3313|0
82
#AI挑战营第一站#基于pytorch模型mnist数据及训练测试 [复制链接]
环境
数据准备
data_train = MNIST('./data/mnist',
                   download=True,
                   transform=transforms.Compose([
                       transforms.Resize((32, 32)),
                       transforms.ToTensor()]))
data_test = MNIST('./data/mnist',
                  train=False,
                  download=True,
data_train_loader = DataLoader(data_train, batch_size=256, shuffle=True, num_workers=8)
data_test_loader = DataLoader(data_test, batch_size=1024, num_workers=8)
LeNet模型构建
卷积神将网络的计算公式为:
N=(W-F+2P)/S+1
其中
N:输出大小
W:输入大小
F:卷积核大小
P:填充值的大小
S:步长大小
net = nn.Sequential(
    nn.Conv2d(in_channels=1, out_channels=6, kernel_size=(5,5)), #卷积层提特征,6*28*28
    nn.Sigmoid(), #激活函数:多项式提供非线性
    nn.AvgPool2d(kernel_size=(5,5), stride=2), #下采样,(28-5+2*0)/2+1=>6*12*12
    nn.Conv2d(in_channels=6, out_channels=16, kernel_size=(5,5)),#16*8*8
    nn.Sigmoid(),
    nn.AvgPool2d(kernel_size=(5,5), stride=2),#(8-5+2*0)/2+1=>16*2*2
    nn.Flatten(),
    nn.Linear(16*2*2, 120), nn.Sigmoid(),#全连接:固定特征维度,激活函数:提供非线性网络
    nn.Linear(120, 84), nn.Sigmoid(),
    nn.Linear(84, 10)
训练
def train(epoch):
    net.train() #训练模式
    loss_list, batch_list = [], []
    for i, (images, labels) in enumerate(data_train_loader):
        optimizer.zero_grad()
        output = net(images) #喂数据
        loss = criterion(output, labels) #计算loss
        loss_list.append(loss.detach().cpu().item())
        batch_list.append(i+1)
        loss.backward() #返传
        optimizer.step() #优化器参数迭代
模型验证及转换
def test(epoch):
    net.eval() #测试模式
    total_correct = 0
    avg_loss = 0.0
    for i, (images, labels) in enumerate(data_test_loader):
        avg_loss += criterion(output, labels).sum()
        pred = output.detach().max(1)[1]
        total_correct += pred.eq(labels.view_as(pred)).sum()
    avg_loss /= len(data_test)
    print('Test Avg. Loss: %f, Accuracy: %f' % (avg_loss.detach().cpu().item(), float(total_correct) / len(data_test)))
    torch.save(net.state_dict(), "pth/epoch{}_accuracy{}.pth".format(epoch, float(total_correct) / len(data_test)))
    dummy_input = torch.randn(1, 1, 32, 32, requires_grad=True) #batch_size=1,channels=1,w*h=32*32
    torch.onnx.export(net, dummy_input, "lenet.onnx") #先推理后根据tensor把模型图变成静态
    onnx_model = onnx.load("lenet.onnx")
    onnx.checker.check_model(onnx_model) #检查onnx模型
验证输出结果: Test Avg. Loss: 0.000170, Accuracy: 0.945300
模型图
小结
基于经典的LeNet进行MNIST数据集训练及验证,学习了整体流程.
模型见附件.
epoch15_accuracy0.9453.pth
87.32 KB, 下载次数: 0
lenet.onnx
85.18 KB, 下载次数: 0
点赞 关注(1)
