2950|0
icmpv6 NS 检测地址冲突出错怎么办? [复制链接]
int icmpv6_NS(char *pIfname, struct in6_addr *dst)
    int sockfd      = -1;
    int sockopt = 0;
    int rc = 0;
    char buff[512] = {0};
    int len = 0;
    struct sockaddr_in6 multi_addr;
    struct ipv6_mreq mreq6;
    struct nd_neighbor_solicit *ns_pkt;
    fd_set rset;
    struct timeval timeout;
    if((NULL == pIfname) || (NULL == dst))
        return -1;
    sockfd = socket(AF_INET6, SOCK_RAW, IPPROTO_ICMPV6);
    if(sockfd <= 0)
        printf("NS icmpv6 socket create error!\r\n");
        return -1;
    sockopt = offsetof(struct icmp6_hdr, icmp6_cksum);
    if(2 != sockopt)
        perror("icmp_cksum offset error\r\n");
        close(sockfd);
        return -1;
    if(setsockopt(sockfd, SOL_RAW, IPV6_CHECKSUM, &sockopt, sizeof(sockopt)) < 0)
        perror("icmp_cksum set error\r\n");
        close(sockfd);
        return -1;
    /*ns packet*/
    ns_pkt = (struct nd_neighbor_solicit*)buff;
    ns_pkt->nd_ns_type      = ND_NEIGHBOR_SOLICIT;
    ns_pkt->nd_ns_code      = 0;
    ns_pkt->nd_ns_reserved  = 0;
    memcpy(&ns_pkt->nd_ns_target, dst, sizeof(struct in6_addr));
    multi_addr.sin6_family = AF_INET6;
    //get node multi_addr
    inet_pton(AF_INET6, "FF02::1:FF00:0", &multi_addr.sin6_addr);
    multi_addr.sin6_addr.s6_addr[13] = dst->s6_addr[13];
    multi_addr.sin6_addr.s6_addr[14] = dst->s6_addr[14];
    multi_addr.sin6_addr.s6_addr[15] = dst->s6_addr[15];
    //join group
    memcpy(&mreq6.ipv6mr_multiaddr, &multi_addr.sin6_addr,sizeof(struct in6_addr));
    mreq6.ipv6mr_interface = if_nametoindex(pIfname);
    setsockopt(sockfd, IPPROTO_IPV6, IPV6_JOIN_GROUP, &mreq6, sizeof(mreq6));
    //set multicast hops to 255
    sockopt = 255;
    setsockopt(sockfd, IPPROTO_IPV6, IPV6_MULTICAST_HOPS, &sockopt, sizeof(int));
    //send data
    len = sendto(sockfd, buff, sizeof(struct nd_neighbor_solicit), 0, (struct sockaddr*)&multi_addr, sizeof(struct sockaddr_in6));
    printf("len is %d\r\n", len);
    perror("len is \r\n");
    //recv
    timeout.tv_sec    = 2;
    timeout.tv_usec    = 0;
    FD_ZERO(&rset);
    FD_SET(sockfd, &rset);
    rc = select(sockfd+1,&rset,NULL,NULL,&timeout);
    len = recv(sockfd, buff, sizeof(buff), 0);
    while(1)
        FD_ZERO(&fdset);
        FD_SET(sockfd_rec, &fdset);
        rc = select(sockfd_rec + 1, &fdset, NULL, NULL, &tm);
        if(rc == 0)
            printf("----------time out\r\n");
            break;
        else if(rc > 0)
            //recvfrom(sockfd, );
            len = recv(sockfd_rec, buff, sizeof(buff), 0);
            break;
    //leave the group
    setsockopt(sockfd, IPPROTO_IPV6, IPV6_LEAVE_GROUP, &mreq6, sizeof(mreq6));
    close(sockfd);
    return 0;
这段代码是检测地址冲突的,
当使用select时,sendto发送失败,为什么?
