看官方教程提供了opencv-mobile的使用,简单易用,浅尝一下
官方教程: opencv-mobile | LUCKFOX WIKI
1、基本测试
创建一个文件夹
mkdir opencvMobile
cd opencvMobile/
下载并解压包,放到创建的文件夹下面
在文件夹下创建新的文件 vi CMakeLists.txt 添加内容,将 <SDK Directory> 修改为自己的 SDK 路径,如 /home/luckfox/luckfox-pico/
project(opencv-mobile-test)
cmake_minimum_required(VERSION 3.5)
set(CMAKE_CXX_STANDARD 11)
SET(CMAKE_C_COMPILER "<SDK Directory>/tools/linux/toolchain/arm-rockchip830-linux-uclibcgnueabihf/bin/arm-rockchip830-linux-uclibcgnueabihf-gcc")
SET(CMAKE_CXX_COMPILER "<SDK Directory>/tools/linux/toolchain/arm-rockchip830-linux-uclibcgnueabihf/bin/arm-rockchip830-linux-uclibcgnueabihf-g++")
set(OpenCV_DIR "${CMAKE_CURRENT_SOURCE_DIR}/opencv-mobile-4.8.1-luckfox-pico/lib/cmake/opencv4")
find_package(OpenCV REQUIRED)
include_directories(${OpenCV_INCLUDE_DIRS})
add_executable(opencv-mobile-test main.cpp)
target_link_libraries(opencv-mobile-test ${OpenCV_LIBS})
创建main vi main.cpp
#include <opencv2/core/core.hpp>
#include <opencv2/highgui/highgui.hpp>
#include <opencv2/imgproc/imgproc.hpp>
#include <unistd.h> // sleep()
int main()
cv::VideoCapture cap;
cap.set(cv::CAP_PROP_FRAME_WIDTH, 320);
cap.set(cv::CAP_PROP_FRAME_HEIGHT, 240);
cap.open(0);
const int w = cap.get(cv::CAP_PROP_FRAME_WIDTH);
const int h = cap.get(cv::CAP_PROP_FRAME_HEIGHT);
fprintf(stderr, "%d x %d\n", w, h);
cv::Mat bgr[9];
for (int i = 0; i < 9; i++)
cap >> bgr[i];
sleep(1);
cap.release();
// combine into big image
cv::Mat out(h * 3, w * 3, CV_8UC3);
bgr[0].copyTo(out(cv::Rect(0, 0, w, h)));
bgr[1].copyTo(out(cv::Rect(w, 0, w, h)));
bgr[2].copyTo(out(cv::Rect(w * 2, 0, w, h)));
bgr[3].copyTo(out(cv::Rect(0, h, w, h)));
bgr[4].copyTo(out(cv::Rect(w, h, w, h)));
bgr[5].copyTo(out(cv::Rect(w * 2, h, w, h)));
bgr[6].copyTo(out(cv::Rect(0, h * 2, w, h)));
bgr[7].copyTo(out(cv::Rect(w, h * 2, w, h)));
bgr[8].copyTo(out(cv::Rect(w * 2, h * 2, w, h)));
cv::imwrite("out.jpg", out);
return 0;
编译
mkdir build
cd build
cmake ..
make
文件夹结构:
在build下就生成了可执行程序
将整个文件夹复制到开发板的root路径下
执行 ./opencv-mobile-test
得到图像
2、opencv4.9支持
github上已经更新到opencv4.9了,浅尝一下区别 nihui/opencv-mobile: The minimal opencv for Android, iOS, ARM Linux, Windows, Linux, MacOS, WebAssembly (github.com)
下载对应的包
解压后也放到刚才的文件夹下,删除build文件夹
修改camkelists.txt
其余步骤相同
使用的做设备 luckfox-pico max + sc3336
4.8.1下的输出
# ./opencv-mobile-test
this device is not whitelisted for jpeg decoder cvi
[ 430.140795] stream_cif_mipi_id0: s_power 1, entity use_count 1
devpath = /dev/video11
driver = rkisp_v7
card = rkisp_mainpath
bus_info = platform:rkisp-vir0
version = 20000
capabilities = 84201000
device_caps = 4201000
fmt = UYVY 4:2:2 59565955
fmt = Y/CbCr 4:2:2 3631564e
fmt = Y/CrCb 4:2:2 3136564e
fmt = Y/CrCb 4:2:0 3132564e
size = 32 x 16 ~ 2304 x 1296 (+8 +8)
fmt = Y/CbCr 4:2:0 3231564e
fmt = Y/CrCb 4:2:0 (N-C) 31324d4e
fmt = Y/CbCr 4:2:0 (N-C) 32314d4e
rkaiq log level ff0
[ 430.324185] stream_cif_mipi_id0: open video, entity use_countt 2
[ 430.324391] stream_cif_mipi_id1: open video, entity use_countt 1
/dev/video11 does not support changing fps
rga_api version 1.9.1_[0]
[ 430.338940] rkisp rkisp-vir0: first params buf queue
[ 430.341360] rkisp_hw ffa00000.rkisp: set isp clk = 198000000Hz
[ 430.341486] rkcif-mipi-lvds: sditf_reinit_mode, mode->rdbk_mode 0, mode->name rkisp-vir0, link_mode 1
[ 430.343320] rkcif-mipi-lvds: stream320 x 240
[0] start streaming
[ 430.343452] rockchip-mipi-csi2 ffa20000.mipi-csi2: stream on, src_sd: baffe55e, sd_name:rockchip-csi2-dphy0
[ 430.343466] rockchip-mipi-csi2 ffa20000.mipi-csi2: stream ON
[ 430.343542] rockchip-csi2-dphy0: dphy0, data_rate_mbps 506
[ 430.343574] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0
[ 430.343587] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0
[ 439.456220] rkcif-mipi-lvds: stream[0] start stopping, total mode 0x2, cur 0x2
[ 439.478307] rockchip-mipi-csi2 ffa20000.mipi-csi2: stream off, src_sd: baffe55e, sd_name:rockchip-csi2-dphy0
[ 439.478359] rockchip-mipi-csi2 ffa20000.mMessageParser process loop exit!
ipi-csi2: stream OFF
[ 439.480935] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream_stop stream stop, dphy0
[ 439.480973] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:0, dpmpp[645]: mpp_buffer: mpi_buf_id = 136, dma_buf_fd = 5
mpp[645]: mpp: mClinetFd 7 open ok attr.chan_id 0
[ 439.481019] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:0, dphy0
[ 439.481238] rkcif-mipi-lvds: stream[0] stopping finished, dma_en 0x0
[ 439.496563] stream_cif_mipi_id1: close video, entity use_count#
# 0
[ 439.496651] stream_cif_mipi_id0: close video, entity use_count 1
[ 439.497314] stream_cif_mipi_id0: s_power 0, entity use_count 0
[ 439.516121] mpp_vcodec: 44: num_chan = 0
[ 439.516219] mpp_vcodec: 103: chan_entry->handle 65722eb9, enc 65722eb9
[ 439.516826] 755: MPP_ENC_SET_CFG in
[ 439.516855] 524: MPP_ENC_SET_RC_CFG bps 0 [0 : 0] fps [1:1] gop 1
4.9.0的输出
this device is not whitelisted for capture cvi
this device is not whitelisted for capture v4l2 awispapi
[ 1681.086395] stream_cif_mipi_id0: s_power 1, entity use_count 1
driver = rkisp_v7
version = 20000
rkaiq log level ff0
[ 1681.269800] stream_cif_mipi_id0: open video, entity use_countt 2
[ 1681.270001] stream_cif_mipi_id1: open video, entity use_countt 1
[ 1681.284710] rkisp rkisp-vir0: first params buf queue
[ 1681.287253] rkisp_hw ffa00000.rkisp: set isp clk = 198000000Hz
[ 1681.287302] rkcif-mipi-lvds: sditf_reinit_mode, mode->rdbk_mode 0, mode->name rkisp-vir0, link_mode 1
[ 1681.289425] rkcif-mipi-lvds: stream[0] start st320 x 240
reaming
[ 1681.289596] rockchip-mipi-csi2 ffa20000.mipi-csi2: stream on, src_sd: baffe55e, sd_name:rockchip-csi2-dphy0
[ 1681.289611] rockchip-mipi-csi2 ffa20000.mipi-csi2: stream ON
[ 1681.289661] rockchip-csi2-dphy0: dphy0, data_rate_mbps 506
[ 1681.289691] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0
[ 1681.289703] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:1, dphy0
[ 1690.398035] rkcif-mipi-lvds: stream[0] start stopping, total mode 0x2, cur 0x2
[ 1690.424739] rockchip-mipi-csi2 ffa20000.mipi-csi2: stream off, src_sd: baffe55e, sd_name:rockchip-csi2-dphy0
[ 1690.424791] rockchip-mipi-MessageParser process loop exit!
csi2 ffa20000.mipi-csi2: stream OFF
[ 1690.427185] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream_stop stream stop, dphy0
[ 1690.427235] rockchip-csi2-dphy csi2-dphmpp[740]: mpp_buffer: mpi_buf_id = 136, dma_buf_fd = 5
ympp[740]: mpp: mClinetFd 7 open ok attr.chan_id 0
[ 1690.427297] rockchip-csi2-dphy csi2-dphy0: csi2_dphy_s_stream stream on:0ioctl IOCTL_FREE_IOMMU_ADDR failed 9 Bad file descriptor
ioctl ION_IOC_FREE failed 9 Bad file descriptor
, dphy0
[ 1690.427546] rkcif# -mipi-lvds: stream[0] stopping finished, dma_en 0x0
[ 1690.439913] stream_cif_mipi_id1: close video, entity use_count 0
[ 1690.440016] stream_cif_mipi_id0: close video, entity use_count 1
[ 1690.440679] stream_cif_mipi_id0: s_power 0, entity use_count 0
[ 1690.459025] mpp_vcodec: 44: num_chan = 0
[ 1690.459126] mpp_vcodec: 103: chan_entry->handle 68c79227, enc 68c79227
[ 1690.459735] 755: MPP_ENC_SET_CFG in
[ 1690.459764] 524: MPP_ENC_SET_RC_CFG bps 0 [0 : 0] fps [1:1] gop 1
3、寻找最大色块
#include <iostream>
#include <vector> // 添加 vector 头文件
#include <opencv2/opencv.hpp>
using namespace cv;
int main()
Mat image = imread("test.jpg"); // 替换为您的图像路径
Mat hsvImage;
cvtColor(image, hsvImage, COLOR_BGR2HSV);
// 定义红色范围
Scalar lowerRed = Scalar(0, 100, 100);
Scalar upperRed = Scalar(10, 255, 255);
// 提取红色物体
Mat redMask;
inRange(hsvImage, lowerRed, upperRed, redMask);
// 查找红色物体的轮廓
std::vector<std::vector<Point>> contours;
findContours(redMask, contours, RETR_EXTERNAL, CHAIN_APPROX_SIMPLE);
// 绘制红色物体的轮廓并计算中心坐标
for (const auto& contour : contours)
drawContours(image, std::vector<std::vector<Point>>{contour}, -1, Scalar(0, 0, 255), 2);
// 计算轮廓的中心坐标
Moments mu = moments(contour, false);
Point2f center = Point2f(mu.m10 / mu.m00, mu.m01 / mu.m00);
// 在图像上绘制中心坐标
circle(image, center, 5, Scalar(255, 255, 255), -1);
// 输出中心坐标
std::cout << "Red object center coordinates: (" << center.x << ", " << center.y << ")" << std::endl;
// 显示结果
imshow("Red Objects", image);
waitKey(0);
return 0;
将测试图片放到和程序同一路径下,执行 ./opencv-mobile-test
输出结果:
Red object center coordinates: (nan, nan)
Red object center coordinates: (245.15, 156.34)
imshow save image to Red Objects.pngwaitKey stub#
