561|3
502
【DigiKey创意大赛】基于STM32H7B3I-DK的智能家居助手+串口通讯驱动与测试 [复制链接]
  • 串口通讯与驱动
为了方便与其他外设和上位机交互,先实现灵活好用的串口驱动接口。
原理
设计环形缓冲区。接收中断将数据写u人缓冲区,读API查询缓冲区。
环形缓冲区读写需要做临界段保护处理。
代码
bsp_uart.h
#ifndef BSP_UART_H
#define BSP_UART_H
#ifdef __cplusplus
extern "C" {
#endif
void bsp_uart_init(void);
#ifdef __cplusplus
#endif
#endif
Bsp_uart.c
#include <stdio.h>
#include "main.h"
#define USARTx                           USART1
#define USARTx_CLK_ENABLE()              __USART1_CLK_ENABLE()
#define USARTx_RX_GPIO_CLK_ENABLE()      __GPIOA_CLK_ENABLE()
#define USARTx_TX_GPIO_CLK_ENABLE()      __GPIOA_CLK_ENABLE()
#define USARTx_FORCE_RESET()             __USART1_FORCE_RESET()
#define USARTx_RELEASE_RESET()           __USART1_RELEASE_RESET()
/* Definition for USARTx Pins */
#define USARTx_TX_PIN                    GPIO_PIN_9
#define USARTx_TX_GPIO_PORT              GPIOA
#define USARTx_TX_AF                     GPIO_AF7_USART1
#define USARTx_RX_PIN                    GPIO_PIN_10
#define USARTx_RX_GPIO_PORT              GPIOA
#define USARTx_RX_AF                     GPIO_AF7_USART1
UART_HandleTypeDef UartHandle;
  GPIO_InitTypeDef  GPIO_InitStruct;
  RCC_PeriphCLKInitTypeDef RCC_PeriphClkInit;
  /*##-1- Enable peripherals and GPIO Clocks #################################*/
  /* Enable GPIO TX/RX clock */
  USARTx_TX_GPIO_CLK_ENABLE();
  USARTx_RX_GPIO_CLK_ENABLE();
  /* Select SysClk as source of USART1 clocks */
  RCC_PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_USART1;
  RCC_PeriphClkInit.Usart16ClockSelection = RCC_USART16CLKSOURCE_D2PCLK2;
  HAL_RCCEx_PeriphCLKConfig(&RCC_PeriphClkInit);
  /* Enable USARTx clock */
  USARTx_CLK_ENABLE();
  /*##-2- Configure peripheral GPIO ##########################################*/
  /* UART TX GPIO pin configuration  */
  GPIO_InitStruct.Pin       = USARTx_TX_PIN;
  GPIO_InitStruct.Mode      = GPIO_MODE_AF_PP;
  GPIO_InitStruct.Pull      = GPIO_PULLUP;
  GPIO_InitStruct.Speed     = GPIO_SPEED_FREQ_VERY_HIGH;
  GPIO_InitStruct.Alternate = USARTx_TX_AF;
  HAL_GPIO_Init(USARTx_TX_GPIO_PORT, &GPIO_InitStruct);
  /* UART RX GPIO pin configuration  */
  GPIO_InitStruct.Pin = USARTx_RX_PIN;
  GPIO_InitStruct.Alternate = USARTx_RX_AF;
  HAL_GPIO_Init(USARTx_RX_GPIO_PORT, &GPIO_InitStruct);
/*##-1- Configure the UART peripheral ######################################*/
  /* Put the USART peripheral in the Asynchronous mode (UART Mode) */
  /* UART configured as follows:
      - Word Length = 8 Bits (7 data bit + 1 parity bit) :
                  BE CAREFUL : Program 7 data bits + 1 parity bit in PC HyperTerminal
      - Stop Bit    = One Stop bit
      - Parity      = ODD parity
      - BaudRate    = 9600 baud
      - Hardware flow control disabled (RTS and CTS signals) */
  UartHandle.Instance            = USARTx;
  UartHandle.Init.BaudRate       = 115200;
  UartHandle.Init.WordLength     = UART_WORDLENGTH_8B;
  UartHandle.Init.StopBits       = UART_STOPBITS_1;
  UartHandle.Init.Parity         = UART_PARITY_NONE;
  UartHandle.Init.HwFlowCtl      = UART_HWCONTROL_NONE;
  UartHandle.Init.Mode           = UART_MODE_TX_RX;
  UartHandle.Init.OverSampling   = UART_OVERSAMPLING_16;
  UartHandle.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT;
  if(HAL_UART_Init(&UartHandle) != HAL_OK)
    /* Initialization Error */
    Error_Handler();
__HAL_UART_ENABLE_IT(&UartHandle,UART_IT_RXNE);
  HAL_NVIC_SetPriority(USART1_IRQn, 5 ,0U);
  HAL_NVIC_EnableIRQ(USART1_IRQn);
  * @brief  Retargets the C library printf function to the USART.
  * @param  None
  * @retval None
int fputc(int ch, FILE *f)
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART1 and Loop until the end of transmission */
  HAL_UART_Transmit(&UartHandle, (uint8_t *)&ch, 1, 0xFFFF);
  return ch;
void uart_sendbyte(uint8_t val)
  HAL_UART_Transmit(&UartHandle, (uint8_t *)&val, 1, 0xFFFF);
extern void uart_api_rx_handler(const uint8_t *buffer, uint32_t length);
void USART1_IRQHandler(void)
uint8_t ch;
ch = (uint16_t) READ_REG(UartHandle.Instance->RDR);
uart_api_rx_handler(&ch, 1);
Uart_api.c
#include "uart_api.h"
extern void uart_sendbyte(uint8_t val);
typedef struct
    uint32_t datalen_u32;
    uint32_t maxlen_u32;
    uint32_t in_u32;
    uint32_t out_u32;
    uint8_t* buffer_pu8;
}ring_buffer_t;
static uint8_t uart_ring_buffer[UART_RING_BUFFER_SIZE];
static ring_buffer_t s_ring_buffer_t=
    .datalen_u32 = 0,
    .maxlen_u32 = sizeof(uart_ring_buffer),
    .in_u32 = 0,
    .out_u32 = 0,
    .buffer_pu8 = uart_ring_buffer,
    uint32_t i;
    for(i=0;i<length; i++)
        if(s_ring_buffer_t.datalen_u32 < s_ring_buffer_t.maxlen_u32)
            s_ring_buffer_t.buffer_pu8[s_ring_buffer_t.in_u32] = buffer;
            s_ring_buffer_t.datalen_u32++;
            s_ring_buffer_t.in_u32++;
            s_ring_buffer_t.in_u32 %= s_ring_buffer_t.maxlen_u32;
        else
            /* full */
            break;
uint32_t uart_api_read(uint8_t *buff, uint32_t len)
    uint32_t readlen = 0;
    if(s_ring_buffer_t.datalen_u32 == 0)
        return 0;
Alloc_Critical();
    Enter_Critical();
    uint32_t i;
    for(i=0;i<len;i++)
if(s_ring_buffer_t.datalen_u32 > 0)
buff = s_ring_buffer_t.buffer_pu8[s_ring_buffer_t.out_u32];
s_ring_buffer_t.datalen_u32--;
s_ring_buffer_t.out_u32++;
s_ring_buffer_t.out_u32 %= s_ring_buffer_t.maxlen_u32;
readlen++;
else
break;
    Exit_Critical();
    return readlen;
void uart_api_write(uint8_t *buff, uint32_t len)
uint32_t i;
for(i=0; i<len ;i++)
uart_sendbyte(buff);
Uart_api.h
#ifndef UART_API_H
#define UART_API_H
#ifdef __cplusplus
extern "C" {
#endif
#include <stdint.h>
#include "cmsis_os.h"
#define Alloc_Critical()
#define Enter_Critical()    taskENTER_CRITICAL();
#define Exit_Critical()     taskEXIT_CRITICAL();
#define UART_RING_BUFFER_SIZE (1024+64)
uint32_t uart_api_read(uint8_t *buff, uint32_t len);
void uart_api_write(uint8_t *buff, uint32_t len);
#ifdef __cplusplus
#endif
#endif
测试
使用上位机发送数据,板子原样返回,测试收发完全正确。
uint8_t buffer[64];
uint32_t  len;
while((len = uart_api_read(buffer, sizeof(buffer))) > 0)
uart_api_read(buffer,len);
期待看实物图  详情 回复 发表于 2023-12-14 10:17
6628
期待后面的测试项目
 /* Place your implementation of fputc here */,,,,,单片机编程的话用什么软件,谢谢
223
期待看实物图
