1200|4
GD32F103硬件SPI与EEPROM(M95)实现数据读写 [复制链接]
各位大佬帮我看看这个EEPROM读出为什么没有数据!!!!!!!!!!!!
//////////--------------------------------------初始化------------------------------------------//////////////
void GPIO_Configuration(void)
GPIO_InitTypeDef GPIO_InitStructure;
//GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO | RCC_APB2Periph_GPIOA, ENABLE);
// NSS
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_4 | GPIO_Pin_8 | GPIO_Pin_10;// GPIO_Pin_1--imu1 GPIO_Pin_4--imu2 GPIO_Pin_8--eeprom
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
CS_L_HIGH;
CS_R_HIGH;
CS_eeprom_HIGH;
GPIO_SetBits(GPIOA , GPIO_Pin_10);
void eepromIOConfig(void)
    /* Enable GPIOC and GPIOB clock */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
      /* Configure PB.09 as Input pull-up */
      GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_0;
      GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;  //上拉输入
      GPIO_Init(GPIOB, &GPIO_InitStructure);
      GPIO_SetBits(GPIOB , GPIO_Pin_0);
//这里针是对SPI1的初始化
void SPI1_Init(void)
SPI_InitTypeDef SPI_InitStructure;
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA, ENABLE );//PORTA时钟使能
RCC_APB2PeriphClockCmd( RCC_APB2Periph_SPI1, ENABLE );//SPI1时钟使能
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //PA 5/6/7复用推挽输出
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
GPIO_SetBits(GPIOA,GPIO_Pin_5|GPIO_Pin_7); //PA567 上拉
SPI_Cmd(SPI1, DISABLE);
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //设置SPI单向或者双向的数据模式:SPI设置为双线双向全双工
SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //设置SPI工作模式:设置为主SPI
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //设置SPI的数据大小:SPI发送接收8位帧结构
SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low; //串行同步时钟的空闲状态为低电平
SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge; //串行同步时钟的第1个跳变沿(上升或下降)数据被采样
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //NSS信号由硬件(NSS管脚)还是软件(使用SSI位)管理:内部NSS信号有SSI位控制
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256; //定义波特率预分频的值:波特率预分频值为16
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //指定数据传输从MSB位还是LSB位开始:数据传输从MSB位开始
SPI_InitStructure.SPI_CRCPolynomial = 10; //CRC值计算的多项式
SPI_Init(SPI1, &SPI_InitStructure); //根据SPI_InitStruct中指定的参数初始化外设SPIx寄存器
SPI_Cmd(SPI1, ENABLE); //使能SPI外设
//SPI1_ReadWriteByte(0xff);//启动传输
//////////--------------------------------------EEPROM------------------------------------------//////////////
EepromOperations_t EEPROM_Read(uint8_t* RxData, uint16_t ReadAddr, uint16_t NumByteToRead)
/* We gonna send all commands in one packet of 3 bytes */
uint8_t header[3];
header[0] = EEPROM_READ; // Send "Read from Memory" instruction
header[1] = ReadAddr >> 8; // Send 16-bit address
header[2] = ReadAddr;
// Select the EEPROM: Chip Select low
EEPROM_CS_LOW();
/* Send WriteAddr address byte to read from */
EEPROM_SendInstruction(header, 3);
while (SPI_I2S_GetFlagStatus(SPI1, SPI_I2S_FLAG_RXNE) == RESET); // 读取接收数据
RxData = SPI_I2S_ReceiveData(SPI1);
printf("out RxData=%x\r\n",
RxData);
// Deselect the EEPROM: Chip Select high
EEPROM_CS_HIGH();
return EEPROM_STATUS_COMPLETE;
EepromOperations_t EEPROM_Write(uint8_t* TxData, uint16_t WriteAddr, uint16_t NumByteToWrite)
  uint16_t NumOfPage = 0, NumOfSingle = 0, Addr = 0, count = 0, temp = 0;
  uint16_t sEE_DataNum = 0;
  EepromOperations_t pageWriteStatus = EEPROM_STATUS_PENDING;
  Addr = WriteAddr % EEPROM_PAGE_SIZE;
  count = EEPROM_PAGE_SIZE - Addr;
  NumOfPage =  NumByteToWrite / EEPROM_PAGE_SIZE;
  NumOfSingle = NumByteToWrite % EEPROM_PAGE_SIZE;
  if (Addr == 0) { /* WriteAddr is EEPROM_PAGESIZE aligned  */
    if (NumOfPage == 0) { /* NumByteToWrite < EEPROM_PAGESIZE */
            sEE_DataNum = NumByteToWrite;
      pageWriteStatus = EEPROM_WritePage(TxData, WriteAddr, sEE_DataNum);
      if (pageWriteStatus != EEPROM_STATUS_COMPLETE) {
        return pageWriteStatus;
    } else { /* NumByteToWrite > EEPROM_PAGESIZE */
      while (NumOfPage--) {
        sEE_DataNum = EEPROM_PAGE_SIZE;
        WriteAddr +=  EEPROM_PAGE_SIZE;
        TxData += EEPROM_PAGE_SIZE;
      sEE_DataNum = NumOfSingle;
  } else { /* WriteAddr is not EEPROM_PAGESIZE aligned  */
      if (NumOfSingle > count) { /* (NumByteToWrite + WriteAddr) > EEPROM_PAGESIZE */
        temp = NumOfSingle - count;
        sEE_DataNum = count;
        WriteAddr +=  count;
        TxData += count;
        sEE_DataNum = temp;
      } else {
      NumByteToWrite -= count;
      WriteAddr +=  count;
      TxData += count;
      if (NumOfSingle != 0) {
此帖出自GD32 MCU论坛
看看是不是硬件的写保护那个引脚电平设置错误了,3脚和7脚,需要接VCC,才是关闭数据保持和写保护。   详情 回复 发表于 2024-4-28 10:32
大佬们,帮帮
此帖出自GD32 MCU论坛
大佬们,走过路过看一看,读可以读了,就是写不进去(呜呜呜呜呜)
EepromOperations_t eeprom_WritePage(uint8_t* TxData, uint16_t WriteAddr, uint16_t NumByteToWrite){
      /* We gonna send commands in one packet of 3 bytes */
  uint8_t header[3];
    u8 i;
  header[0] = EEPROM_WRITE;   // Send "Write to Memory" instruction
  header[1] = WriteAddr >> 8; // Send 16-bit address
  header[2] = WriteAddr;
    sEE_WriteEnable();
//    sEE_WriteStatusRegister(NULL);
//    sEE_WriteEnable();
  EEPROM_CS_LOW();
    for(i=0;i<3;i++){
    SPI1_ReadWriteByte(header[ i ]);
    for(i=0;i<NumByteToWrite;i++){
  SPI1_ReadWriteByte(*(TxData+i));
    M95xx_DelayMs(1);
    EEPROM_CS_HIGH();
    M95xx_DelayMs(10);
  // Wait the end of EEPROM writing
  EEPROM_WaitStandbyState();
  // Disable the write access to the EEPROM
  sEE_WriteDisable();
    M95xx_DelayMs(10);
这是写入的新函数
此帖出自GD32 MCU论坛
363
此帖出自GD32 MCU论坛
дЩ   ед   лл  详情 回复 发表于 2024-4-30 09:52
hjl2832 2024-4-28 10:32 谢谢楼上的大佬   已经解决了  不是写保护的问题  那些我之前全测过了都没有问题
此帖出自GD32 MCU论坛
