3333|4
createfile 一个驱动sys 在xp下没问题 在2000下错误 [复制链接]
getlasterror代码是 2 找不到指定的文件
xp下 别人的xp下 都是对的
但是2000下 就是createfile失败了
为什么啊
到驱动的代码里看看,看是不是判断系统不同,创建的名字不一样。 另外,2000和xp有可能驱动所属的路径不同,你看看驱动里的代码 举个例子:sfilter里面 RtlInitUnicodeString( &nameString, L"\\FileSystem\\Filters\\SFilter" );     status = IoCreateDevice( DriverObject,                              //0,                      //has no device extension                              sizeof(SFILTER_DEVICE_EXTENSION),                              &nameString,                              FILE_DEVICE_DISK_FILE_SYSTEM,                              FILE_DEVICE_SECURE_OPEN,                              FALSE,                              &gSFilterControlDeviceObject );     if (status == STATUS_OBJECT_PATH_NOT_FOUND) {         //         //  This must be a version of the OS that doesn't have the Filters         //  path in its namespace.  This was added in Windows XP.         //         //  We will try just putting our control device object in the \FileSystem         //  portion of the object name space.         //         RtlInitUnicodeString( &nameString, L"\\FileSystem\\SFilterCDO" );         status = IoCreateDevice( DriverObject,                                  0,                      //has no device extension                                  &nameString,                                  FILE_DEVICE_DISK_FILE_SYSTEM,                                  FILE_DEVICE_SECURE_OPEN,                                  FALSE,                                  &gSFilterControlDeviceObject );         if (!NT_SUCCESS( status )) {                         KdPrint(( "SFilter!DriverEntry: Error creating control device object "%wZ", status=%08x\n", &nameString, status ));             return status;         }              } else if (!NT_SUCCESS( status )) {         KdPrint(( "SFilter!DriverEntry: Error creating control device object "%wZ", status=%08x\n", &nameString, status ));         return status;     } 复制代码  详情 回复 发表于 2010-5-7 11:40
86
各位编写过驱动的帮帮忙啊
还没有人回复我吗。谢谢帮忙啊
66
贴下代码看看
举个例子:sfilter里面
  1. RtlInitUnicodeString( &nameString, L"\\FileSystem\\Filters\\SFilter" );
  2.     status = IoCreateDevice( DriverObject,
  3.                              //0,                      //has no device extension
  4.                              sizeof(SFILTER_DEVICE_EXTENSION),
  5.                              &nameString,
  6.                              FILE_DEVICE_DISK_FILE_SYSTEM,
  7.                              FILE_DEVICE_SECURE_OPEN,
  8.                              FALSE,
  9.                              &gSFilterControlDeviceObject );
  10.     if (status == STATUS_OBJECT_PATH_NOT_FOUND) {
  11.         //
  12.         //  This must be a version of the OS that doesn't have the Filters
  13.         //  path in its namespace.  This was added in Windows XP.
  14.         //
  15.         //  We will try just putting our control device object in the \FileSystem
  16.         //  portion of the object name space.
  17.         //
  18.         RtlInitUnicodeString( &nameString, L"\\FileSystem\\SFilterCDO" );
  19.         status = IoCreateDevice( DriverObject,
  20.                                  0,                      //has no device extension
  21.                                  &nameString,
  22.                                  FILE_DEVICE_DISK_FILE_SYSTEM,
  23.                                  FILE_DEVICE_SECURE_OPEN,
  24.                                  FALSE,
  25.                                  &gSFilterControlDeviceObject );
  26.         if (!NT_SUCCESS( status )) {
  27.
  28.             KdPrint(( "SFilter!DriverEntry: Error creating control device object "%wZ", status=%08x\n", &nameString, status ));
  29.             return status;
  30.         }
  31.
  32.     } else if (!NT_SUCCESS( status )) {
  33.         KdPrint(( "SFilter!DriverEntry: Error creating control device object "%wZ", status=%08x\n", &nameString, status ));
  34.         return status;
  35.     }
复制代码
会议时间:3月18日(周二)09:30签到
参会奖励:电动螺丝刀套装、户外登山包、京东卡
