603|0
【EFM32 Zero Gecko Starter Kit】-2-搭建开发环境 [复制链接]
目前SiliconLabs芯片推荐的开发IDE是Simplicity Studio V5,下载安装过程比较漫长。
安装好之后板子通过USB-B - USB A连接至电脑后,可以看到IDE正确识别开发板。
接着新建一个空白工程:
Simplicity studio V5提供了“Software Component”的功能,这里面把常见的硬件外设包括片上的或者板级的外设进行了模块化。
比如通过搜索LED,然后右上角点击Install,即可进入LED配置界面,比如分配GPIO引脚等。
接下来熟悉一下按键输入触发中断,首先配置按键输入引脚,以及工作模式:
  从原理图可以看出,按键0连接到PC8,按键1连接到PC9。接下来回到Simplicity Studio V5。
点击保存后,自动生成代码:
#include "sl_simple_button.h"
#include "sl_simple_button_btn0_config.h"
#include "sl_simple_button_btn1_config.h"
sl_simple_button_context_t simple_btn0_context = {
  .state = 0,
  .history = 0,
  .port = SL_SIMPLE_BUTTON_BTN0_PORT,
  .pin = SL_SIMPLE_BUTTON_BTN0_PIN,
  .mode = SL_SIMPLE_BUTTON_BTN0_MODE,
const sl_button_t sl_button_btn0 = {
  .context = &simple_btn0_context,
  .init = sl_simple_button_init,
  .get_state = sl_simple_button_get_state,
  .poll = sl_simple_button_poll_step,
  .enable = sl_simple_button_enable,
  .disable = sl_simple_button_disable,
sl_simple_button_context_t simple_btn1_context = {
  .state = 0,
  .history = 0,
  .port = SL_SIMPLE_BUTTON_BTN1_PORT,
  .pin = SL_SIMPLE_BUTTON_BTN1_PIN,
  .mode = SL_SIMPLE_BUTTON_BTN1_MODE,
const sl_button_t sl_button_btn1 = {
  .context = &simple_btn1_context,
// the table of buttons and button count are generated as a
// convenience for the application
const sl_button_t *sl_simple_button_array[] = {
  &sl_button_btn0,
  &sl_button_btn1
const uint8_t simple_button_count = 2;
void sl_simple_button_init_instances(void)
  sl_button_init(&sl_button_btn0);
  sl_button_init(&sl_button_btn1);
void sl_simple_button_poll_instances(void)
  sl_button_poll_step(&sl_button_btn0);
  sl_button_poll_step(&sl_button_btn1);
对于按键中断处理与液晶显示:
 * Callback on button change.
 * This function overrides a weak implementation defined in the simple_button
 * module. It is triggered when the user activates one of the buttons.
void sl_button_on_change(const sl_button_t *handle)
  if (sl_button_get_state(handle) == SL_SIMPLE_BUTTON_PRESSED) {
    if (&BUTTON_INSTANCE_0 == handle) {
      currentLine = 0;
      GLIB_clear(&glibContext);
    } else if (&BUTTON_INSTANCE_1 == handle) {
      GLIB_drawStringOnLine(&glibContext,
                            "BtnPressed!",
                            currentLine++,
                            GLIB_ALIGN_LEFT,
                            5,
                            5,
                            true);
    DMD_updateDisplay();
实物测试:
待完善。
此帖出自单片机论坛
点赞 关注(1)
