FLASH存储器是嵌入式常见用于存储参数的器件,例如华邦的W25QXX系列,那么本次测评主要使用SPI读写W25Q128 FLASH实验;
一、使用SPI读写
1、AT32 SPI 外设特性
从以上可知最大时钟频率为72M;
2、使用引脚:
PA4---CS;
PA5---CLK
PA6---MISO
PA7---MOSI
使用SPI1引脚;
3、程序编写
.h文件
#ifndef __W25QXX_H
#define __W25QXX_H
#include "at32f435_437.h"
//W25X系列/Q系列芯片列表
//W25Q80 ID 0XEF13
//W25Q16 ID 0XEF14
//W25Q32 ID 0XEF15
//W25Q64 ID 0XEF16
//W25Q128 ID 0XEF17 总共65536页; 每页256字节;
#define W25Q80 0XEF13
#define W25Q16 0XEF14
#define W25Q32 0XEF15
#define W25Q64 0XEF16
#define W25Q128 0XEF17
#define W25QXX_CS_L() gpio_bits_reset(GPIOA, GPIO_PINS_4)
#define W25QXX_CS_H() gpio_bits_set(GPIOA, GPIO_PINS_4)
extern uint16_t W25QXX_TYPE;
extern uint32_t W25QXX_SIZE;
extern uint8_t W25QXX_UID[8];
#define W25X_WriteEnable 0x06
#define W25X_WriteDisable 0x04
#define W25X_ReadStatusReg 0x05
#define W25X_WriteStatusReg 0x01
#define W25X_ReadData 0x03
#define W25X_FastReadData 0x0B
#define W25X_FastReadDual 0x3B
#define W25X_PageProgram 0x02
#define W25X_BlockErase 0xD8
#define W25X_SectorErase 0x20
#define W25X_ChipErase 0xC7
#define W25X_PowerDown 0xB9
#define W25X_ReleasePowerDown 0xAB
#define W25X_DeviceID 0xAB
#define W25X_ManufactDeviceID 0x90
#define W25X_JedecDeviceID 0x9F
int W25QXX_Init(void);
void W25QXX_ReadUniqueID(uint8_t UID[8]);
uint16_t W25QXX_ReadID(void);
uint8_t W25QXX_ReadSR(void);
void W25QXX_Write_SR(uint8_t sr);
void W25QXX_Write_Enable(void);
void W25QXX_Write_Disable(void);
void W25QXX_Write_NoCheck(uint8_t* pBuffer,uint32_t WriteAddr,uint16_t NumByteToWrite);
void W25QXX_Read(uint8_t* pBuffer,uint32_t ReadAddr,uint16_t NumByteToRead);
void W25QXX_Write(uint8_t* pBuffer,uint32_t WriteAddr,uint16_t NumByteToWrite);
void W25QXX_Erase_Chip(void);
void W25QXX_Erase_Sector(uint32_t Dst_Addr);
void W25QXX_Wait_Busy(void);
void W25QXX_PowerDown(void);
void W25QXX_WAKEUP(void);
uint32_t W25QXX_ReadCapacity(void);
#endif
.c文件
* [url=home.php?mod=space&uid=1307177]@File[/url] w25qxx.c
* @brief
#include "w25qxx.h"
#include <stdio.h>
#include "at32f435_437_board.h"
uint16_t W25QXX_TYPE = 0;
uint32_t W25QXX_SIZE = 0;
void SPI_Init(void) {
gpio_init_type gpio_initstructure;
spi_init_type spi_init_struct;
crm_periph_clock_enable(CRM_GPIOA_PERIPH_CLOCK, TRUE);
/* software cs, pd0 as a general io to control flash cs */
gpio_initstructure.gpio_out_type = GPIO_OUTPUT_PUSH_PULL;
gpio_initstructure.gpio_pull = GPIO_PULL_UP;
gpio_initstructure.gpio_mode = GPIO_MODE_OUTPUT;
gpio_initstructure.gpio_drive_strength = GPIO_DRIVE_STRENGTH_STRONGER;
gpio_initstructure.gpio_pins = GPIO_PINS_4;
gpio_init(GPIOA, &gpio_initstructure);
W25QXX_CS_H();
/* sck */
gpio_initstructure.gpio_mode = GPIO_MODE_MUX;
gpio_initstructure.gpio_pins = GPIO_PINS_5;
gpio_pin_mux_config(GPIOA, GPIO_PINS_SOURCE5, GPIO_MUX_5);
/* miso */
gpio_initstructure.gpio_pins = GPIO_PINS_6;
gpio_pin_mux_config(GPIOA, GPIO_PINS_SOURCE6, GPIO_MUX_5);
/* mosi */
gpio_initstructure.gpio_pins = GPIO_PINS_7;
gpio_pin_mux_config(GPIOA, GPIO_PINS_SOURCE7, GPIO_MUX_5);
crm_periph_clock_enable(CRM_SPI1_PERIPH_CLOCK, TRUE);
spi_default_para_init(&spi_init_struct);
spi_init_struct.transmission_mode = SPI_TRANSMIT_FULL_DUPLEX;
spi_init_struct.master_slave_mode = SPI_MODE_MASTER;
spi_init_struct.mclk_freq_division = SPI_MCLK_DIV_32;
spi_init_struct.first_bit_transmission = SPI_FIRST_BIT_MSB;
spi_init_struct.frame_bit_num = SPI_FRAME_8BIT;
spi_init_struct.clock_polarity = SPI_CLOCK_POLARITY_HIGH;
spi_init_struct.clock_phase = SPI_CLOCK_PHASE_2EDGE;
spi_init_struct.cs_mode_selection = SPI_CS_SOFTWARE_MODE;
spi_init(SPI1, &spi_init_struct);
spi_enable(SPI1, TRUE);
//SPI读写一个字节
//TxData:要写入的字节
//返回值:读取到的字节
static uint8_t W25QXX_SPI_ReadWriteByte(uint8_t TxData)
uint8_t RxData = 0X00;
while(spi_i2s_flag_get(SPI1, SPI_I2S_TDBE_FLAG) == RESET);
spi_i2s_data_transmit(SPI1, TxData);
while(spi_i2s_flag_get(SPI1, SPI_I2S_RDBF_FLAG) == RESET);
RxData = spi_i2s_data_receive(SPI1);
return RxData;
//4Kbytes为一个Sector
//16个扇区为1个Block
//W25Q128
//容量为16M字节,共有128个Block,4096个Sector
//初始化SPI FLASH的IO口
SPI_Init();
W25QXX_CS_L(); /* 拉低选中 */
W25QXX_SPI_ReadWriteByte(0XFF);
W25QXX_CS_H(); /* 拉高取消 */
W25QXX_TYPE = W25QXX_ReadID(); // 读取FLASH ID.
printf("W25QXX_Init: W25QXX_TYPE = %x\r\n",W25QXX_TYPE);
W25QXX_SIZE = W25QXX_ReadCapacity(); // 读取容量
printf("W25QXX_Init: W25QXX_TYPE = %d\r\n",W25QXX_SIZE);
W25QXX_ReadUniqueID(W25QXX_UID); // 读取唯一ID
// if((W25QXX_TYPE & 0XEF00) != 0XEF00)
// return -1;
return 0;
//读取W25QXX的状态寄存器
//BIT7 6 5 4 3 2 1 0
//SPR RV TB BP2 BP1 BP0 WEL BUSY
//SPR:默认0,状态寄存器保护位,配合WP使用
//TB,BP2,BP1,BP0:FLASH区域写保护设置
//WEL:写使能锁定
//BUSY:忙标记位(1,忙;0,空闲)
//默认:0x00
uint8_t byte = 0;
W25QXX_CS_L(); //使能器件
W25QXX_SPI_ReadWriteByte(W25X_ReadStatusReg); //发送读取状态寄存器命令
byte = W25QXX_SPI_ReadWriteByte(0Xff); //读取一个字节
W25QXX_CS_H(); //取消片选
return byte;
//写W25QXX状态寄存器
//只有SPR,TB,BP2,BP1,BP0(bit 7,5,4,3,2)可以写!!!
W25QXX_SPI_ReadWriteByte(W25X_WriteStatusReg); //发送写取状态寄存器命令
W25QXX_SPI_ReadWriteByte(sr); //写入一个字节
//W25QXX写使能
//将WEL置位
W25QXX_SPI_ReadWriteByte(W25X_WriteEnable); //发送写使能
//W25QXX写禁止
//将WEL清零
W25QXX_SPI_ReadWriteByte(W25X_WriteDisable); //发送写禁止指令
//读取芯片ID
//返回值如下:
//0XEF13,表示芯片型号为W25Q80
//0XEF14,表示芯片型号为W25Q16
//0XEF15,表示芯片型号为W25Q32
//0XEF16,表示芯片型号为W25Q64
//0XEF17,表示芯片型号为W25Q128
uint16_t Temp = 0;
W25QXX_CS_L();
W25QXX_SPI_ReadWriteByte(0x90); //发送读取ID命令
W25QXX_SPI_ReadWriteByte(0x00);
Temp |= W25QXX_SPI_ReadWriteByte(0xFF) << 8;
Temp |= W25QXX_SPI_ReadWriteByte(0xFF);
W25QXX_CS_H();
return Temp;
int i = 0;
uint8_t arr[4] = {0,0,0,0};
W25QXX_CS_L();
W25QXX_SPI_ReadWriteByte(0x5A);
W25QXX_SPI_ReadWriteByte(0x84);
for(i = 0; i < sizeof(arr); i++)
arr[i] = W25QXX_SPI_ReadWriteByte(0xFF);
W25QXX_CS_H();
return ((((*(uint32_t *)arr)) + 1) >> 3);
int i = 0;
W25QXX_CS_L();
W25QXX_SPI_ReadWriteByte(0x4B);
for(i = 0; i < 8; i++)
UID[i] = W25QXX_SPI_ReadWriteByte(0xFF);
W25QXX_CS_H();
//读取SPI FLASH
//在指定地址开始读取指定长度的数据
//pBuffer:数据存储区
//ReadAddr:开始读取的地址(24bit)
//NumByteToRead:要读取的字节数(最大65535)
void W25QXX_Read(uint8_t *pBuffer, uint32_t ReadAddr, uint16_t NumByteToRead)
uint16_t i;
W25QXX_SPI_ReadWriteByte(W25X_ReadData); //发送读取命令
W25QXX_SPI_ReadWriteByte((uint8_t)((ReadAddr) >> 16)); //发送24bit地址
W25QXX_SPI_ReadWriteByte((uint8_t)((ReadAddr) >> 8));
W25QXX_SPI_ReadWriteByte((uint8_t)ReadAddr);
for (i = 0; i < NumByteToRead; i++)
pBuffer[i] = W25QXX_SPI_ReadWriteByte(0XFF); //循环读数
W25QXX_CS_H();
//SPI在一页(0~65535)内写入少于256个字节的数据
//在指定地址开始写入最大256字节的数据
//pBuffer:数据存储区
//WriteAddr:开始写入的地址(24bit)
//NumByteToWrite:要写入的字节数(最大256),该数不应该超过该页的剩余字节数!!!
void W25QXX_Write_Page(uint8_t *pBuffer, uint32_t WriteAddr, uint16_t NumByteToWrite)
uint16_t i;
W25QXX_Write_Enable(); //SET WEL
W25QXX_SPI_ReadWriteByte(W25X_PageProgram); //发送写页命令
W25QXX_SPI_ReadWriteByte((uint8_t)((WriteAddr) >> 16)); //发送24bit地址
W25QXX_SPI_ReadWriteByte((uint8_t)((WriteAddr) >> 8));
W25QXX_SPI_ReadWriteByte((uint8_t)WriteAddr);
for (i = 0; i < NumByteToWrite; i++)
W25QXX_SPI_ReadWriteByte(pBuffer[i]); //循环写数
W25QXX_Wait_Busy(); //等待写入结束
//无检验写SPI FLASH
//必须确保所写的地址范围内的数据全部为0XFF,否则在非0XFF处写入的数据将失败!
//具有自动换页功能
//在指定地址开始写入指定长度的数据,但是要确保地址不越界!
//pBuffer:数据存储区
//NumByteToWrite:要写入的字节数(最大65535)
//CHECK OK
void W25QXX_Write_NoCheck(uint8_t *pBuffer, uint32_t WriteAddr, uint16_t NumByteToWrite)
uint16_t pageremain;
pageremain = 256 - WriteAddr % 256; //单页剩余的字节数
if (NumByteToWrite <= pageremain)
pageremain = NumByteToWrite; //不大于256个字节
while (1)
W25QXX_Write_Page(pBuffer, WriteAddr, pageremain);
if (NumByteToWrite == pageremain)
break; //写入结束了
else //NumByteToWrite>pageremain
pBuffer += pageremain;
WriteAddr += pageremain;
NumByteToWrite -= pageremain; //减去已经写入了的字节数
if (NumByteToWrite > 256)
pageremain = 256; //一次可以写入256个字节
else
pageremain = NumByteToWrite; //不够256个字节了
//写SPI FLASH
//在指定地址开始写入指定长度的数据
//该函数带擦除操作!
//pBuffer:数据存储区
uint8_t W25QXX_BUFFER[4096];
void W25QXX_Write(uint8_t *pBuffer, uint32_t WriteAddr, uint16_t NumByteToWrite)
uint32_t secpos;
uint16_t secoff;
uint16_t secremain;
uint16_t i;
uint8_t *W25QXX_BUF;
W25QXX_BUF = W25QXX_BUFFER;
secpos = WriteAddr / 4096; //扇区地址
secoff = WriteAddr % 4096; //在扇区内的偏移
secremain = 4096 - secoff; //扇区剩余空间大小
if (NumByteToWrite <= secremain)
secremain = NumByteToWrite; //不大于4096个字节
while (1)
W25QXX_Read(W25QXX_BUF, secpos * 4096, 4096); //读出整个扇区的内容
for (i = 0; i < secremain; i++) //校验数据
if (W25QXX_BUF[secoff + i] != 0XFF)
break; //需要擦除
if (i < secremain) //需要擦除
W25QXX_Erase_Sector(secpos); //擦除这个扇区
for (i = 0; i < secremain; i++) //复制
W25QXX_BUF[i + secoff] = pBuffer[i];
W25QXX_Write_NoCheck(W25QXX_BUF, secpos * 4096, 4096); //写入整个扇区
else
W25QXX_Write_NoCheck(pBuffer, WriteAddr, secremain); //写已经擦除了的,直接写入扇区剩余区间.
if (NumByteToWrite == secremain)
break; //写入结束了
else //写入未结束
secpos++; //扇区地址增1
secoff = 0; //偏移位置为0
pBuffer += secremain; //指针偏移
WriteAddr += secremain; //写地址偏移
NumByteToWrite -= secremain; //字节数递减
if (NumByteToWrite > 4096)
secremain = 4096; //下一个扇区还是写不完
else
secremain = NumByteToWrite; //下一个扇区可以写完了
//擦除整个芯片
//等待时间超长...
W25QXX_Wait_Busy();
W25QXX_SPI_ReadWriteByte(W25X_ChipErase); //发送片擦除命令
W25QXX_Wait_Busy(); //等待芯片擦除结束
//擦除一个扇区
//Dst_Addr:扇区地址 根据实际容量设置
//擦除一个山区的最少时间:150ms
//监视falsh擦除情况,测试用
Dst_Addr *= 4096;
W25QXX_Wait_Busy();
W25QXX_SPI_ReadWriteByte(W25X_SectorErase); //发送扇区擦除指令
W25QXX_SPI_ReadWriteByte((uint8_t)((Dst_Addr) >> 16)); //发送24bit地址
W25QXX_SPI_ReadWriteByte((uint8_t)((Dst_Addr) >> 8));
W25QXX_SPI_ReadWriteByte((uint8_t)Dst_Addr);
W25QXX_Wait_Busy(); //等待擦除完成
//等待空闲
while ((W25QXX_ReadSR() & 0x01) == 0x01); // 等待BUSY位清空
//进入掉电模式
W25QXX_SPI_ReadWriteByte(W25X_PowerDown); //发送掉电命令
delay_us(3); //等待TPD
//唤醒
W25QXX_SPI_ReadWriteByte(W25X_ReleasePowerDown); // send W25X_PowerDown command 0xAB
delay_us(3); //等待TRES1
4、读写FLASH ID和大小测试
at32_led_toggle(LED2);
delay_ms(1000);
printf("SIZE:%d ID:%x \r\n",W25QXX_ReadCapacity(),W25QXX_ReadID());
5、读写数据测试
if (g_key_flag == 1) {
g_key_flag = 0;
W25QXX_Read(g_readdataBuf,0x200,64);
for (i = 0; i < 64;i++) {
printf("%d ",g_readdataBuf[i]);
printf("WRITE TEST\r\n");
sprintf((char *)g_writedataBuf,"AT32F437ZMT7 Spi Flash read/write demo");
len = strlen((char *)g_writedataBuf);
W25QXX_Write(g_writedataBuf,0x200,len);
printf("WRITE ok\r\n");
printf("READ TEST\r\n");
W25QXX_Read(g_readdataBuf,0x200,len);
for (i = 0; i < len;i++) {
printf("%c",g_readdataBuf[i]);
} else;
二、QSPI读写FLASH
1、QSPI特性
2、QSPI协议说明
3、使用引脚:
PA6---IO0;
PA7---IO1;
PA15---IO2;
PA1---IO3;
PD3---SCK;
PB10---CS;
使用QSPI1引脚;
4、程序编写
主要参考官方EN25Q128例程
.c文件
/** @addtogroup AT32F437_periph_examples
/** @addtogroup 437_QSPI_command_port_using_polling
#define QSPI_FIFO_DEPTH (32*4)
#define FLASH_PAGE_PROGRAM_SIZE 256
qspi_cmd_type w25q128_cmd_config;
void qspi_busy_check(void);
void qspi_write_enable(void);
* [url=home.php?mod=space&uid=159083]@brief[/url] QSPI GPIO init
* @param none
* @retval none
void QSPI_Init(void) {
/* enable the qspi clock */
crm_periph_clock_enable(CRM_QSPI1_PERIPH_CLOCK, TRUE);
crm_periph_clock_enable(CRM_GPIOB_PERIPH_CLOCK, TRUE);
crm_periph_clock_enable(CRM_GPIOD_PERIPH_CLOCK, TRUE);
/* QSPI1_IO0 */
gpio_initstructure.gpio_pull = GPIO_PULL_NONE;
gpio_pin_mux_config(GPIOA, GPIO_PINS_SOURCE6, GPIO_MUX_10);
/* QSPI1_IO1 */
gpio_pin_mux_config(GPIOA, GPIO_PINS_SOURCE7, GPIO_MUX_10);
/* QSPI1_IO2*/
gpio_initstructure.gpio_pins = GPIO_PINS_15;
gpio_pin_mux_config(GPIOA, GPIO_PINS_SOURCE15, GPIO_MUX_10);
/* QSPI1_IO3*/
gpio_initstructure.gpio_pins = GPIO_PINS_1;
gpio_pin_mux_config(GPIOA, GPIO_PINS_SOURCE1, GPIO_MUX_9);
/* QSPI1_SCK*/
gpio_initstructure.gpio_pins = GPIO_PINS_3;
gpio_init(GPIOD, &gpio_initstructure);
gpio_pin_mux_config(GPIOD, GPIO_PINS_SOURCE3, GPIO_MUX_9);
/* QSPI1_CS*/
gpio_initstructure.gpio_pins = GPIO_PINS_10;
gpio_init(GPIOB, &gpio_initstructure);
gpio_pin_mux_config(GPIOB, GPIO_PINS_SOURCE10, GPIO_MUX_9);
* @brief w25q128 cmd read unique_id
* @param qspi_cmd_struct: the pointer for qspi_cmd_type parameter
* @param addr: read start address
* @param counter: read data counter
* @retval none
void w25q128_cmd_read_unique_id(qspi_cmd_type *qspi_cmd_struct)
qspi_cmd_struct->pe_mode_enable = FALSE;
qspi_cmd_struct->pe_mode_operate_code = 0;
qspi_cmd_struct->instruction_code = 0x4B; //快速读指令
qspi_cmd_struct->instruction_length = QSPI_CMD_INSLEN_1_BYTE;
qspi_cmd_struct->address_code = 0;
qspi_cmd_struct->address_length = QSPI_CMD_ADRLEN_0_BYTE;//
qspi_cmd_struct->data_counter = 8;
qspi_cmd_struct->second_dummy_cycle_num = 4;
qspi_cmd_struct->operation_mode = QSPI_OPERATE_MODE_111;
qspi_cmd_struct->read_status_config = QSPI_RSTSC_HW_AUTO;
qspi_cmd_struct->read_status_enable = FALSE;
qspi_cmd_struct->write_data_enable = FALSE;
* @retval none
void w25q128_cmd_read_jedec_id(qspi_cmd_type *qspi_cmd_struct)
qspi_cmd_struct->instruction_code = 0x9F; //读指令
qspi_cmd_struct->data_counter = 4;
qspi_cmd_struct->second_dummy_cycle_num = 0;
* @brief w25q128 cmd read config
* @retval none
void w25q128_cmd_read_config(qspi_cmd_type *qspi_cmd_struct, uint32_t addr, uint32_t counter)
qspi_cmd_struct->pe_mode_operate_code = 0xff;
qspi_cmd_struct->instruction_code = 0xEB; //快速读指令
qspi_cmd_struct->address_code = addr ;
qspi_cmd_struct->address_length = QSPI_CMD_ADRLEN_3_BYTE;//地址长度
qspi_cmd_struct->data_counter = counter;
qspi_cmd_struct->second_dummy_cycle_num = 2;
qspi_cmd_struct->operation_mode = QSPI_OPERATE_MODE_144;//快速读指令;4个IO参与输入输出
* @brief w25q128 cmd write config
* @param addr: write start address
* @param counter: write data counter
* @retval none
void w25q128_cmd_write_config(qspi_cmd_type *qspi_cmd_struct, uint32_t addr, uint32_t counter)
qspi_cmd_struct->instruction_code = 0x32; //Quad Page Program instruction;写一页的数据 256字节
qspi_cmd_struct->address_code = addr;
qspi_cmd_struct->operation_mode = QSPI_OPERATE_MODE_114; //写页;1条指令;1条数据线输出;4条数据线输入
qspi_cmd_struct->write_data_enable = TRUE;
* @brief w25q128 cmd erase config
* @param addr: erase address
* @retval none
void w25q128_cmd_erase_config(qspi_cmd_type *qspi_cmd_struct, uint32_t addr)
qspi_cmd_struct->instruction_code = 0x20; //扇区擦除指令
qspi_cmd_struct->address_length = QSPI_CMD_ADRLEN_3_BYTE; //地址长度为3个字节
qspi_cmd_struct->data_counter = 0;
qspi_cmd_struct->operation_mode = QSPI_OPERATE_MODE_111; //SPI MODE;1条数据线输入;1条数据线输出
* @brief w25q128 cmd wren config
* @retval none
void w25q128_cmd_wren_config(qspi_cmd_type *qspi_cmd_struct)
qspi_cmd_struct->instruction_code = 0x06; //写使能指令
qspi_cmd_struct->read_status_config = QSPI_RSTSC_HW_AUTO; //硬件读状态
* @brief w25q128 cmd rdsr config
* @param qspi_cmd_struct: the pointer for qspi_cmd_type parameter;
* @retval none
void w25q128_cmd_rdsr_config(qspi_cmd_type *qspi_cmd_struct) //读状态寄存器
qspi_cmd_struct->instruction_code = 0x05;
qspi_cmd_struct->read_status_enable = TRUE;
* @param qspi_cmd_struct: the pointer for qspi_cmd_type parameter;cmd 表示读取状态寄存器第几个
* @retval none
void w25q128_cmd_read_sta_reg(qspi_cmd_type *qspi_cmd_struct,uint8_t cmd) //读状态寄存器
qspi_cmd_struct->instruction_code = cmd;
qspi_cmd_struct->data_counter = 1;
* @brief w25q128 cmd wdsr config //读取状态寄存器
* @retval none
void w25q128_cmd_write_sta_reg(qspi_cmd_type *qspi_cmd_struct,uint8_t cmd) //读状态寄存器
* @retval none
uint8_t w25q128_cmd_read_write_sta_data(uint8_t rw, uint8_t cmd, uint8_t dta) //读状态寄存器
uint8_t data = 0;
if (rw) {
w25q128_cmd_read_sta_reg(&w25q128_cmd_config,cmd);
qspi_cmd_operation_kick(QSPI1, &w25q128_cmd_config);
while(qspi_flag_get(QSPI1, QSPI_RXFIFORDY_FLAG) == RESET);
data = qspi_byte_read(QSPI1);
/* wait command completed */
while(qspi_flag_get(QSPI1, QSPI_CMDSTS_FLAG) == RESET);
qspi_flag_clear(QSPI1, QSPI_CMDSTS_FLAG);
return data;
} else {
qspi_write_enable();
w25q128_cmd_write_sta_reg(&w25q128_cmd_config,cmd);
while(qspi_flag_get(QSPI1, QSPI_TXFIFORDY_FLAG) == RESET);
qspi_byte_write(QSPI1, dta);
return 0;
* @brief qspi read unique_id
* @param addr: the address for read
* @param total_len: the length for read
* @param buf: the pointer for read data
* @retval none
void qspi_data_read_unique_id(uint8_t* buf)
uint32_t i, len = 0;
uint32_t total_len = 8;
w25q128_cmd_read_unique_id(&w25q128_cmd_config);
/* read data */
len = total_len;
for(i = 0; i < len; ++i)
*buf++ = qspi_byte_read(QSPI1);
* @retval none
void qspi_data_read_jedec_id(uint8_t* buf)
uint32_t total_len = 4;
w25q128_cmd_read_jedec_id(&w25q128_cmd_config);
/* read data */
len = total_len;
* @brief qspi read data
* @retval none
void qspi_data_read(uint32_t addr, uint32_t total_len, uint8_t* buf)
uint32_t i, len = total_len;
w25q128_cmd_read_config(&w25q128_cmd_config, addr, total_len);
/* read data */
do
if(total_len >= QSPI_FIFO_DEPTH)
len = QSPI_FIFO_DEPTH;
else
len = total_len;
total_len -= len;
}while(total_len);
* @brief qspi write data
* @param addr: the address for write
* @param total_len: the length for write
* @param buf: the pointer for write data
* @retval none
void qspi_data_write(uint32_t addr, uint32_t total_len, uint8_t* buf)
uint32_t i, len;
uint8_t temp = 0;
do
temp = w25q128_cmd_read_write_sta_data(1,READ_STATUS_REG2,0);
// printf("0x%.2x\r\n",temp);//读状态2寄存器
w25q128_cmd_read_write_sta_data(0,WRITE_STATUS_REG2,0x02 | temp);//写状态2寄存器
// printf("0x%.2x\r\n",w25q128_cmd_read_write_sta_data(1,READ_STATUS_REG2,0));//读状态2寄存器
/* send up to 256 bytes at one time, and only one page */
len = (addr / FLASH_PAGE_PROGRAM_SIZE + 1) * FLASH_PAGE_PROGRAM_SIZE - addr;
if(total_len < len)
len = total_len;
w25q128_cmd_write_config(&w25q128_cmd_config, addr, len);
qspi_byte_write(QSPI1, *buf++);
total_len -= len;
addr += len;
qspi_busy_check();
}while(total_len > 0);
* @brief qspi erase data
* @param sec_addr: the sector address for erase
* @retval none
void qspi_erase(uint32_t sec_addr)
w25q128_cmd_erase_config(&w25q128_cmd_config, sec_addr);
qspi_busy_check();
* @brief qspi check busy
* @param none
* @retval none
w25q128_cmd_rdsr_config(&w25q128_cmd_config);
* @brief qspi write enable
* @param none
* @retval none
w25q128_cmd_wren_config(&w25q128_cmd_config);
main.c代码
* @brief main function.
* @param none
* @retval none
int main(void)
uint16_t i = 0;
uint16_t err = 0;
system_clock_config();
at32_board_init();
button_exint_init();
QSPI_Init();
/* switch to cmd port */
qspi_xip_enable(QSPI1, FALSE);
/* set sclk */
qspi_clk_division_set(QSPI1, QSPI_CLK_DIV_4);
/* set sck idle mode 0 */
qspi_sck_mode_set(QSPI1, QSPI_SCK_MODE_3);
/* set wip in bit 0 */
qspi_busy_config(QSPI1, QSPI_BUSY_OFFSET_0);
/* erase */
qspi_erase(0);
while(1)
delay_ms(1000);
g_key_flag = 0;
/* read */
/* 读取Unique ID*/
// qspi_data_read_unique_id(rbuf);
// for (i = 0; i < 8;i++) {
// printf("0x%x \r\n",rbuf[i]);
// /* 读取设备ID和制造商ID*/
// qspi_data_read_jedec_id(rbuf);
// for (i = 0; i < 4;i++) {
qspi_data_read(0, TEST_SIZE, rbuf);
for(i = 0; i < TEST_SIZE; i++)
if(rbuf[i] != 0xFF)
err = 1;
break;
} else {
err = 0;
// printf("err %d\r\n",err);
/* program */
sprintf((char *)g_writedataBuf,"Thanks EEworld;Qspi Flash read/write demo on AT32F437ZMT7 ");
memcpy(wbuf,g_writedataBuf,strlen((char *)g_writedataBuf));
qspi_data_write(0, TEST_SIZE, wbuf);
/* read */
for (i = 2; i < TEST_SIZE;i++) {
printf("%c",rbuf[i]);
} else;
5、验证
1)读写Unique ID和设备ID和制造商ID
2)读写数据
工程文件:
