346|0
54
集创北方 ICNM8001 HDMI/DISPLAYPORT转eDP/LVDS 4K芯片方案提供技术支持 [复制链接]
Chipone ICNM8001CG监视器控制器结合了两个HDMI 2.0兼容的数字输入接口与
HDCP1.4/HDCP2.2,两个带有HDCP1.4/HDCP2.2的DP1.4数字输入接口,一个高质量的放大/缩小和
收缩引擎、多色屏幕显示(OSD)控制器和许多其他功能。32位微控制器
嵌入式与外部串行闪存。
该ICNM8001CG适用于多个细分市场和显示应用,如显示器,所有功能于一身的PC,
和嵌入式应用。
图1-1系统应用显示了ICNM8001CG系统应用图。
⚫ Support Input/output video format up to 2560 x 1440@100Hz ,1920x1080@180Hz w/o ODC
⚫ Support color depth: input 6/8/10bpc, output 8/10bpc
⚫ Support eDP1.4 and LVDS panel interfaces
⚫ Support customized Power on LOGO
⚫ DisplayPort1.4 receiver
- Support 2 ports of DP1.4 receivers
- Compliant with DisplayPort standard v1.4
- Up to 4-lanes @5.4Gbps, 2.7Gbps and 1.62Gbps for each port
- Support lane swap and P/N swap
- Down-spread spectrum supported (0.5% down spread)
- Support 1Mbps AUX CH
- Only support SST
- Support HDCP1.4 and HDCP2.2
- Normal Link training
- EDID access through AUX channel
- Support DPCD version up to 1.4
- Support Static HDR video
⚫ HDMI2.0 receiver
- Support 2 ports of HDMI2.0 receivers
- Support data lane swap and P/N swap
- Maximum TMDS bit rate 6Gbps
- Minimum TMDS bit rate 250Mbps
- Support HPD output
- Support PRBS31 Check for ATE
- Support static HDR packet receiving
⚫ eDP1.4 transmitter
- Compliant with DisplayPort standard v1.4 and eDP standard v1.4
- Only support SST
⚫ LVDS transmitter
- Support 2/4 port 8bit/10bit, clock frequency up to 150MHz/port
- Support JEIDA and VESA LVDS format mapping
- Support pair swap and P/N swap function
- SSCG max: +-3%, 200KHz
⚫ Audio
- Output: IIS
- Embedded Audio DAC
- Embedded headphone AMP
⚫ Scaling
- Fully programmable zoom ratios
- Independent horizontal/vertical scaling
⚫ Embedded OSD
- Support multi-color RAM font, 1,2 and 4-bit per pixel
- Embedded 32KB SRAM dynamically stores OSD char and font
- Maximum 5 windows
- 256 words x 24bits palette
- Programmable blinking effects for each character
- Support power on logo display
⚫ Video Process
- sRGB/Adobe/DCI-P3 compliance
- EOTF LUT (2084) decoder
- Color mapping BT.2407
- Tone mapping BT.2390
- Support Color Enhancement
- Support CGM
- Support PUC (Panel Uneven Calibration)
- Support LTI/Peaking function Sharpness
- Support 17x17x17 3D LUT
- Support White Balance
- Support Gamma and dither
⚫ Support Adaptive sync, Free-Sync and G-sync function
⚫ Built-in pattern generator for factory mode
⚫ Support shadow EDID inside Chip
⚫ Support External Max 128Mbit Flash is shared for HDCP Key, EDID, LUT and chip configuration
⚫ Support 32bit Internal MCU
⚫ High resolution PWM output, and wide range selectable PWM frequency
⚫ 27MHz Crystal Oscillator
⚫ Power Supply: 3.3V/1.1V
⚫ Power consumption: Max 2.3W
⚫ Package: LQFP216 24*24mm2
