nWAIT [Input] nWAIT requests to prolong a current bus cycle. As long as nWAIT is L, th
current bus cycle cannot be completed.
nWAIT PIN OPERATION
If the WAIT bit(WSn bit in BWSCON) corresponding to each memory bank is enabled, the nOE duration should be
prolonged by the external nWAIT pin while the memory bank is active. nWAIT is checked from tacc-1. nOE will be
de-asserted at the next clock after sampling nWAIT is high. The nWE signal have the same relation with nOE.
