4688|0
【复刻】基于Adafruit开源硬件的桌面led阵列小电视 [复制链接]
在学习led阵列控制时发现了Adafruit的桌面led阵列小电视项目,感觉看起来是个很有意思的小项目,于是就尝试复刻下,此贴为复刻过程和注意点的总结。
项目硬件电路部分组件如下
原项目采用了Adafruit的3403 Feather M0 Expres、2946 16x9 Charlieplexed PWM LED Matrix Driver以及2972 LED Charlieplexed Matrix - 9x16 LEDs,实际复刻过程中,我将主控板换成了3405 Huzzah32-ESP32 Feather开发板
2972和2946分别为led阵列和led阵列控制板,阵列控制板使用IS31FL3731,基于iic与主控板通信,控制整个led阵列的显示。控制板和led阵列板采用背对背直插焊接的方式。整个电路非常简洁。
项目还基于Feather开发板的电源使能接口外接了电源开关,并连接了电池,实现了在没有数据线连接开发板时也可正常使用。不过我只是尝试复刻,且没有使用电池的需求,所以并没有制作这一步
此项目需要3D打印的部件比较多,共由10个部件组成
具体安装步骤如下
本项目的示例代码如下(我也不知道为什么这里代码格式是居中的,修改了好几遍都是居中然后我放弃了,复制出来应该格式是没有问题的)
// Animated Commodore PET plaything. Uses the following parts:
//   - Feather M0 microcontroller (adafruit.com/products/2772)
//   - 9x16 CharliePlex matrix (2972 is green, other colors avail.)
//   - Optional LiPoly battery (1578) and power switch (805)
// This is NOT good "learn from" code for the IS31FL3731. Taking a cue from
// our animated flame pendant project, this code addresses the CharliePlex
// driver chip directly to achieve smooth full-screen animation.  If you're
// new to graphics programming, download the Adafruit_IS31FL3731 and
// Adafruit_GFX libraries, with examples for drawing pixels, lines, etc.
// Animation cycles between different effects: typing code, Conway's Game
// of Life, The Matrix effect, and a blank screen w/blinking cursor (shown
// for a few seconds before each of the other effects; to imply "loading").
#include <Wire.h>
#define I2C_ADDR 0x74        // I2C address of Charlieplex matrix
#define WIDTH      16        // Matrix size in pixels
#define HEIGHT      9
#define GAMMA     2.5        // Gamma-correction exponent
uint8_t img[WIDTH * HEIGHT], // 8-bit buffer for image rendering
        bitmap[((WIDTH+7)/8) * HEIGHT], // 1-bit buffer for some modes
        gamma8[256],         // Gamma correction (brightness) table
        page  = 0,           // Double-buffering front/back control
        frame = 0;           // Frame counter used by some animation modes
// More globals later, above code for each animation, and before setup()
// UTILITY FUNCTIONS -------------------------------------------------------
// Begin I2C transmission and write register address (data then follows)
uint8_t writeRegister(uint8_t n) {
  Wire.beginTransmission(I2C_ADDR);
  Wire.write(n); // No endTransmission() - left open for add'l writes
  return 2;      // Always returns 2; count of I2C address + register byte n
// Select one of eight IS31FL3731 pages, or the Function Registers
void pageSelect(uint8_t n) {
  writeRegister(0xFD); // Command Register
  Wire.write(n);       // Page number (or 0xB = Function Registers)
  Wire.endTransmission();
// Set bit at (x,y) in the bitmap buffer (no clear function, wasn't needed)
void bitmapSetPixel(int8_t x, int8_t y) {
  bitmap[y * ((WIDTH + 7) / 8) + x / 8] |= 0x80 >> (x & 7);
// Read bit at (x,y) in bitmap buffer, returns nonzero (not always 1) if set
uint8_t bitmapGetPixel(int8_t x, int8_t y) {
  return bitmap[y * ((WIDTH + 7) / 8) + x / 8] & (0x80 >> (x & 7));
// BLINKING CURSOR / LOADING EFFECT ----------------------------------------
// Minimal animation - just one pixel in the corner blinks on & off,
// meant to suggest "program loading" or similar busy effect.
void cursorLoop() {
  img[0] = (frame & 1) * 255;
// TERMINAL TYPING EFFECT --------------------------------------------------
// I messed around trying to make a random "fake code generator," but it
// was getting out of hand. Instead, the typed "code" is just a bitmap!
const uint16_t codeBits[] = {
  0b1110111110100000,
  0b0011101100000000,
  0b0011011111101000,
  0b0000111111011100,
  0b0000111011100000,
  0b0010000000000000,
  0b0011011111000000,
  0b1000000000000000,
  0b0000000000000000,
  0b1111011010000000,
  0b0011110111110110,
  0b1000000000000000,
  0b0000000000000000,
  0b1110111101000000,
  0b0011101011010000,
  0b0011110111111000,
  0b0011101101110000,
  0b0011011111101000,
  0b0000111011111100,
  0b0010000000000000,
  0b1000000000000000,
  0b0000000000000000,
  0b1110110100000000,
  0b0011011111110100,
  0b0000111101100000,
  0b0010000000000000,
  0b0011110111110000,
  0b0011101111011000,
  0b1000000000000000,
  0b0000000000000000
uint8_t cursorX, cursorY, line;
void typingSetup() {
  cursorX = cursorY = line = 0;
void typingLoop() {
  img[cursorY * WIDTH + cursorX] = // If bit set, "type" random char
    ((codeBits[line] << cursorX) & 0x8000) ? random(32, 128) : 0;
  cursorX++;
  if(!(uint16_t)(codeBits[line] << cursorX)) { // End of line reached?
    cursorX = 0;
    if(cursorY >= HEIGHT-1) { // Cursor on last line?
      uint8_t y;
      for(y=0; y<HEIGHT-1; y++) // Move img[] buffer up one line
        memcpy(&img[y * WIDTH], &img[(y+1) * WIDTH], WIDTH);
      memset(&img[y * WIDTH], 0, WIDTH); // Clear last line
    } else cursorY++;
    if(++line >= (sizeof(codeBits) / sizeof(codeBits[0]))) line = 0;
  img[cursorY * WIDTH + cursorX] = 255; // Draw cursor in new position
// MATRIX EFFECT -----------------------------------------------------------
// Inspired by "The Matrix" coding effect -- 'raindrops' travel down the
// screen, their 'tails' twinkle slightly and fade out.
#define N_DROPS 15
struct {
  int8_t  x, y; // Position of raindrop 'head'
  uint8_t len;  // Length of raindrop 'tail' (not incl head)
} drop[N_DROPS];
void matrixRandomizeDrop(uint8_t i) {
  drop[i].x   = random(WIDTH);
  drop[i].y   = random(-18, 0);
  drop[i].len = random(9, 18);
void matrixSetup() {
  for(uint8_t i=0; i<N_DROPS; i++) matrixRandomizeDrop(i);
void matrixLoop() {
  uint8_t i, j;
  int8_t  y;
  for(i=0; i<N_DROPS; i++) { // For each raindrop...
    // If head is onscreen, overwrite w/random brightness 20-80
    if((drop[i].y >= 0) && (drop[i].y < HEIGHT))
      img[drop[i].y * WIDTH + drop[i].x] = random(20, 80);
    // Move pos. down by one. If completely offscreen (incl tail), make anew
    if((++drop[i].y - drop[i].len) >= HEIGHT) matrixRandomizeDrop(i);
    for(j=0; j<drop[i].len; j++) {     // For each pixel in drop's tail...
      y = drop[i].y - drop[i].len + j; // Pixel Y coord
      if((y  >= 0) && (y < HEIGHT)) {  // On screen?
        // Make 4 pixels at end of tail fade out.  For other tail pixels,
        // there's a 1/10 chance of random brightness change 20-80
        if(j < 4)            img[y * WIDTH + drop[i].x] /= 2;
        else if(!random(10)) img[y * WIDTH + drop[i].x] = random(20, 80);
    if((drop[i].y >= 0) && (drop[i].y < HEIGHT)) // If head is onscreen,
      img[drop[i].y * WIDTH + drop[i].x] = 255;  // draw w/255 brightness
// CONWAY'S GAME OF LIFE ---------------------------------------------------
// The rules: if cell at (x,y) is currently populated, it stays populated
// if it has 2 or 3 populated neighbors, else is cleared.  If cell at (x,y)
// is currently empty, populate it if 3 neighbors.
void lifeSetup() { // Fill bitmap with random data
  for(uint8_t i=0; i<sizeof(bitmap); i++) bitmap[i] = random(256);
void lifeLoop() {
  static const int8_t xo[] = { -1,  0,  1, -1, 1, -1, 0, 1 },
                      yo[] = { -1, -1, -1,  0, 0,  1, 1, 1 };
  int8_t              x, y;
  uint8_t             i, n;
  // Modify img[] based on old contents (dimmed) + new bitmap
  for(i=y=0; y<HEIGHT; y++) {
    for(x=0; x<WIDTH; x++, i++) {
      if(bitmapGetPixel(x, y)) img[i]  = 255;
      else if(img[i] > 28)     img[i] -= 28;
      else                     img[i]  = 0;
  // Generate new bitmap (next frame) based on img[] contents + rules
  memset(bitmap, 0, sizeof(bitmap));
  for(y=0; y<HEIGHT; y++) {
    for(x=0; x<WIDTH; x++) {
      for(i=n=0; (i < sizeof(xo)) && (n < 4); i++)
        n += (img[((y+yo[i])%HEIGHT) * WIDTH + ((x+xo[i])%WIDTH)] == 255);
      if((n == 3) || ((n == 2) && (img[y * WIDTH + x] == 255)))
        bitmapSetPixel(x, y);
  // Every 32 frames, populate a random cell so animation doesn't stagnate
  if(!(frame & 0x1F)) bitmapSetPixel(random(WIDTH), random(HEIGHT));
// MORE GLOBAL STUFF - ANIMATION STATES ------------------------------------
struct { // For each of the animation modes...
  void    (*setup)(void); // Animation setup func (run once on mode change)
  void    (*loop)(void);  // Animation loop func (renders one frame)
  uint8_t maxRunTime;     // Animation run time in seconds
  uint8_t fps;            // Frames-per-second for this effect
} anim[] = {
  NULL       , cursorLoop,  3,  4,
  typingSetup, typingLoop, 15, 15,
  lifeSetup  , lifeLoop  , 12, 30,
  matrixSetup, matrixLoop, 15, 10,
uint8_t  seq[] = { 0, 1, 0, 2, 0, 3 }, // Sequence of animation modes
         idx   = sizeof(seq) - 1;      // Current position in seq[]
uint32_t modeStartTime = 0x7FFFFFFF;   // micros() when current mode started
// SETUP - RUNS ONCE AT PROGRAM START --------------------------------------
void setup() {
  uint16_t i;
  uint8_t  p, bytes;
  randomSeed(analogRead(A0));              // Randomize w/unused analog pin
  Wire.begin();                            // Initialize I2C
  Wire.setClock(400000L);                  // 400 KHz I2C = faster updates
  // Initialize IS31FL3731 directly (no library)
  pageSelect(0x0B);                        // Access the Function Registers
  writeRegister(0);                        // Starting from first...
  for(i=0; i<13; i++) Wire.write(10 == i); // Clear all except Shutdown
  for(p=0; p<2; p++) {                     // For each page used (0 & 1)...
    pageSelect(p);                         // Access the Frame Registers
    for(bytes=i=0; i<180; i++) {           // For each register...
      if(!bytes) bytes = writeRegister(i); // Buf empty? Start xfer @ reg i
      Wire.write(0xFF * (i < 18));         // 0-17 = enable, 18+ = blink+PWM
      if(++bytes >= SERIAL_BUFFER_SIZE) bytes = Wire.endTransmission();
    if(bytes) Wire.endTransmission();      // Write any data left in buffer
  for(i=0; i<256; i++) // Initialize gamma-correction table:
    gamma8[i] = (uint8_t)(pow(((float)i / 255.0), GAMMA) * 255.0 + 0.5);
// LOOP - RUNS ONCE PER FRAME OF ANIMATION ---------------------------------
uint32_t prevTime  = 0x7FFFFFFF; // Used for frame-to-frame animation timing
uint32_t frameUsec = 0L;         // Frame interval in microseconds
void loop() {
  // Wait for FPS interval to elapse (this approach is more consistent than
  // delay() as the animation rendering itself takes indeterminate time).
  uint32_t t;
  while(((t = micros()) - prevTime) < frameUsec);
  prevTime = t;
  // Display frame rendered on prior pass.  This is done immediately
  // after the FPS sync (rather than after rendering) to ensure more
  // uniform animation timing.
  pageSelect(0x0B);    // Function registers
  writeRegister(0x01); // Picture Display reg
  Wire.write(page);    // Page #
  page ^= 1;           // Flip front/back buffer index
  anim[seq[idx]].loop();                     // Render next frame
  frameUsec = 1000000L / anim[seq[idx]].fps; // Frame hold time
  // Write img[] array to matrix thru gamma correction table
  uint8_t i, bytes; // Pixel #, Wire buffer counter
  pageSelect(page); // Select background buffer
  for(bytes=i=0; i<WIDTH*HEIGHT; i++) {
    if(!bytes) bytes = writeRegister(0x24 + i);
    Wire.write(gamma8[img[i]]);
  // Time for new mode?
  if((t - modeStartTime) > (anim[seq[idx]].maxRunTime * 1000000L)) {
    if(++idx >= sizeof(seq)) idx = 0;
    memset(img, 0, sizeof(img));
    if(anim[seq[idx]].setup) anim[seq[idx]].setup();
    modeStartTime = t;
    frame = 0;
  } else frame++;
示例代码没有使用Adafruit官方提供的GFX和IS31FL3731驱动库,直接对IS31FL3731芯片进行寻址操作进行驱动,以达到更好的显示效果
如果是用正常的驱动库的话,则可以轻松在屏幕上显示各种图案,比如下图中的哭脸表情
