5830|10
ARM&WINCE 多通道数据采集驱动实现思路(求高手指点) [复制链接]
本人要编一个多通道数据采集的驱动程序,硬件采用S3C2410A,操作系统是wince,开发工具是PB。第一次接触这些东西,思路有些乱:
     数据采集的频率由S3C2410A自带的PWM Timer实现,通过设置PMW寄存器的预分频值、分频值、TCNTB0, TCMPB0,输出一定频率和脉宽的波形,在脉宽的下降沿触发中断,该中断触发线程,将中断与事件关联,实现AD转换。在调用的AD转换函数中实现采样数据读取,放入缓存,更改采样通道的设置。
     在ADC_Init()中应用VirtualAlloc()和VirtualCopy()完成物理地址映射成虚拟地址,需要该操作的寄存器有PWM、ADC、GPIO,不确定是否涉及INT。线程函数也放在这里。
DWORD ADC_Init(DWORD dwcontext)
DWORD IDThread;
RETAILMSG( 1, (TEXT("Initialing pADCIOreg!\r\n")));
//分配空间
pADCIOreg = ( ADCreg * )VirtualAlloc( 0, sizeof(ADCreg), MEM_RESERVE, PAGE_NOACCESS );
if( !pADCIOreg )
  RETAILMSG( 1, (TEXT("Unable to alloc memory for ADCIOreg!\r\n")));
  return NULL;
if( !VirtualCopy((PVOID)pADCIOreg, (PVOID)(ADC_BASE), sizeof(ADCreg),
     PAGE_READWRITE | PAGE_NOCACHE ))
  RETAILMSG(1, (TEXT("For ADCIOreg, virtual copy failed!\r\n")));
  return NULL;
pPWMIOreg = ( PWMreg * )VirtualAlloc( 0, sizeof(PWMreg), MEM_RESERVE, PAGE_NOACCESS );     //PWMreg,结构体,定义在s2410.h中
if( !pPWMIOreg )
  RETAILMSG( 1, (TEXT("Unable to alloc memory for PWMIOreg!\r\n")));
  return NULL;
if( !VirtualCopy((PVOID)pPWMIOreg, (PVOID)(PWM_BASE), sizeof(PWMreg),
  RETAILMSG(1, (TEXT("For PWMIOreg, virtual copy failed!\r\n")));
  return NULL;
pIOPIOreg = ( IOPreg * )VirtualAlloc( 0, sizeof(IOPreg), MEM_RESERVE, PAGE_NOACCESS );
if( !pIOPIOreg )
  RETAILMSG( 1, (TEXT("Unable to alloc memory for IOPIOreg!\r\n")));
  return NULL;
if( !VirtualCopy((PVOID)pIOPIOreg, (PVOID)(IOP_BASE), sizeof(IOPreg),
  RETAILMSG(1, (TEXT("For IOPIOreg, virtual copy failed!\r\n")));
  return NULL;
pINTIOreg = ( INTreg * )VirtualAlloc( 0, sizeof(INTreg), MEM_RESERVE, PAGE_NOACCESS );         ???????????????????????????????
if( !pINTIOreg )
  RETAILMSG( 1, (TEXT("Unable to alloc memory for INTIOreg!\r\n")));
  return NULL;
if( !VirtualCopy((PVOID)pINTIOreg, (PVOID)(INT_BASE), sizeof(INTreg),
  RETAILMSG(1, (TEXT("For INTIOreg, virtual copy failed!\r\n")));
  return NULL;
if(!KernelIoControl(IOCTL_HAL_REQUEST_SYSINTR,&g_ADCIrq,sizeof(UINT32),&g_ADCIrq,sizeof(UINT32),NULL))           //在底层调用OAL层实现的OEMIoContorl函数
  RETAILMSG(1,(TEXT("ERROR:EINTKey:Failed to request sysintr value for Timer interrupt.\r\n")));
  return(0);
RETAILMSG(1,(TEXT("INFO:EINTKey:Mapped Irq 0x%x to SysIntr 0x%x.\r\n"),g_ADCIrq,g_ADCSysIntr));
gADCIntrThread=CreateThread(0,0,(LPTHREAD_START_ROUTINE)ADCTIMER_IntrThread,0,0,&IDThread);
if(gADCIntrThread==NULL)
  RETAILMSG(1,(TEXT(":::ADC_Init:CreateThread() Fail.\r\n")));
  KernelIoControl(IOCTL_HAL_RELEASE_SYSINTR,&g_ADCSysIntr,sizeof(UINT32),NULL,0,NULL);
  return 0;
gADCEvent[0]=CreateEvent(NULL,FALSE,FALSE,NULL);          //创建两个事件
gADCEvent[1]=CreateEvent(NULL,FALSE,FALSE,NULL);
RETAILMSG(1,(TEXT(":::ADC_Init Successfully!\r\n")));
return (DWORD)1;
DWORD ADCTIMER_IntrThread(PVOID pArg)                  //中断服务线程,进行定时器中断时的中断处理
DWORD ret;
gWaitEvent=CreateEvent(NULL,FALSE,FALSE,NULL);
if(!(InterruptInitialize(g_ADCSysIntr,gWaitEvent,0,0)))                   //(1)IST使用InterruptInitialize注册自己,将一个中断和一个事件相关联    ???????????????????????????????
  RETAILMSG(1,(TEXT("ERROR:ADCTIMER:InterruptInitialize failed.\r\n")));
  CloseHandle(gWaitEvent);
  return 0;
while(1)
  ret=WaitForSingleObject(gWaitEvent,INFINITE);     //(2)等待中断请求。线程等待,INFINITE: 无限期等待
  if((ret==WAIT_OBJECT_0)&&(g_KillIST==FALSE))
   SetEvent(gADCEvent[0]);
   RETAILMSG(1,(TEXT(":::it's time to ad convert!\r\n")));
  else
   RETAILMSG(1,(TEXT(":::ADCTIMER_IntrThread exit!\r\n")));
   return 0;
  InterruptDone(g_ADCSysIntr);
return 1;
采样相关的函数主要在ADC_IOControl()中实现。启动AD转换部分不太懂。
BOOL ADC_IOControl(volatile ADCreg* pADCIOreg,DWORD dwCode,PBYTE pBufIn,DWORD dwLenIn,
                   PBYTE pBufOut,DWORD dwLenOut,PDWORD pdwActualOut )
int iDigiValue = 0;
BOOL bErr = FALSE;
DWORD ret;
switch(dwCode)
  case IOCTL_PWM_SET_PRESCALER:
   if (dwLenIn >= 2)                            /* 需要2个字节缓冲区 */
    PWM_SetPrescaler(pBufIn[0], pBufIn[1]);//参一:定时器号,参二:预分频值
    bErr = TRUE;
  break;
  case IOCTL_PWM_SET_DIVIDER:
                bErr = PWM_SetDivider(pBufIn[0], pBufIn[1]);
                // 设置分频值        (定时器编号, 分频值)
     break;
  case IOCTL_PWM_START:        //设置采样率(即:pwm波形频率及占空比)
   if (dwLenIn >= 3)                           /* 需要3个字缓冲区 */
       DWORD t_num = *((DWORD *)pBufIn);
       DWORD cycle = *((DWORD *)(pBufIn + 4));
       DWORD duty = *((DWORD *)(pBufIn + 8));
   // pINTIOreg->rINTMSK&=~(0x1<<10);//不屏蔽timer0的中断,即开timer0的中断
    bErr = PWM_StartPWM(t_num, cycle, duty);//定时器号,TCNTB value,TCMPB value
   break;
  case IOCTL_PWM_GET_FREQUENCY:
   if ((dwLenIn >= 0) && (dwLenOut > 0))
          bErr = PWM_GetFrequency(t_num, (DWORD *)pBufOut);
    *pdwActualOut = 1;
  break;
  case IOCTL_SET_UP:
    ret=WaitForMultipleObjects(2,gADCEvent,FALSE,INFINITE);   //两个同步对象,gADCEvent:指向包含的所有的同步对象,FALSE:只要一个线程处于有信号状态,线程就被唤醒而继续运行。等待时间无限期
    if(ret==WAIT_OBJECT_0)
     ResetEvent(gADCEvent[0]);
     /////////////////启动ad
     iDigiValue = Read_Adc( pADCIOreg,*pBufIn);
     *( int* )pBufOut = iDigiValue;
    else if(ret==(WAIT_OBJECT_0+1))
     ResetEvent(gADCEvent[1]);
   break;
  default:
  break;
int Read_Adc( volatile ADCreg* pADCIOreg,int ch )
RETAILMSG(1, (TEXT("channel:%d\r\n")),ch);
pADCIOreg->rADCCON = (1<<14)|(ch<<3)|(19<<6);  // setup channel (19<<6)是设置你的分频值的,19是根据你的采样频率来设置的。
//pADCIOreg->rADCCON |= 0<<3; // setup channel
pADCIOreg->rADCCON |= 0x1; // start adc
while(pADCIOreg->rADCCON & 0x1); //check if Enable_start is low
while(!(pADCIOreg->rADCCON & 0x8000)); //check if End of Conversion flag is high
return ( (int)pADCIOreg->rADCDAT0 & 0x3ff ); //return the digital value
     望高手帮忙整理一下思路。不胜感激!
顶~~  详情 回复 发表于 2010-6-7 21:51
88
帮顶吧
条理较乱
从程序中并没看到PWM的作用。 没看到你用什么作为采样开始的中断源。
用芯片的timer作中断源不可以么?
也没有用
因为你read_adc是通过轮询来保证转换完成的。
65
你是打算设置PWM输出,然后再输入到外部中断口?我觉得,你不如直接开一个PWM中断,这样还省了一个步骤。
84
引用 2 楼 rushonin 的回复:
条理较乱
用芯片的timer作中断源不可以么?
也没有用
那我用PWM timer做中断源,用什么语句触发中断呢?
90
引用 3 楼 peasant_lee 的回复:
想了一下,就用PWM中断了。
61
闂備礁鎼悮顐﹀磿閸愯鑰块柛娑欐綑鐎氬銇勯幒鍡椾壕缂備焦顨嗛敃銏犵暦濡ゅ懎惟闁宠桨绀佹慨銈夋煟閻橀亶妾烽柛鏂跨箻椤㈡瑩骞嬮敂鑺ユ珫閻庡厜鍋撻柛鎰劤濞堬拷闂備浇鐨崱鈺佹缂傚倸绋勯幏锟�闂備胶鎳撻悺銊╂偋閻愬搫鐒垫い鎺戯攻鐎氾拷婵犵數鍋涢ˇ顓㈠礉瀹€鍕埞闁跨噦鎷�
83
77
快来报名!
