936|1
#AI挑战营第一站# 利用pytorch进行手写数字模型训练的训练和转换 [复制链接]
安装pytorch
加载程序库
import torch
import os
import numpy as np
import torch.nn as nn
import torch.optim as optim
from torch.utils.data import DataLoader, random_split
from torchvision import datasets, transforms
定义超参数
input_size = 1 * 28 * 28
num_classes = 10
num_epochs = 20
batch_size = 256
learning_rate = 0.0001
定义CNN模型
class CNN(nn.Module):
    def __init__(self):
        super(CNN, self).__init__()
        self.layer1 = nn.Sequential(
            nn.Conv2d(1, 32, kernel_size=5, stride=1, padding=2),
            nn.ReLU(),
            nn.MaxPool2d(kernel_size=2, stride=2))
        self.layer2 = nn.Sequential(
            nn.Conv2d(32, 64, kernel_size=5, stride=1, padding=2),
            nn.ReLU(),
        self.drop_out = nn.Dropout()
        self.fc1 = nn.Linear(7 * 7 * 64, 1000)
        self.fc2 = nn.Linear(1000, num_classes)
    def forward(self, x):
        out = self.layer1(x)
        out = self.layer2(out)
        out = out.reshape(out.size(0), -1)
        out = self.drop_out(out)
        out = self.fc1(out)
        out = self.fc2(out)
        return out
 训练模型
    # 训练循环
    for epoch in range(num_epochs):
        model.train()  # 设置模型为训练模式
        running_loss = 0.0
        corrects = 0
        for inputs, labels in train_loader:
            optimizer.zero_grad()  # 清空之前的梯度
            outputs = model(inputs)  # 获取模型输出
            loss = criterion(outputs, labels)  # 计算损失
            loss.backward()  # 反向传播计算梯度
            optimizer.step()  # 使用优化器更新权重
            _, preds = torch.max(outputs, 1)  # 获取预测结果
            corrects += torch.sum(preds == labels.data)  # 计算正确预测的数量
            running_loss += loss.item()  # 累加损失
        epoch_loss = running_loss / len(train_loader)
        epoch_acc = corrects.double() / train_total
        # 验证模型性能
        model.eval()  # 设置模型为评估模式
        val_loss = 0.0
        val_corrects = 0
        with torch.no_grad():  # 不计算梯度
            for inputs, labels in val_loader:
                val_loss += loss.item()
                val_corrects += torch.sum(preds == labels.data)
        val_loss = val_loss / len(val_loader)
        val_acc = val_corrects.double() / val_total
        # 打印训练结果和验证结果
        print(
            f'Epoch {epoch + 1}/{num_epochs}, Loss: {epoch_loss:.4f}, Train Acc: {epoch_acc:.4f}, Val Loss: {val_loss:.4f}, Val Acc: {val_acc:.4f}')
        # 如果当前验证准确率比之前的最佳准确率要好,保存当前权重
        if val_acc > best_acc:
            best_acc = val_acc
            best_model_wts = model.state_dict()  # 获取模型权重
测试模型
 def test():
     network.eval()
     test_loss = 0
     correct = 0
         for data, target in test_loader:
             output = network(data)
             pred = output.data.max(1, keepdim=True)[1]
model.onnx (88.09 KB, 下载次数: 1)
mnist_cnn_model.pth (12.21 MB, 下载次数: 0)
此帖出自ARM技术论坛
RE: #AI挑战营第一站# 利用pytorch进行手写数字模型训练的训练和转换
测试模型
def test(model, device, test_loader):
    model.eval()
    test_loss = 0
    correct = 0
            data, target = data.to(device), target.to(device)
            output = model(data)
            test_loss += F.nll_loss(output, target, reduction='sum').item()  # sum up batch loss
            pred = output.argmax(dim=1, keepdim=True)  # get the index of the max log-probability
            correct += pred.eq(target.view_as(pred)).sum().item()
    test_loss /= len(test_loader.dataset)
    print('\nTest set: Average loss: {:.4f}, Accuracy: {}/{} ({:.0f}%)\n'.format(
        test_loss, correct, len(test_loader.dataset),
        100. * correct / len(test_loader.dataset)))
训练模型测试结果:
此帖出自ARM技术论坛
