【DigiKey“智造万物,快乐不停”创意大赛】汇总:机器视觉打造全自动老板键智能键盘
汇总一下每个步骤的实现帖子:
【DigiKey“智造万物,快乐不停”创意大赛】1,ESP32S2摄像头开发板设计
【DigiKey“智造万物,快乐不停”创意大赛】2,Pi400 HID 键盘功能的实现
【DigiKey“智造万物,快乐不停”创意大赛】3,Pi400 键盘动作的捕捉与独占
【DigiKey“智造万物,快乐不停”创意大赛】4,人脸识别在Pi400上的实现。
最后我们只需要整合上述功能,就可以实现带有全自动老板键的智能键盘。
完整主程序代码如下:
- import zero_hid
- import evdev
- import csv
- import signal
- import os
- import threading
- if os.geteuid() != 0:
- raise ImportError('You must be root to use this library on linux.')
- k = zero_hid.Keyboard()
- dev = evdev.InputDevice('/dev/input/event0')
- dev.grab()
- with open('./codemap.csv', 'r') as file:
- reader = csv.reader(file)
- codemap = {rows[0]:rows[1] for rows in reader}
- del codemap[""]
- curr_pressed = []
- def key_input(key):
- global curr_pressed
- if isinstance(key, evdev.KeyEvent) and key.keystate != 2:
- if key.keystate == 1:
- curr_pressed.append(key.keycode)
- if key.keystate == 0:
- curr_pressed.remove(key.keycode)
- print("\r" + "CODE: " + key.keycode + " ;STAT: " + str(key.keystate) + " "*40, end="")
- keys = [codemap[i] for i in curr_pressed]
- k.press(keys, additive=False, hold=True)
- def handler(signal, frame):
- k.release_all()
- dev.ungrab()
- dev.close()
- exit()
- signal.signal(signal.SIGTSTP, handler)
- signal.signal(signal.SIGINT, handler)
- def thread1():
- for event in dev.read_loop():
- try:
- key_input(evdev.categorize(event))
- except Exception as error:
- print(error)
- t1 = threading.Thread(target=thread1, daemon=True)
- t1.start()
- from ultralytics import YOLO
- import requests
- url = "http://192.168.8.171"
- model = YOLO("yolov8n.pt")
- requests.get(url+"/control?var=framesize&val=" + str(8))
- results = model.predict(url+":81/stream", stream=True, show=True, conf = 0.5)
- delay = 1
- count = 0
- mode = 0
- pre_mode = 0
- for result in results:
- try:
- for box in result.boxes:
- class_id = result.names[box.cls[0].item()]
- cords = box.xyxy[0].tolist()
- cords = [round(x) for x in cords]
- conf = round(box.conf[0].item(), 2)
- print("Object type:", class_id)
- print("Coordinates:", cords)
- print("Probability:", conf)
- print("---")
- if class_id == "person":
- mode = 1
- count = 0
- if mode != pre_mode:
- pre_mode = mode
- k.press(["MOD_LEFT_ALT","KEY_TAB"], additive=False, hold=False)
- print("triggered!!!")
- count += 1
- if count > delay:
- mode = 0
- pre_mode = mode
- print(error)
项目源码:https://download.eeworld.com.cn/detail/eew_dy9f48/630641
