553|2
113
【DigiKey“智造万物,快乐不停”创意大赛】基于Arduino Uno R4智能床头灯项目&6调试2 [复制链接]
第二部分调试:蓝牙通讯调试
基于Arduino Uno R4智能床头灯项目中蓝牙版本部分最重要的是蓝牙通信,蓝牙通信可以将手机发送指令传送到智能床头灯系统中
实物图
调试效果:
演示视频:
蓝牙调试
调试代码:
#include <SPI.h>
#include <SoftwareSerial.h>
// 设置灯珠数量
#define NUMPIXELS 8
// 设置SPI输出数据引脚
//#define PIN_NEOPIXEL 11
// LED引脚设置
#define PIN_LED 10
#include <Arduino.h>//驱动多合一SEN44程序
#include <SensirionUartSen44.h>
#define SENSOR_SERIAL_INTERFACE Serial1
SensirionUartSen44 sen44;
SoftwareSerial SoftSerial(D3, D2); // Rx, Tx
unsigned int datenum1=0;
unsigned int incomdate[10];
void printModuleVersions() {
    uint16_t error;
    char errorMessage[256];
    uint8_t firmwareMajor;
    uint8_t firmwareMinor;
    bool firmwareDebug;
    uint8_t hardwareMajor;
    uint8_t hardwareMinor;
    uint8_t protocolMajor;
    uint8_t protocolMinor;
    error = sen44.getVersion(firmwareMajor, firmwareMinor, firmwareDebug,
                             hardwareMajor, hardwareMinor, protocolMajor,
                             protocolMinor);
    if (error) {
        Serial.print("Error trying to execute getVersion(): ");
        errorToString(error, errorMessage, 256);
        Serial.println(errorMessage);
    } else {
        if (firmwareDebug) {
            printf("Development firmware version: ");
        Serial.print("Firmware: ");
        Serial.print(firmwareMajor);
        Serial.print(".");
        Serial.print(firmwareMinor);
        Serial.print(", ");
        Serial.print("Hardware: ");
        Serial.print(hardwareMajor);
        Serial.print(".");
        Serial.print(hardwareMinor);
        Serial.print(", ");
        Serial.print("Protocol: ");
        Serial.print(protocolMajor);
        Serial.print(".");
        Serial.println(protocolMinor);
void printSerialNumber() {
    uint16_t error;
    unsigned char serialNumber[32];
    uint8_t serialNumberSize = 32;
    error = sen44.getSerialNumber(serialNumber, serialNumberSize);
    if (error) {
        Serial.print("Error trying to execute getSerialNumber(): ");
    } else {
        Serial.print("Serial number: ");
        Serial.println((char*)serialNumber);
unsigned char R;
unsigned char G;
unsigned char B;
unsigned long RGB=0XFF00FF;
// 熄灭的数据
unsigned char default_tx0[24] =
    0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, //G
    0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, //R
    0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80  //B
unsigned char WS2812[24] =
// 点亮的数据
unsigned char default_tx1[3][24] = {
  //绿色-G
    0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0x80, 0xf8,
  //红色-R
  //蓝-B
void lgiht_Open()
for (int i = 0; i < 24; i++)
        // 显示数据转换
        if((RGB>>i)&0X01)  { WS2812[23-i]=0xf8; }
          else             { WS2812[23-i]=0x80; }
for (int j = 0; j < 64; j++)
        // 显示
        SPI.transfer(WS2812[i]);
// 当前灯珠指向
int idx = 0;
void lgiht_n(int n)
  for(int i=0;i<NUMPIXELS;i++) {
    if(i==n) {
        // 点亮
        SPI.transfer(default_tx1[ n%3 ][i]);
    } else {
        // 熄灭
        SPI.transfer(default_tx0[i]);
void setup(void)
  SoftSerial.begin(9600);
  // 调试串口速率设置
  Serial.begin(115200);
  Serial1.begin(9600);
  // 设置LED3对应的引脚为输出
  pinMode(PIN_LED, OUTPUT);
pinMode(D6, INPUT);//触摸电路输入
pinMode(LED_BUILTIN, OUTPUT);//LED指示灯I/O引脚
  // 设置SPI时钟频率为6.4MHz,高位先传输,默认操作模式
  SPI.beginTransaction(SPISettings(6400000, MSBFIRST, SPI_MODE0));
  // 系统时钟分频设置方式
  // SPI.begin ();
  // SPI.setClockDivider(SPI_CLOCK_DIV16);//divide the clock by 8
    SENSOR_SERIAL_INTERFACE.begin(115200);
    while (!SENSOR_SERIAL_INTERFACE) {
        delay(100);
sen44.begin(SENSOR_SERIAL_INTERFACE);
sen44.deviceReset();
sen44.startMeasurement();
pinMode(A0, OUTPUT);//负离子发生器模块控制I/O
pinMode(A1, OUTPUT);//涡轮风扇模块控制I/O
pinMode(D2, INPUT);
RGB=0X000000;lgiht_Open();
char inChar;
void loop(void)
  uint16_t CM;//触摸开关
    uint16_t massConcentrationPm1p0;
    uint16_t massConcentrationPm2p5;
    uint16_t massConcentrationPm4p0;
    uint16_t massConcentrationPm10p0;
    float vocIndex;
    float ambientHumidity;
    float ambientTemperature;
    while (SoftSerial.available())
       incomdate[datenum1]= int(SoftSerial.read());
       datenum1=datenum1+1;
    if(datenum1>3)
     switch (incomdate[0])
         case 65:
         RGB=0XFF000F;lgiht_Open();
         break;
         case 66:
         RGB=0XFF0064;lgiht_Open();
         break;
         case 67:
         RGB=0X5000FF;lgiht_Open();
         break;
         case 68:
         RGB=0X0032FF;lgiht_Open();
         break;
         case 69:
         RGB=0X0064FF;lgiht_Open();
         break;
         case 70:
         RGB=0X00FFFF;lgiht_Open();
         break;
         case 71:
         RGB=0X00FF96;lgiht_Open();
         break;
         case 72:
         RGB=0X00FF00;lgiht_Open();
         break;
         case 73:
         RGB=0X2AFF00;lgiht_Open();
         break;
         case 74:
         RGB=0X84FF00;lgiht_Open();
         break;
         case 75:
         RGB=0XFFC800;lgiht_Open();
         break;
         case 76:
         RGB=0XFF6400;lgiht_Open();
         break;
         case 77:
         RGB=0XFF4500;lgiht_Open();
         break;
         case 78:
         RGB=0XFF6347;lgiht_Open();
         break;
         case 79:
         RGB=0XFF2D19;lgiht_Open();
         break;
         case 80:
         RGB=0XC81905;lgiht_Open();
         break;
     datenum1=0;
sen44.readMeasuredMassConcentrationAndAmbientValues(
        massConcentrationPm1p0, massConcentrationPm2p5, massConcentrationPm4p0,
        massConcentrationPm10p0, vocIndex, ambientHumidity, ambientTemperature);
if(massConcentrationPm2p5>76)
   {digitalWrite(A0, HIGH); digitalWrite(A1, HIGH);}//开启负离子净化系统
   else
     {digitalWrite(A0, LOW); digitalWrite(A1, LOW);}//关闭负离子净化系统
    if(massConcentrationPm2p5<35){RGB=0X00F0FF;lgiht_Open();}//0-35ug/m3
      else if(massConcentrationPm2p5<75){RGB=0X00FF00;lgiht_Open();}//36-75ug/m3
          else if(massConcentrationPm2p5<115){RGB=0XFFF000;lgiht_Open();}//76-115ug/m3
              else if(massConcentrationPm2p5<150){RGB=0XFFFF70;lgiht_Open();}//116-150ug/m3
                  else if(massConcentrationPm2p5<250){RGB=0XFF0000;lgiht_Open();}//151-250ug/m3
                        else if(massConcentrationPm2p5<500){RGB=0XF048F0;lgiht_Open();}//251-500ug/m3
 Serial.println(massConcentrationPm2p5);
if (SoftSerial.available())
   inChar+=SoftSerial.read();
   if(inChar==0X40){digitalWrite(A1, HIGH);}
   if(inChar==0X32){digitalWrite(A1, LOW);}
app代码及界面:
逻辑代码块
蓝牙实现的圆板灯听酷炫的   详情 回复 发表于 2024-1-14 10:54
6822
蓝牙实现的圆板灯听酷炫的
都是模块化设计,自己设计灯板太麻烦了  详情 回复 发表于 2024-1-16 22:46
113
Jacktang 发表于 2024-1-14 10:54 蓝牙实现的圆板灯听酷炫的
都是模块化设计,自己设计灯板太麻烦了
