3165|2
GCCAVR下的12864初始化,下载后12864无反应,请各位大侠帮忙指点 [复制链接]
#include
#include
#define Enable_0()  (PORTC&=~_BV(PC2))
#define Enable_1() (PORTC|=_BV(PC2))
#define RW_0()     (PORTC&=~_BV(PC1))
#define RW_1()     (PORTC|=_BV(PC1))
#define Di_0()     (PORTC&=~_BV(PC0))
#define Di_1()     (PORTC|=_BV(PC0))
#define reset_0()     (PORTC&=~_BV(PC5))
#define reset_1()     (PORTC|=_BV(PC5))
#define Lcd_Bus PORTA  //连接液晶的八位总线
//-----------------------液晶相关-------------------------------
#define Disp_On  0x3f        //开显示控制字
#define Disp_Off 0x3e        //关闭显示控制字
#define Col_Add  0x40        //列地址增加量
#define Page_Add 0xb8        //页地址增加量
#define Start_Line 0xc0        //行地址增加量
#define cs1_0()  (PORTC&=~_BV(PC3))
#define cs1_1()  (PORTC|=_BV(PC3))
#define cs2_0()  (PORTC&=~_BV(PC4))
#define cs2_1()  (PORTC|=_BV(PC4))
void init_port();
void write_com(unsigned char cmdcode);
void write_data(unsigned char Dispdata);
void Clr_Scr(void);
//void hz_disp16(unsigned char pag,unsigned char col, unsigned char *hzk);
//void e_disp16(unsigned char pag,unsigned char col, unsigned char *hzk);
void init_lcd(void);
void init_port()
     DDRA=0xff;
     DDRC=0XFF;
//////////////////////////////////////////////  液         晶       显       示      部       分      程        序  ///////////////////////////////////////////////////////
/*------------------写命令到LCD------------------------------*/
    Di_0();
    RW_0();
    Lcd_Bus=cmdcode;
    Enable_1();
    Enable_0();
/*-------------------写数据到LCD----------------------------*/
    Di_1();RW_0();
    Lcd_Bus=Dispdata;_delay_us(0);
    Enable_1();_delay_us(0);
    Enable_0();
void Clr_Scr(void)
    unsigned char j,k;
    cs1_0();cs2_0();
    write_com(Page_Add+0);
    write_com(Col_Add+0);
    for(k=0;k<8;k++)
        write_com(Page_Add+k);
        for(j=0;j<128;j++)
            write_data(0xff);
                        _delay_us(100);
void init_lcd(void)
{   reset_0();
    _delay_us(1);
    reset_1();
    _delay_us(1);
    cs1_1();cs2_1();_delay_us(1);
    write_com(Disp_Off);
    write_com(Start_Line+0);
    write_com(Disp_On);
/*void delay(unsigned int t)
    unsigned int i,j;
    for(i=0;i         for(j=0;j<5;j++);
void main(void)
   init_port();
   init_lcd();
   while(1)
        Clr_Scr();
没用过,帮顶  详情 回复 发表于 2010-4-14 18:50
版主贴主中午好!
版主贴主每天都有好心情!
iCFb5aQHynPayuPMLYfaipj回帖是一种美德!s7f1tDHuNCFRsRbJ8g5skin
介+绍:
[/url]
c8MlrDjCPA88TPV5vydOvbj
1)可录制上网记录,截获Http信息。
2)利用截获的Http信息自动生成命令(Page,拖拽即可完成)
3)执行命令,模拟浏览器向Web服务器发生命令。
中文论坛:[url=http://spritebrowser.com/LunTan]
发现一群美女:
[url=http://byhat.com][/url]
软件创业QQ qun群:103815692
mBWa58yjGPy7GYoS7THErgf
86
没用过,帮顶
