[PPP:5] pppDispatch[0]: ipcp in nBuf len=22
fsm_input(IPCP):3,2,22
fsm_rconfnakrej(IPCP): Rcvd id 2 state=8
local IP address 10.59.56.130
primary DNS address 211.136.20.203
secondary DNS address 211.136.17.107
7E FF 03 80 21 01 03 00 16 03 06 0A 3B 38 82 81 06 D3 88 14 CB 83 06 D3 88 7D 31 6B 12 14 7E ppp [0] Write len=31
fsm_sdata(IPCP): Sent code 1,序号 3,长度 22.
IPCP: sending Configure-Request, id 3
--------------------------------------------------parse one packet
fsm_input(IPCP):2,3,22
Receive Configure-Ack(IPCP): Rcvd id 3 state=8
np_up: 0 proto=21
network protocol has come up: maxconnect=0 idle_time_limit=0
ipcp: Configure the IP network interface up
[PPP:5] sifvjcomp: VJ compress enable=0 slot=0 max slot=0
[PPP:5] Config the interface up and enable IP packets to pass sifup[0]: ok
[IP:5] ipSetDefault: 10.59.56.130 192.168.254.254 1 0
ppp subsystem init ok[TCP:0] tcpOpen[0]: Opened
[TCP:0] tcpBind[0]: to 0.0.0.0:5000 mss 0
[IP:5] ipMTU: dst 218.107.30.198 => 512
[TCP:0] tcpConnect[0]: to 218.107.30.198:2000 mss 472
[TCP:0] setState[0]: SYN_SENT from CLOSED
[TCP:1] tcpOutput[0]: Timer 63 in SYN_SENT bo=0 md=0 srtt=500
[TCP:0] tcpOutput[0]: 10.59.56.130:5000->218.107.30.198:2000 0@553908780
[TCP:0] out SYN 0 win 512
[TCP:2] out IP: H
[TCP:2] out TCP: H
[IP:5] ipDispatch: len 44 proto 6 to 218.107.30.198 from 10.59.56.130 tos 0
[PPP:7] pppOutput[0]: proto=0x21 len=0
7E 21 45 00 00 2C 00 01 00 00 40 06 3E DD 0A 3B 38 82 DA 6B 1E C6 7D 33 88 07 D0 21 03 FA 2C 00 00 00 00 60 02 02 00 27 8C 00 00 02 04 01 D8 0F 89 7E
[PPP:7] pppInProc[0]: got 45 bytes
[PPP:7] pppInProc[0]: got 5 bytes
[PPP:7] pppDispatch[0]: ip in nBuf len=44
[IP:5] ipDispatch: len 44 proto 6 to 10.59.56.130 from 218.107.30.198 tos 0
[TCP:0] tcpInput[0]: 218.107.30.198:2000->10.59.56.130:5000 0@2038524395
[TCP:0] ACK+SYN 553908781 win 16384
[TCP:2] IP: H
[TCP:2] TCP: H
[TCP:2] tcbUpdate[0]: send(una=553908781,nxt=553908781,ptr=553908781,wnd=16384)
[TCP:2] tcbUpdate[0]: snd(wl1=2038524395,wl2=553908781)
[TCP:2] tcbUpdate[0]: iss=553908780 cwin=257 sst=65535 res=0 backoff=0
[TCP:2] tcbUpdate[0]: recv(nxt=2038524396,wnd=512,up=0) irs=2038524395 mss=472
[TCP:0] setState[0]: ESTABLISHED from SYN_SENT
[TCP:0] tcpOutput[0]: 10.59.56.130:5000->218.107.30.198:2000 0@553908781
[TCP:0] out ACK 2038524396 win 512
[TCP:2] out IP: H
[TCP:2] out TCP: H
[IP:5] ipDispatch: len 40 proto 6 to 218.107.30.198 from 10.59.56.130 tos 0
7E 21 45 00 00 28 00 02 00 00 40 06 3E E0 0A 3B 38 82 DA 6B 1E C6 7D 33 88 07 D0 21 03 FA 2D 79 81 69 EC 50 10 02 00 57 EF 00 00 4E 7B 7E
[TCP:0] tcpConnect[0]: ESTABLISHED
[TCP:1] tcpWrite[0]: 11:1234567890
[TCP:1] tcpOutput[0]: Timer 86 in ESTABLISHED bo=0 md=125 srtt=437
[TCP:0] tcpOutput[0]: 10.59.56.130:5000->218.107.30.198:2000 11@553908781
[TCP:0] out ACK+PUSH 2038524396 win 512
[TCP:2] out IP: H
[TCP:2] out TCP: H
[TCP:0] out DATA: H
[IP:5] ipDispatch: len 51 proto 6 to 218.107.30.198 from 10.59.56.130 tos 0
7E 21 45 00 00 33 00 03 00 00 40 06 BE 54 0A 3B 38 82 DA 6B 1E C6 7D 33 88 07 D0 21 03 FA 2D 79 81 69 EC 50 18 02 00 4D D7 00 00 31 32 33 34 35 36 37 38 39 30 00 26 86 7E
[PPP:7] pppInProc[0]: got 57 bytes
[PPP:7] pppDispatch[0]: ip in nBuf len=51
[IP:5] ipDispatch: len 51 proto 6 to 10.59.56.130 from 218.107.30.198 tos 0
[TCP:0] tcpInput[0]: 218.107.30.198:2000->10.59.56.130:5000 11@2038524396
[TCP:0] ACK+PUSH 553908781 win 65535
[TCP:2] IP: H
[TCP:2] TCP: H
[TCP:0] DATA: H
[TCP:0] tcpOutput[0]: 10.59.56.130:5000->218.107.30.198:2000 0@553908792
[TCP:0] out ACK 2038524407 win 256
[TCP:2] out IP: H
[TCP:2] out TCP: H
7E 21 45 00 00 28 00 04 00 00 40 06 3E DE 0A 3B 38 82 DA 6B 1E C6 7D 33 88 07 D0 21 03 FA 38 79 81 69 F7 50 10 01 00 58 D9 00 00 E0 67 7E
--------------------------------------------------等到数据进
[TCP:1] tcpRead[0]: 11:1234567890
