
PSRAM (MB)
Flash voltage(V)
3.3
3.3
3.3
3.3
3.3
3.3
ADC
1*10-bit ADC, 1 channel
2*12-bit ADC, 18 channels
2*13-bit ADC, 20 channels
2*12-bit ADC, 20 channels
2*12-bit ADC, 6 channels
1*12-bit ADC, 7 channels
DAC
2*8-bit DAC
2*8-bit DAC
Touch
Temp Sensor
GPIO
34
43
45
22
Strapping GPIO
0, 2, 15
0, 2, 5, 12, 15
0, 45, 46
0, 3, 45, 46
2, 8, 9
GPIO for flash/PSRAM
6, 7, 8, 9, 10, 11 /
27, 28, 29, 30, 31, 32 /
11, 12, 13, 14, 15, 16, 17 /
UART
SPI
SDIO HOST
SDIO SLAVE
I2C
I2S
RMT
1*8 channels
1*4 channels
1*8 channels
1*4 channels
LED PWM
2*8 channels
1*8 channels
1*8 channels
1*6 channels
1*6 channels
MCPWM
USB OTG
Hall
Ethernet
TWAI
JTAG
NO
YES
YES
YES
YES
YES
Camera
N/A
1*DVP 8/16-bit
1*DVP 8/16-bit
1*DVP 8/16-bit
N/A
N/A
TOF
N/A
N/A
YES
N/A
N/A
N/A
蓝牙认证
BT SIG
BT SIG BQB
BT SIG/BT SIG BQB
BQB
Wi-Fi 认证
Wi-Fi Alliance
Wi-Fi Alliance/WPA 3
Thread
环保认证
RoHS/REACH
RoHS/REACH
RoHS/REACH
RoHS/REACH
RoHS/REACH
生态认证
Props 65/Alibaba IOT
Zigbee 认证
Thread 认证
Thread
楼主提供的esp32系列芯片对比内容非常全面,为产品选型提供了有力的参考,非常感谢   详情 回复 发表于 2024-4-27 14:20
7063
版主大大,这表格分析得全面呀,选型最佳手册。
755
