3035|0
66
请高人明示vxworks5.5的82541网卡驱动修改 [复制链接]
 从82543改82541,改了gei82543end.h里的:
#define PRO1000_PCI_DEVICE_ID   0x1001 /* device ID */,
顺便把#define PRO1000_PCI_DEVICE_ID           0x1001 /* device ID */
#define PRO1000F_PCI_SUBSYSTEM_ID       0x1003 /* device subsystem ID */
#define PRO1000T_PCI_SUBSYSTEM_ID       0x1004
#define PRO1000T_PCI_DEVICE_ID          0x1004 /* bizard case */
#define PRO1000F_BOARD                  0x1003 /* backward compatible */
#define PRO1000T_BOARD                  0x1003 /* backward compatible */
都改成82543的1017,这样可以吗,(因为对其他的几个不确定)
另外把sysgei82543.h中的#define PRO1000_543_PCI_DEVICE_ID_T     (0x1001) /* Copper */
#define PRO1000_543_PCI_DEVICE_ID_FT    (0x1004) /* Fiber / Copper */
也改成1017,还有别的要改吗?或者说这样不对??
急求,这个在网上没有找到具体解决办法。请指教!
