446|0
7091
【得捷电子Follow me第3期】任务3控制蜂鸣器播放音乐 [复制链接]
开发的扩展板板载了一个蜂鸣器,接在PIN5个
1、我们引入import machine
2、pin为5:buzzer_pin = machine.Pin(5, machine.Pin.OUT)
3、配置为pwm输出:buzzer = machine.PWM(buzzer_pin)
4、指定频率为1047:buzzer.freq(1047)
5、在主循环中修改占空比,以达到响与关的效果:
while True:
buzzer.duty(100)
time.sleep(1)
buzzer.duty(0)
time.sleep(1)
播放音乐
  1. pwm的频率决定音调,根据资料定义音谱频率如下:
    # Defining frequency of each music note
    NOTE_C4 = 262
    NOTE_D4 = 294
    NOTE_E4 = 330
    NOTE_F4 = 349
    NOTE_G4 = 392
    NOTE_A4 = 440
    NOTE_B4 = 494
    NOTE_C5 = 523
    NOTE_D5 = 587
    NOTE_E5 = 659
    NOTE_F5 = 698
    NOTE_G5 = 784
    NOTE_A5 = 880
    NOTE_B5 = 988
  2. 根据乐谱,制定如下频率表:
    # Music notes of the song, 0 is a rest/pulse
    notes = [
    NOTE_E4, NOTE_G4, NOTE_A4, NOTE_A4, 0,
    NOTE_A4, NOTE_B4, NOTE_C5, NOTE_C5, 0,
    NOTE_C5, NOTE_D5, NOTE_B4, NOTE_B4, 0,
    NOTE_A4, NOTE_G4, NOTE_A4, 0,
    NOTE_A4, NOTE_C5, NOTE_D5, NOTE_D5, 0,
    NOTE_D5, NOTE_E5, NOTE_F5, NOTE_F5, 0,
    NOTE_E5, NOTE_D5, NOTE_E5, NOTE_A4, 0,
    NOTE_A4, NOTE_C5, NOTE_B4, NOTE_B4, 0,
    NOTE_C5, NOTE_A4, NOTE_B4, 0,
    NOTE_A4, NOTE_A4,
    #Repeat of first part
    #End of Repeat
    NOTE_E5, 0, 0, NOTE_F5, 0, 0,
    NOTE_E5, NOTE_E5, 0, NOTE_G5, 0, NOTE_E5, NOTE_D5, 0, 0,
    NOTE_D5, 0, 0, NOTE_C5, 0, 0,
    NOTE_B4, NOTE_C5, 0, NOTE_B4, 0, NOTE_A4,
  3. 而延时决定声音的长短。我们根据乐谱制作时序如下表:
# Durations (in ms) of each music note of the song
# Quarter Note is 250 ms when songSpeed = 1.0
durations = [
125, 125, 250, 125, 125,
125, 125, 375, 125,
125, 125, 375, 125,
125, 125, 125, 250, 125,
250, 125, 250, 125,
125, 125, 375, 375,
250, 125,
#Rpeat of First Part
125, 125, 375, 125,
125, 125, 375, 125,
250, 125, 250, 125,
125, 125, 375, 375,
#End of Repeat
250, 125, 375, 250, 125, 375,
125, 125, 125, 125, 125, 125, 125, 125, 375,
125, 125, 125, 125, 125, 500,
结合以上三个数组,做播放声音程序如下:
def play_song():
total_notes = len(notes)
for i in range(total_notes):
current_note = notes
wait = durations
if current_note != 0:
buzzer.duty(512) # Set duty cycle for sound
buzzer.freq(current_note) # Set frequency of the note
else:
buzzer.duty(0) # Turn off the sound
time.sleep_ms(wait)
总的程序如下:
import machine
import time
from machine import Pin, SoftI2C
import ssd1306py as lcd
i2c = SoftI2C(scl=Pin(7), sda=Pin(6))  # Adjust the Pin numbers based on your connections
lcd.init_i2c(7,6,128,64)
lcd.text('PLAY SONG', 10, 10, 16)
lcd.show()
# Buzzer settings
buzzer.freq(1047)
NOTE_C4 = 262
NOTE_D4 = 294
NOTE_E4 = 330
NOTE_F4 = 349
NOTE_G4 = 392
NOTE_A4 = 440
NOTE_B4 = 494
NOTE_C5 = 523
NOTE_D5 = 587
NOTE_E5 = 659
NOTE_F5 = 698
NOTE_G5 = 784
NOTE_A5 = 880
NOTE_B5 = 988
notes = [
    NOTE_A4, NOTE_A4,
    #End of Repeat
durations = [
    125, 125, 375, 125,
    125, 125, 375, 125,
    250, 125, 250, 125,
    125, 125, 375, 375,
    250, 125,
    125, 125, 375, 125,
    125, 125, 375, 125,
    250, 125, 250, 125,
    125, 125, 375, 375,
    #End of Repeat
def play_song():
        current_note = notes[i]
        wait = durations[i]
        else:
        time.sleep_ms(wait)
while True:
    # Play the song
    play_song()
实现效果:
播放音乐
