811|1
441
【STM32F723 Discovery Kit】tcp server和tcp client测试 [复制链接]
这篇来测试下,在w5500模块上实现tcp server和tcp client测试。在上篇https://bbs.eeworld.com.cn/thread-1262011-1-1.html的基础上,添加tcp 代码。
一、代码
1.1、tcp_demo.c
* [url=home.php?mod=space&uid=1307177]@File[/url] tcp_demo.c
* [url=home.php?mod=space&uid=252314]@version[/url] V1.2
* [url=home.php?mod=space&uid=311857]@date[/url] 2017-11-01
* [url=home.php?mod=space&uid=159083]@brief[/url] TCP ÑÝʾº¯Êý
#include <stdio.h>
#include <string.h>
#include "tcp_demo.h"
#include "W5500_conf.h"
#include "w5500.h"
#include "socket.h"
#include "utility.h"
uint8 buff[2048];				                              	        /*¶¨ÒåÒ»¸ö2KBµÄ»º´æ*/
*@brief		TCP Server»Ø»·ÑÝʾº¯Êý¡£
*@param		ÎÞ
*[url=home.php?mod=space&uid=784970]@return[/url] ÎÞ
void do_tcp_server(void)
	uint16 len=0;
	switch(getSn_SR(SOCK_TCPS))											            	/*»ñÈ¡socketµÄ״̬*/
		case SOCK_CLOSED:													                  /*socket´¦ÓڹرÕ״̬*/
			socket(SOCK_TCPS ,Sn_MR_TCP,local_port,Sn_MR_ND);	        /*´ò¿ªsocket*/
			break;
		case SOCK_INIT:														                  /*socketÒѳõʼ»¯×´Ì¬*/
			listen(SOCK_TCPS);												                /*socket½¨Á¢¼àÌý*/
			break;
		case SOCK_ESTABLISHED:												              /*socket´¦ÓÚÁ¬½Ó½¨Á¢×´Ì¬*/
			if(getSn_IR(SOCK_TCPS) & Sn_IR_CON)
				setSn_IR(SOCK_TCPS, Sn_IR_CON);								          /*Çå³ý½ÓÊÕÖжϱê־λ*/
			len=getSn_RX_RSR(SOCK_TCPS);									            /*¶¨ÒålenΪÒѽÓÊÕÊý¾ÝµÄ³¤¶È*/
			if(len>0)
				recv(SOCK_TCPS,buff,len);								              	/*½ÓÊÕÀ´×ÔClientµÄÊý¾Ý*/
//				buff[len]=0x00; 											                  /*Ìí¼Ó×Ö·û´®½áÊø·û*/
//				printf("%s\r\n",buff);
				send(SOCK_TCPS,buff,len);									              /*ÏòClient·¢ËÍÊý¾Ý*/
			break;
		case SOCK_CLOSE_WAIT:												                /*socket´¦Óڵȴý¹Ø±Õ״̬*/
			close(SOCK_TCPS);
			break;
*@brief		TCP Client»Ø»·ÑÝʾº¯Êý¡£
*@param		ÎÞ
*@return	ÎÞ
void do_tcp_client(void)
	uint16 len=0;
	switch(getSn_SR(SOCK_TCPC))								  				         /*»ñÈ¡socketµÄ״̬*/
			socket(SOCK_TCPC,Sn_MR_TCP,local_port++,Sn_MR_ND);
			break;
		case SOCK_INIT:													        	         /*socket´¦ÓÚ³õʼ»¯×´Ì¬*/
			connect(SOCK_TCPC,remote_ip,remote_port);                /*socketÁ¬½Ó·þÎñÆ÷*/
			break;
		if(getSn_IR(SOCK_TCPC) & Sn_IR_CON)
			setSn_IR(SOCK_TCPC, Sn_IR_CON); 							         /*Çå³ý½ÓÊÕÖжϱê־λ*/
		len=getSn_RX_RSR(SOCK_TCPC); 								  	         /*¶¨ÒålenΪÒѽÓÊÕÊý¾ÝµÄ³¤¶È*/
		if(len>0)
			recv(SOCK_TCPC,buff,len); 							   		         /*½ÓÊÕÀ´×ÔServerµÄÊý¾Ý*/
			send(SOCK_TCPC,buff,len);								     	         /*ÏòServer·¢ËÍÊý¾Ý*/
		break;
		close(SOCK_TCPC);
		break;
1.2、tcp_demo.h
#ifndef __TCP_DEMO_H
#define __TCP_DEMO_H
#include "types.h"
extern uint16 W5500_tcp_server_port;
void do_tcp_server(void);//TCP Server»Ø»·ÑÝʾº¯Êý
void do_tcp_client(void);//TCP Clinet»Ø»·ÑÝʾº¯Êý
void setKPALVTR(SOCKET i,uint8 val);
#endif
1.3、main.c
tcp server测试
#include "main.h"
#include "led/led.h"
#include "delay/delay.h"
#include "key/key.h"
#include "usart/usart.h"
#include "sram/sram.h"
#include "STM32F723E-Discovery/stm32f723e_discovery_lcd.h"
#include "STM32F723E-Discovery/stm32f723e_discovery_qspi.h"
#include "i2c/i2c.h"
#include "spi/spi.h"
#include "tim/tim.h"
#include "w5500_conf.h"
#include "w5500.h"
#include "ping.h"
static void MPU_Config(void);
static void SystemClock_Config(void);
static void CPU_CACHE_Enable(void);
int main(void)
	uint16_t i=0;
	uint8_t txbuf[10];
	uint8_t rxbuf[10];
	HAL_Init();
  MPU_Config();					/* Configure the MPU attributes */
  CPU_CACHE_Enable();		/* Enable the CPU Cache */
  SystemClock_Config();	/* Configure the system clock to 216 MHz */
	delay_init(216);
	led_init();
	usart_init(115200);
	init_spi();
	BSP_LCD_Init();
	gpio_for_w5500_config();
	reset_w5500();
	PHY_check();													/*¼ì²éÍøÏßÊÇ·ñ½ÓÈë*/
  set_w5500_mac();											/*ÅäÖÃMACµØÖ·*/
  set_w5500_ip();												/*ÅäÖÃIPµØÖ·*/
	socket_buf_init(txsize, rxsize);			/*³õʼ»¯8¸öSocketµÄ·¢ËͽÓÊÕ»º´æ´óС*/
	printf(" tcp server test! \r\n");
	LED5(0);
  LED6(1);
	BSP_LCD_Clear(LCD_COLOR_RED);
	printf(" tcp server port: %d! \r\n",local_port);
  while (1)
		do_tcp_server();                    /*TCP_Server Êý¾Ý»Ø»·²âÊÔ³ÌÐò*/
1.4、main.c
tcp client测试
#include "main.h"
#include "w5500.h"
#include "ping.h"
int main(void)
	uint16_t i=0;
	uint8_t txbuf[10];
	uint8_t rxbuf[10];
	HAL_Init();
	delay_init(216);
	led_init();
	usart_init(115200);
	init_spi();
	BSP_LCD_Init();
	reset_w5500();
	printf(" tcp client test! \r\n");
	LED5(0);
  LED6(1);
	printf("server ip:%d.%d.%d.%d\r\n",remote_ip[0],remote_ip[1],remote_ip[2],remote_ip[3]);
	printf("port :%d \r\n",remote_port);
  while (1)
		do_tcp_client();
二、运行结果
2.1、tcp server 测试
串口输出
网络调试助手
开发板回复网络调试助手发送的内容
2.2、tcp client 测试
先打开网络调试助手,创建服务器,然后给开发板上电,建立网络连接
建立连接后,网络调试助手发送消息后,收到开发板的回复,同时串口输出收到的消息。
以上是tcp server 和tcp client测试的内容。
此帖出自stm32/stm8论坛
初步看tcp server 和tcp client测试的内容整的不错   详情 回复 发表于 2023-11-6 07:32
6822
此帖出自stm32/stm8论坛
