671|1
250
【得捷电子Follow me第4期】基础任务二:主控板建立TCPIP或UDP服务器 [复制链接]
 这部分我们先看UDP协议,UDP他也是有例子的,我们可以查看下。
  • #include <Ethernet.h>
  • #include <EthernetUdp.h>
  • // Enter a MAC address and IP address for your controller below.
  • // The IP address will be dependent on your local network:
  • byte mac[] = {
  •   0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
  • IPAddress ip(192, 168, 2, 177);
  • unsigned int localPort = 8888;      // local port to listen on
  • // buffers for receiving and sending data
  • char packetBuffer[UDP_TX_PACKET_MAX_SIZE];  // buffer to hold incoming packet,
  • char ReplyBuffer[] = "acknowledged";        // a string to send back
  • // An EthernetUDP instance to let us send and receive packets over UDP
  • EthernetUDP Udp;
  • void setup() {
  •   // You can use Ethernet.init(pin) to configure the CS pin
  •   //Ethernet.init(10);  // Most Arduino shields
  •   //Ethernet.init(5);   // MKR ETH shield
  •   //Ethernet.init(0);   // Teensy 2.0
  •   //Ethernet.init(20);  // Teensy++ 2.0
  •   //Ethernet.init(15);  // ESP8266 with Adafruit Featherwing Ethernet
  •   //Ethernet.init(33);  // ESP32 with Adafruit Featherwing Ethernet
  •   Ethernet.init(17);  // WIZnet W5100S-EVB-Pico W5500-EVB-Pico W6100-EVB-Pico
  •   // start the Ethernet
  •   Ethernet.begin(mac, ip);
  •   // Open serial communications and wait for port to open:
  •   Serial.begin(9600);
  •   while (!Serial) {
  •     ; // wait for serial port to connect. Needed for native USB port only
  •   // Check for Ethernet hardware present
  •   if (Ethernet.hardwareStatus() == EthernetNoHardware) {
  •     Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
  •     while (true) {
  •       delay(1); // do nothing, no point running without Ethernet hardware
  •   if (Ethernet.linkStatus() == LinkOFF) {
  •     Serial.println("Ethernet cable is not connected.");
  •   // start UDP
  •   Udp.begin(localPort);
  • void loop() {
  •   // if there's data available, read a packet
  •   int packetSize = Udp.parsePacket();
  •   if (packetSize) {
  •     Serial.print("Received packet of size ");
  •     Serial.println(packetSize);
  •     Serial.print("From ");
  •     IPAddress remote = Udp.remoteIP();
  •     for (int i=0; i < 4; i++) {
  •       Serial.print(remote[i], DEC);
  •       if (i < 3) {
  •         Serial.print(".");
  •     Serial.print(", port ");
  •     Serial.println(Udp.remotePort());
  •     // read the packet into packetBufffer
  •     Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
  •     Serial.println("Contents:");
  •     Serial.println(packetBuffer);
  •     // send a reply to the IP address and port that sent us the packet we received
  •     Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
  •     Udp.write(ReplyBuffer);
  •     Udp.endPacket();
  •   delay(10);
这部分还比较好理解,主要就是创建一个UDP服务,端口是8888,通过电脑软件也建一个UDP服务连接他。
连接目标机器的IP地址和端口。
连接上之后会有反馈。接收信息也会打印的。
网络分析就是看数据段,数据是吻合的。
创建一个UDP服务,端口是8888,通过电脑软件也建一个UDP服务连接他,这是重点,,,   详情 回复 发表于 2024-2-22 07:22
6889
福禄克有奖直播:高精度测温赋能电子制造 报名中!
直播时间:2025年2月28日(周五)上午10:00
直播主题:高精度测温赋能电子制造
小伙伴们儿快来报名直播吧~好礼等你拿!
