6360|17
请教一下--wince4.2 部分SD卡能找到,部分SD怎么都找不到. [复制链接]
  用2440做的wince4.2的系统...
  手里有2张SD卡..还有2张TF卡.
  结果其中有一张SD卡,插入设备,调试信息输出:
charlie::Prescale for Real clock rate = 156, pRate:100000
Card inserted
SDCSDSlotOptionHandler:0x1
BUS Width 1Bit
SD_API_STATUS_CMD_RESPONSE_TIMEOUT
BusRequestHandler Error - command:0x05
BusRequestHandler Error - command:0x01
Card status error:0x400120,CMD:55
SDCSDSlotOptionHandler:0x0
SDCSDSlotOptionHandler - called - SetSlotPower : 0x00100000
到这里没有了,系统找不到卡.
用另外一张SD卡,插入设备能正确找到卡.
输出的调试信息,除了上面的多了下面的一段.
SDCSDSlotOptionHandler:0x5
SDCSDSlotOptionHandler - called - SDHCDGetWriteProtectStatus : on slot 0
BUS Width 4Bit
charlie::Prescale for Real clock rate = 4, pRate:25000000
卡的插入拔出也是对的...
不知道什么原因..
是不是SD卡水货和行货的区别哦?
此帖出自WindowsCE论坛
SDHC 没有成功 现在下面的信息: charlie::Prescale for Real clock rate = 156, pRate:100000 Card inserted SDCSDSlotOptionHandler:0x1 BUS Width 1Bit charlie::Prescale for Real clock rate = 156, pRate:100000 CMD:5,0x0 SD_API_STATUS_CMD_RESPONSE_TIMEOUT BusRequestHandler Error - command:0x05 CMD:5,0x0 SD_API_STATUS_CMD_RESPONSE_TIMEOUT BusRequestHandler Error - command:0x05 CMD:5,0x0 SD_API_STATUS_CMD_RESPONSE_TIMEOUT BusRequestHandler Error - command:0x05 CMD:5,0x0 SD_API_STATUS_CMD_RESPONSE_TIMEOUT BusRequestHandler Error - command:0x05 CMD:0,0x0 CMD:1,0x300000 SD_API_STATUS_CMD_RESPONSE_TIMEOUT BusRequestHandler Error - command:0x01 CMD:1,0x300000 SD_API_STATUS_CMD_RESPONSE_TIMEOUT BusRequestHandler Error - command:0x01 CMD:1,0x300000 SD_API_STATUS_CMD_RESPONSE_TIMEOUT BusRequestHandler Error - command:0x01 CMD:1,0x300000 SD_API_STATUS_CMD_RESPONSE_TIMEOUT BusRequestHandler Error - command:0x01 CMD:55,0x0 Card status error:0x400120,CMD:55 CMD:41,0x0 SDCSDSlotOptionHandler:0x0 SDCSDSlotOptionHandler - called - SetSlotPower : 0x00100000   MSIM: IM_ReadRegistry read KB 5 CMD:0,0x0 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 Explorer(V2.0) taskbar thread started. CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 NDISPWR:: Found adapter [DM9CE1] CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000 CMD:55,0x0 CMD:41,0x100000  详情 回复 发表于 2010-1-13 14:03
有SD能读出来,说明系统是支持的,但是性能不好,那么就只能猜了
1 有可能是SD性能的原因,我们这边也WinCe4.2的系统就是这样子,有的U盘可以识别
有的死活就识别不了,郁闷;
2 WinCE4.2下系统本身驱动支持的就不是很好,我先用WinCE6.0就比4.2好了很多
此帖出自WindowsCE论坛
86
看你的卡的容量是多少?
2440的BSP不支持2G(4G?)以上容量的卡。
此帖出自WindowsCE论坛
关注
此帖出自WindowsCE论坛
卡的容量都是一样的..所以才奇怪.
买卡的人给我说的是,能读的那个卡是 行货卡...不能读的那张是水货卡..
此帖出自WindowsCE论坛
87
卡的质量问题
所有嵌入式设备上都有这个问题,基本上无解
此帖出自WindowsCE论坛
85
ding
此帖出自WindowsCE论坛
67
ding
此帖出自WindowsCE论坛
sd卡的主要用途不在嵌入式,所以一般劣质的只保证windows下能认。
另外,有这样问题的不是水卡,而是仿卡。水卡的质量不比行货差,只是逃了税,无维护,才便宜。
此帖出自WindowsCE论坛
81
引用 8 楼 shuiyan 的回复:
有没有什么办法能解决捏...不会限定别人使用某种卡吧
此帖出自WindowsCE论坛
引用 9 楼 libin_uclinux 的回复:
引用 8 楼 shuiyan 的回复:
格式化一下 你的sd卡,不行的话就在command 5等待response的时间改的长一点.
此帖出自WindowsCE论坛
引用 10 楼 abo77281 的回复:
引用 8 楼 shuiyan 的回复:
请问,你说的在command 5等待response的时间改的长一点,修改地方在那里捏?
对SD的驱动不怎么熟悉..
此帖出自WindowsCE论坛
顶一下,wince4.2 的SD卡驱动就没有办法 修改么?
此帖出自WindowsCE论坛
84
不知道此问题有没有解决,我关注一下。。。。。。。。。。
此帖出自WindowsCE论坛
63
高速卡和低速卡?
4.2不能支持现在很多高速卡的
只能支持普通卡,例如创见的4g普通卡,一般这些卡都是三星的芯片
此帖出自WindowsCE论坛
卡的质量及SD卡驱动问题
此帖出自WindowsCE论坛
77
引用 11 楼 libin_uclinux 的回复:
引用 8 楼 shuiyan 的回复:
对SD的驱动不怎么熟悉..
不是command 5,是在上电后,在发command 0之前,要有足够的延时,这个延时加长一点。
另外要看看你的sd卡部分的硬件电路的供电部分。这个电压不能太低。
其实这个也跟卡的质量有很大的关系,呵呵!
此帖出自WindowsCE论坛
SDHC 没有成功
现在下面的信息:
Card inserted
BUS Width 1Bit
CMD:5,0x0
CMD:5,0x0
CMD:5,0x0
CMD:5,0x0
CMD:0,0x0
CMD:1,0x300000
CMD:1,0x300000
CMD:1,0x300000
CMD:1,0x300000
CMD:55,0x0
CMD:41,0x0
CMD:0,0x0
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
CMD:55,0x0
CMD:41,0x100000
此帖出自WindowsCE论坛
