3541|2
79
怎样对USB设备的其中一个pipe进行读写操作?谢谢!(VB) [复制链接]
我需要与蓝牙设备通信,通过SetupDiGetClassDevs (Guid由注册表找到),SetupDiEnumDeviceInterfaces ,SetupDiGetDeviceInterfaceDetail 函数查找到DevicePath。但是createfile失败。
我需要对这个设备的其中一个pipe读写。在Path后加上“\PIPE2”后createfile,还是失败了。
DeviceInfoSet = SetupDiGetClassDevs _
    (HidGuid, _
    vbNullString, _
    0, _
    (DIGCF_PRESENT Or DIGCF_DEVICEINTERFACE))
'SetupDiEnumDeviceInterfaces
'On return, MyDeviceInterfaceData contains the handle to a
'SP_DEVICE_INTERFACE_DATA structure for a detected device.
'Requires:
'the DeviceInfoSet returned in SetupDiGetClassDevs.
'the HidGuid returned in GetHidGuid.
'An index to specify a device.
'Begin with 0 and increment until no more devices are detected.
MemberIndex = 0
'遍历查找
Do
    'The cbSize element of the MyDeviceInterfaceData structure must be set to
    'the structure's size in bytes. The size is 28 bytes.
    MyDeviceInterfaceData.cbSize = LenB(MyDeviceInterfaceData)
    Result = SetupDiEnumDeviceInterfaces _
        (DeviceInfoSet, _
        0, _
        HidGuid, _
        MemberIndex, _
    '如果是最后一个设备则会返回0,设置LastDevice标志为True
    If Result = 0 Then LastDevice = True
    '如果有设备,则检查是否我们USB接收器
    If Result <> 0 Then
        'SetupDiGetDeviceInterfaceDetail
        'Returns: an SP_DEVICE_INTERFACE_DETAIL_DATA structure
        'containing information about a device.
        'To retrieve the information, call this function twice. ---需要调用两次----
        'The first time returns the size of the structure in Needed.
        'The second time returns a pointer to the data in DeviceInfoSet.
        'Requires:
        'A DeviceInfoSet returned by SetupDiGetClassDevs and
        'an SP_DEVICE_INTERFACE_DATA structure returned by SetupDiEnumDeviceInterfaces.
        MyDeviceInfoData.cbSize = Len(MyDeviceInfoData)
        Result = SetupDiGetDeviceInterfaceDetail _
           (DeviceInfoSet, _
           MyDeviceInterfaceData, _
           0, _
           0, _
           Needed, _
           0)
        DetailData = Needed
        'Store the structure's size.
        MyDeviceInterfaceDetailData.cbSize = _
            Len(MyDeviceInterfaceDetailData)
        'Use a byte array to allocate memory for
        'the MyDeviceInterfaceDetailData structure
        ReDim DetailDataBuffer(Needed)
        'Store cbSize in the first four bytes of the array.
        Call RtlMoveMemory _
            (DetailDataBuffer(0), _
            MyDeviceInterfaceDetailData, _
            4)
        'Call SetupDiGetDeviceInterfaceDetail again.
        'This time, pass the address of the first element of DetailDataBuffer
        'and the returned required buffer size in DetailData.
           (DeviceInfoSet, _
           VarPtr(DetailDataBuffer(0)), _
           DetailData, _
           Needed, _
           0)
        'Convert the byte array to a string.
        DevicePathName = CStr(DetailDataBuffer())
        'Convert to Unicode.
        DevicePathName = StrConv(DevicePathName, vbUnicode)
        'Strip cbSize (4 bytes) from the beginning.
        DevicePathName = Right$(DevicePathName, Len(DevicePathName) - 4)
        DevicePathName = Left$(DevicePathName, Len(DevicePathName) - 2) + "\PIPE02"
        'CreateFile
        'Returns: a handle that enables reading and writing to the device. return -1 if fail
        'Requires:
        'The DevicePathName returned by SetupDiGetDeviceInterfaceDetail.
        HIDHandle = CreateFile _
            (DevicePathName, _
            GENERIC_READ Or GENERIC_WRITE, _
            (FILE_SHARE_READ Or FILE_SHARE_WRITE), _
            Security, _
            OPEN_EXISTING, _
            0&, _
            0)
        'Now we can find out if it's the device we're looking for.
        'HidD_GetAttributes
        'Requests information from the device.
        'Requires: The handle returned by CreateFile.
        'Returns: an HIDD_ATTRIBUTES structure containing
        'the Vendor ID, Product ID, and Product Version Number.
        'Use this information to determine if the detected device
        'is the one we're looking for.
    End If
    'Keep looking until we find the device or there are no more left to examine.
    MemberIndex = MemberIndex + 1
Loop Until (LastDevice = True) Or (DeviceFound = True)
好的,能否说一下大概思路? 是否将usbview源码拿出相关部分做个dll? 通过这个dll就可以直接对pipe操作? 谢谢!  详情 回复 发表于 2009-1-14 11:36
61
参考ddk里面的src\wdm\usb\usbview例子
建议用vc封装一个usb操作动态库接口,然后由vb调用
77
好的,能否说一下大概思路?
谢谢!
